Unicyclist Community
Reply
Old 2008-01-30, 05:08 AM   #1
Brian O.
Team Spencer Photographer
Brian O.'s Avatar
New 36" tire and Two 36" Rims Announced By UDC
For those of you not following the "Exciting news for 36" enthusiasts" thread, Roger of UDC UK has announced a new 36" tire and two new 36" rims!
Quote:
Originally Posted by rogeratunicycledotcom
Attention fellow commuters! During the past year, your worldwide Unicycle.com team has been developing a new tire and rim for all 36-inch unicycles. We have some exciting new products to announce that are coming to Unicycle.com’s world-wide in the next few weeks!
The Nightrider, our new 36-inch tire, has an innovative, cross-cut tread pattern that offers a huge improvement in performance and control. The 2-ply construction makes it the lightest-available 36-inch tire on the market and it’s rated to a whopping 65 PSI!
We’ve also developed two new 36" rims, the Stealth and Stealth Pro, both of which have a hardened-aluminium box-section that offers considerable weight savings and better performance over previous
products.
The Stealth Pro, which is standard on the Nimbus 36-inch unicycle, has a machined braking surface and spoke-nipple eyelets. The Stealth model, which is standard on the UDC 36-inch unicycle, does not include the machined braking surface or spoke-nipple eyelets.
All UDC/Nimbus unicycles will include with 14 gauge stainless steel spokes. Specifications:
The Nimbus Nightrider 36" tire
• Size: 36 x 2.25 inches, to fit 787mm rim
• Construction: 2-ply
• Pressure rating: 35 - 65PSI (250-450kpa)
• Tread pattern: cross-cut block style - great for both road and trail riding.
• Weight 1660g
The Nimbus Stealth Pro Rim
• Width: wide (38mm) for stability
• Spoke holes: 36, 14 gauge
• Size: ISO 787mm
• Material: high-quality 6061-T6 aluminium
• Construction: double-wall
• Finish: hard, black anodised with CNC-machined braking surfaces
• Colour: black
• Nipple eyelets: stainless steel for better wheel tension
• Weight: 1116g
The Nimbus Stealth Rim
• Size: ISO 787mm
• Colour: black
• Eyelets: none
• Weight: 1116g
Basically the best thing since sliced bread! :-)
Roger
__________________
Get cool unicycle posters, pins and more! All products are my personal photography. * New Poster 11/16/2010 *
Brian O. is offline   Reply With Quote
Old 2008-01-30, 05:21 AM   #2
MuniAddict
Not "2" Tired
MuniAddict's Avatar
I'm wondering about the tread life on that new, lighter tire compared to the beefier TA tire. I have found the TA to be a great tire for both distance riding on paved roads, and offroad as well. I can see hardly any wear after many hundreds of miles so far.
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2008-01-30, 05:32 AM   #3
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
Will that tire fit on airfoils?
Wow these are 30 grams lighter than my drilled rim...
ntappin is offline   Reply With Quote
Old 2008-01-30, 05:39 AM   #4
XCcrev
Learning Crankflips
XCcrev's Avatar
Quote:
yeah it should however the coker beaded tire does not according to UDC
XCcrev is offline   Reply With Quote
Old 2008-01-30, 05:39 AM   #5
Borgschulze
2 Wheel Traitor
Borgschulze's Avatar
Send a message via MSN to Borgschulze
What rim is that? I'm assuming Airfoil drilled rim?
__________________
Gravity is not the issue.
Borgschulze is offline   Reply With Quote
Old 2008-01-30, 05:49 AM   #6
lpounds
Registered User
lpounds's Avatar
Send a message via MSN to lpounds
I guess I sprung for my 36er a month too soon.
__________________
Unicycle Dot Com Canada
lpounds is offline   Reply With Quote
Old 2008-01-30, 05:57 AM   #7
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
A question for Roger...
How does the quality and strength of the casing and bead compare with the previous Coker and TA tyres? Is it made in that same factory?
