Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycling Articles and Tutorials
Reply
Old 2008-02-23, 01:23 PM   #1
Uni-Jam
Registered User
SIF hopping:Tucking?? help?
I hop 63cm SIF but I can't tucking can anyone help me how I must tuck the unicycle.
Uni-Jam is offline   Reply With Quote
Old 2008-02-23, 01:49 PM   #2
TrialsUni
urban trials with a street flare
TrialsUni's Avatar
Send a message via AIM to TrialsUni Send a message via MSN to TrialsUni
you should be able to find a lot of information when you use the search feature.
but, i'll help you out with an older post of mine:
Quote:
Originally Posted by TrialsUni
One of the biggest things, that someone already said, but I'll reinforce is confidence. Tell yourself that you can do it, convince your mind that what ever you're hopping on is not as big as your mind wants you to think because of a lack of confidence.
A hop is basically you pulling your knees up to your chest. This is what's called tuck. What helps you be able to tuck the uni underneath you is your sense of timing. As Zack Baldwin used to say, it's all about TUCK and TIMING. The quicker you force compression (the push off from the ground you make before you go into the air), and then suck the uni up under you, the higher you'll go more than likely.
The more you practice, the better your sense of timing gets.
When you start hopping onto bigger stuff, get that extra boost with a pre-hop.
NOTE: this is all for SIF hopping. I'm not sure how you hop.
For seat-in-front practice, just ride around with the seat out in front of you.
Try not to let the seat push against your legs, but just brush up against your legs. Relax your arm that's holding onto your seat. Put only as much pressure as you need to hold onto it. Use your other arm, that's not holding the seat, for balance.
As you get better, trying riding seat-in-front up hills, down hills, backwards, turning both directions. You can also try to ride forward, and see how far you can hold the seat out in front of you. The more you practice, and comfortable you get with seat-out riding, you'll be able to hold the seat really far out in front of you while riding.
I'm so comfortable riding seat-out, that it sometimes feels weird riding seat-in. As a matter of fact, I rarely do anything trials seat-in, anymore.
I suggest you get comfortable sif riding, before you start sif hopping, which is called jumping. But, practice hopping seat in, in the meantime, since it involves similar techniques and principles.
AND, here's a whole thread about tucking SIF: http://www.unicyclist.com/forums/sho...ight=high+hops
I hope this helps. And it's never too early to learn how to use the search feature.
evan
TrialsUni is offline   Reply With Quote
Old 2008-02-24, 10:00 AM   #3
Uni-Jam
Registered User
sorry
But thanks
Reply
Tags
hoppingtucking, sif
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help with a no-footer-i've been trying for a month!!!!!!!!!!!!!!!PLEASE HELP Beni General Unicycling Discussions 8 2008-08-07 10:13 PM
tucking sif? mornish General Unicycling Discussions 43 2008-06-13 04:30 AM
Sif?? TheGreenMonster Just Conversation & Introduce Yourself 9 2008-02-20 09:30 PM
SIF hopping unidunc Unicycling Articles and Tutorials 20 2008-02-19 07:57 PM
problem with SIF señor coolguy Unicycling Articles and Tutorials 6 2007-08-03 01:51 AM
Copyright © 2001-2005 Gilby
Page generated in 0.06474 seconds with 10 queries
