Unicyclist Community
Reply
Old 2008-04-01, 08:33 AM   #1
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
Maggies or V-brake on a 36"?
Alright, I'm going to get another Triton frame...this time a 36".
Although I hardly ever use a brake, I'd like to have brake mounts as an option for Coker Muni and the occasional steep road ride. There are few situations where I think it might come in handy.
Just have to decide whether to have Magura mounts or V-brake/cantilever type mount welded on the frame. I have an Odyssey A brake already which has been gathering dust in the drawer. I also have a set of Maguras which are sitting unused on my 24" Muni.
Those of you who run brakes on your 36"....what are your thoughts on this?
GizmoDuck is offline   Reply With Quote
Old 2008-04-01, 08:44 AM   #2
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
I just use a BMX calliper on my 36 - just needs a hole through the crown. Tidy and very cheap. And probably a bit lighter than Maguras (as you're known to be a bit of a weight weenie )
But if you're thinking of Vs or Maguras, if you get Magura mounts fitted to the frame you can screw canti adapters into the lower holes if you decide to go with Vs. The top mounts will be pretty much obscured by the V brake anyway so it won't look too untidy, and the extra weight of the top mounts will be insignificant.
That's what I'd do anyway - although I think even if I was replacing my (very cheap) 36 with a new one I'd still probably use a BMX calliper.
Rob
rob.northcott is offline   Reply With Quote
Old 2008-04-01, 09:09 AM   #3
joemarshall
dumb blonde
yeah magura mounts if you're not sure - if you use v brakes on magura mounts it looks and works okay. if you put maguras on v brake mounts it is a right hassle to set up and looks minging.
Joe
joemarshall is offline   Reply With Quote
Old 2008-04-01, 12:07 PM   #4
Seager
I had a thing in here one time!
Seager's Avatar
Send a message via AIM to Seager
The adaptors you speak of, they are something like this?
http://www.chainreactioncycles.com/M...?ModelID=21791
are there better or recommended ones out there?
Or these: http://www.unicycle.uk.com/shop/shop...?catalogid=909
The US version of UDC apparently does not have them. I just bought a used coker and live on a very long and steep hill and would like brakes for when I commute to work. I'm sure you've inferred by now that I can't afford maggies.
Seager is offline   Reply With Quote
Old 2008-04-01, 12:28 PM   #5
rob.northcott
Mainly XC Muni
Seager: Yes that's the type of thing. Those adaptors on CRC might work as long as the thread is right to fit the Magura bosses. But if you want cheap, easy and effective I'd say go for a BMX calliper - you can pick them up for next to nothing and they work fine. All you need to do is drill a hole through the crown of the frame for the mounting bolt. Make sure you get a front brake (the bolt will be too short on a rear one) and check the amount of drop (vertical distance from the bolt to the brake blocks) is enough. Most brakes meant for BMX are big enough. If you're using a steel rim it's worth getting hold of some leather faced brake blocks - they work much better especially in the wet (not as easy to get as they used to be now people don't use steel rims on bikes much, but still available if you look - my LBS still stocks a couple of pairs).
Rob
Old 2008-04-01, 12:32 PM   #6
Seager
Seager's Avatar
Thanks for the info. I don't want to drill the frame and may upgrade to maggies later, so the adapter probably is a better fix for me.
I do have a steel rim, as well. It's a pretty old-school coker wheel.
Old 2008-04-01, 12:37 PM   #7
rob.northcott
Mainly XC Muni
I doubt you'll find any Magura blocks that work too well on a steel rim if it's damp - you'll be OK in the dry. I'm not sure if you can get leather V-brake blocks either. Rubber blocks on steel rims in the wet are next to useless.
Rob
Old 2008-04-01, 12:45 PM   #8
Seager
Seager's Avatar
hmm... definately good to know since I live in rain city, USA. Good think I'll have my trusty bike for a backup. Thanks for the warning.
Old 2008-04-01, 02:57 PM   #9
corbin
Treehouse Muni Rider
corbin's Avatar
Send a message via AIM to corbin
Hey Ken,
I recently switched from magura's to a simple cable brake (from a kids bike). I prefer the cable brake, as it is less prone to accidental biting -- especially when riding down rough terrain. Plus, the Nimbus frame tends to flex a little bit, so the maguras would rub against the wheel on really (really really) steep inclines. However, the Ti frame may flex less (or not at all), so that may no longer be an issue.
I'd say go with the magura mounts, and then use an adapter if the magura's don't work out. But, give both a try.
corbin
__________________
http://www.corbinstreehouse.com
maestro8 fan club
Justin LE fan club
corbin is offline   Reply With Quote
Old 2008-04-01, 03:45 PM   #10
joemarshall
dumb blonde
magura v-brake adaptors are something like this
the second thing posted above, not the marzocchi thing (which won't work).
The adaptors aren't worth going for on a cost basis if you already have a frame with magura mounts, if you are stuck for money, buying a 2nd hand magura makes much more sense. I paid £15-£20 for each of my HS33s including postage, which is only about the same as a v-brake, and less than adaptor plus v-brakes. Just watch ebay and bid on the ones that aren't at stupid prices at the last minute.
Joe
Reply
Tags
maggies or vbrake on a 36
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New 36" tire and Two 36" Rims Announced By UDC Brian O. General Unicycling Discussions 98 2008-06-03 07:04 AM
QU-AX 36" and brake Triball Unicycle Product Reviews 3 2008-03-10 07:29 AM
Nimbus 36" with V brake innes General Unicycling Discussions 17 2008-02-18 09:28 AM
NEw Video: Uni Geezer: "36 in 36 on a 36er!" MuniAddict General Unicycling Discussions 16 2007-08-08 10:18 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07767 seconds with 10 queries