I know I've destroyed three sets of Coker Tyres because they do not tolerate going tubeless very well. I had no problems with my first tubeless set-up, but subsequently I've blown up the beads and casings of three Coker tyres.
The new rim/tyre combo with a tubeless set-up would make an awesomely lightweight wheelset.
Ken
GizmoDuck is offline   Reply With Quote
Old 2008-01-30, 06:04 AM   #8
feel the light
level 1 fat guy
Like Terry said
Ya gotta love the wear on the TA tire. Mine looks almost new at 1000 ish miles. So here in flat snowless ville, the new tire looks cool, but it may take me 10 or so years to wear out the TA. The new tire looks good though.
The rims look good.
Now we have 3 brands of 36" tires. Why oh why won't someone make a 42 or bigger?
It's gonna happen, sell huge, and make manufactures scratch their heads and say, "well, that was easy."
feel the light is offline   Reply With Quote
Old 2008-01-30, 06:30 AM   #9
lpounds
Registered User
lpounds's Avatar
So very true. I like my 36er but I can't see what wouldn't be better about a bigger wheel, as long as it is a pneumatic tire. Why is 42" the next logical size btw?
__________________
Old 2008-01-30, 07:32 AM   #10
GizmoDuck
GizmoDuck's Avatar
I think it's better to have a good choice of 36" tyres. It's a much more versatile wheel size for most terrain. 42" is going to get pretty heavy and unwieldy. You would need to make a very good rim and tyre for it to be worthwhile.
Old 2008-01-30, 08:21 AM   #11
unijuul
Registered User
unijuul's Avatar
Very good news!
Has the new tire some bigger circumference? A couple of cm because of the new tread pattern?
__________________
www.unijuul.com
unijuul is offline   Reply With Quote
Old 2008-01-30, 10:41 AM   #12
onebyone
Registered User
Send a message via ICQ to onebyone
Smile 42"
Lets be patient. New ground is being broken all the time and who would have thought the 36" unicycles would have come so far in a few years. Have you seen a production 36 MTB yet?
It is a bloody long way down if you fall off though but I am prepared.
__________________
Mal
Unicycle.com Australia
www.municycle.com.au
onebyone is offline   Reply With Quote
Old 2008-01-30, 07:57 PM   #13
maestro8
is what it is
maestro8's Avatar
Quote:
I'm looking for a new tire (and maybe even rim) for the Uninam tour. I'd be more than happy to give it a 500km road test if Roger were willing to ship one to me at a cut rate
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2008-01-30, 08:16 PM   #14
BoojiBoy
Team Unicycle Max
BoojiBoy's Avatar
Send a message via AIM to BoojiBoy
And incidentally, the old steel rims that were stock on the Nimbus 36" are gone forever. It's all airfoil all the time now.
__________________
dreamrapper.wordpress.com
www.unicyclemax.com
BoojiBoy is offline   Reply With Quote
Old 2008-01-30, 09:36 PM   #15
Brian O.
Brian O.'s Avatar
Quote:
Good riddance.
__________________
Reply
Tags
36 tire and two 36, announced, rims, udc
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New 24"/29"/36" Frame and Handle unit i made. iridemymuni General Unicycling Discussions 11 2010-11-16 01:02 AM
New grapefruit Nimbus 36" with the new T 6.5 handle onebyone General Unicycling Discussions 5 2007-11-03 02:18 AM
36 hole hub and 48 hole rim? Matt_V General Unicycling Discussions 27 2007-10-08 03:39 PM
New UDC Double Walled 36" Rim! kerosian General Unicycling Discussions 45 2007-09-05 06:15 PM
NEw Video: Uni Geezer: "36 in 36 on a 36er!" MuniAddict General Unicycling Discussions 16 2007-08-08 10:18 PM
Copyright © 2001-2005 Gilby
Page generated in 0.10144 seconds with 11 queries
