Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2007-11-24, 04:42 PM   #1
penguini
My Unicycle Hates Me
penguini's Avatar
A few beginner questions
I have a few questions to ask. I've been learning to ride my uni for about 4 days now, with 2 hours each. I've managed to get used to getting on if I'm next to a wall, and can ride about 5 feet holding onto the wall before I have to stop (small porch).
My first question is would it be better to learn without the support of a wall? I've been trying to stop using the wall, but I seem to lean to the left every time if I don't (the wall is on the right ). I tried learning without a wall in the grass, but it was too hard to ride in the grass, and when I mounted I would just dismount since I wasn't moving at all.
I also want to know if it's good or bad that I'm holding onto the front of the seat with my left hand. I noticed this and tried to ride without my hand there, but the seat just slips out from under me and won't keep up.
And lastly, is there any particular order that is easiest for learning? Such as learn to freemount, ride, then idle? Or ride, freemount, idle?
__________________
(- Mac -)
penguini is offline   Reply With Quote
Old 2007-11-24, 04:47 PM   #2
ivan
Non-Danish Girl
ivan's Avatar
First of all, learn to ride both ways next to the wall. So you can ride with the wall on your left and with the wall on your right. Then start letting go of the wall while riding. Then start starting by holding on to something like a stop sign or the good old wall and riding off into the open from it. When you can ride about 10m on average, start freemounting.
Don't know about idling, I've been riding for one and a half years, I can do a 360 unispin, jump a five-set, up four pallets, but I still can't idle properly. I can do it, but I go all over the place when I do it. Not very cool. Then again, I've never practiced it.
Basically, just learn to ride and freemount and take it from there.
__________________
Did you know that lighter flame smells like burnt nose hair?
Entropy isn't what it used to be.
ivan is offline   Reply With Quote
Old 2007-11-24, 05:05 PM   #3
harper
768 - It's in your DNA
harper's Avatar
If you have to hold onto the seat to keep it from slipping out it sounds as if you are putting too much weight on the pedals and not enough on the seat. It sounds as if you're trying to stand on the pedals. Try to keep as much weight on the seat as possible at all times. Remind yourself to do this because the natural tendency when learning is to stand on the pedals.
You may also want to check your seat height. If it's easy to stand on the pedals it may be because your seat is too low. Your leg should be fully extended with your heel on the down pedal. That way it will be slightly bent at the knee when the ball of your foot is on the pedal. It's just like adjusting seat height on a bicycle.
I'm an advocate of no-support learning. That doesn't make it right, that's just my philosophy. I think it is detrimental to train yourself to depend on some form of support while learning. I recommend getting on, letting go, and riding away. Do this on a smooth, flat surface, not grass. Try to look into the distance, keep your weight on the seat, and make smooth, round pedal strokes. Try to ride until you fall. Don't chicken out and step off because you think you're going to fall.
__________________
-Greg Harper
JC is the only main man. There can be no other.
"Natural logs are what you ride on a Mun'e'." - kevinalexandersmith
harper is offline   Reply With Quote
Old 2007-11-24, 05:54 PM   #4
Probailer2
Say no to drugs!
Probailer2's Avatar
Does anyone knows the Roger Sanchez song "Here we go again" ?
Peter M
__________________
Sponsored by www.municycle.com
Quote:
Originally Posted by JJuggle
If somebody cloned your mother would you have sex with the clone? I should think not.
Quote:
Originally Posted by Danni
I don't like having penis written all over my uni .
Quote:
Originally Posted by manon1wheel
no offense but deads look plain old gross...
Probailer2 is offline   Reply With Quote
Old 2007-11-24, 06:46 PM   #5
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
I agree with everything that Harper said but would like to add "let go of that seat and flail your arms like a mad-man." The more limbs you have swinging about the easier it is for you to correct your balance. Don't worry about looking stupid, You're learning to ride a unicycle
__________________
Silly things cease to be silly when done by sensible people in an impudent manner. - Jane Austen
saskatchewanian is offline   Reply With Quote
Old 2007-11-24, 08:18 PM   #6
harper
harper's Avatar
Quote:
Originally Posted by saskatchewanian
Don't worry about looking stupid, You're learning to ride a unicycle.
Preach it, brother.
Also, try to familiarize yourself with the SEARCH feature. You should be able to dig up lots of past threads about learning to ride, seat height, service, and a variety of skills.
__________________
-Greg Harper
Reply
Tags
beginner, questions
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
beginner-type questions, i guess banjolick Rec.Sport.Unicycling 5 2007-07-30 12:04 PM
A few questions... SqueakyOnion Rec.Sport.Unicycling 4 2007-07-30 10:46 AM
Some Beginner Questions icon Rec.Sport.Unicycling 10 2006-01-12 05:59 PM
Some beginner questions Lewis W Beard Rec.Sport.Unicycling 8 2001-12-29 02:12 AM
Beginner questions... Spin Rec.Sport.Unicycling 4 2001-11-22 06:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.15817 seconds with 10 queries
