#16 |
I unicycle for Donuts
Hmm.... I wish I had more room, I have two Giant cable spools, and some 2x4's, my old bed frame, and a crappy ramp made with junk wood, an old grind rail from when I attempted to learn to skate, oh and a little seesaw thingy but I have no room to ride with all that stuff back there and some of it is too heavy to move on my own (the bed frame and the largest of the two cable spools) I'll try to get pictures of it all soon.
__________________
BUY MY SHIRTS AND STUFF WATCH MY VIDEOS Uniman Comics Original Thread for Uniman Sigged Quotes Last edited by Ducttape; 2007-09-18 at 11:58 PM. |
#17 |
Stupidity gets you 2 of these:
__________________
Ride everywhere and never just ride anywhere. If you can ride where you are going within a hour, do it, and if you can do a trick 50-75% of the time do it along the way.- Bob Burnquist What's next? Learn2Ride&doTricks TrialsClasses&Building |
#18 | |
Quote:
__________________
BUY MY SHIRTS AND STUFF WATCH MY VIDEOS Uniman Comics Original Thread for Uniman Sigged Quotes |
#19 |
THE original 12" Trials vid
__________________
www.voodoounicycles.com- The UKs only Extreme Unicycle Display Team I guess it's just a good thing you didn't include the footage of us snorting cocaine from the thighs of prostitutes eh Edd. - Boogie Last edited by Eddbmxdude; 2007-11-07 at 09:25 AM. |
#20 |
Registered User
I have 30-40 pallets and a cable reel and stuff which I often set up on my lawn as a pretty awsome trials corse. I dont have any pics but there are a few shots of me riding it in my video.
__________________
Marcus Collings *)---' my pure trials vid , 1mHighJump*my Year in vid learning 180 or 360 unispins? watch my unispin tutorial Want to glide? watch my ww tutorial |
#21 | |
Trialstreet Rider
Quote:
#22 | ||
I was searching through some old e-mails I sent to myself and found this from Andrew Carter's now defunct Unicycletips.com site:
Trials Obstacle BuildingTips Sandwich Boards Sandwich boards are probably the most versatile trials unicycling obstacle and are also very easy to make. They are light and portable, and in my opinion one of the most important elements of a good trials course. Materials 20mm (or more) thick sheet of wood 35x70mm (or similar) planks 50mm long screws 2 solid hinges Solid string or thin rope Wood glue Building Instructions Cut the sheet of wood into two identical bits that are preferrably almost twice as wide as they are high. A standard size is about 250x400. Cut the planks to the same width as the sheets. Place one plank on the long side of the sheet (70mm face down), glue it into place, then add at least 5 screws placed diagonally. Repeat for the other sheet and plank. Lay these pieces down flat, side by side with the planks together and facing up, and separate them about 5mm (maybe less if you?re using a smaller hinge). Place the hinges slightly in from the sides and mark where each hole is. Screw the screws (usually provided with the hinge) in loosely starting with the outer ones. Check the alignment of the hinges and planks. Tighten each screw. Drill two holes in each sheet in the two remaining bare corners. Make the holes only slightly wider than the string you have chosen. Open the sandwich board to your desired angle (around 60 degrees) and feed the string through the holes. Tie knots on the outer side of each hole making sure that the strings are equal in length. Cut off excess string and lightly melt the strings at the cut and also at the knot to prevent it from loosening. Ride on your new sandwich board. Applications - Gapping between sandwich boards at various heights and angles - Supports for planks and balance beams - A unicycle stand for running suicide mounts Practice Rails The handy thing about this type of practice rail is that it?s very portable. It allows you to move it around and also to change the length of the rail. This design uses the narrow face of a 35x70mm plank as the riding surface. It's not quite as challenging as a 2cm diameter round railing, but it's narrow enough that the rider has to focus on staying on top of the uni rather than moving the wheel side to side underneath them...more of a moving stillstand. This particular design is for a 5mx35mm rail that?s about 20cm above the ground. These dimensions can be easily changed to suit your preferences. Materials 35x70mm (or similar) planks, one 5m long 60mm long screws Wood glue Building Instructions Cut the planks into the following pieces: - 400mm pieces (4) - 300mm pieces (6) - 210mm pieces (10) - 160mm pieces (3) - 90mm pieces (2) - 5000mm plank to ride along Glue and screw together the pieces as in the diagram. Shown is the end support. For the middle supports, use the 160mm pieces in place of the 90mm pieces and have them extending all the way down. Also, attach the two 300mm pieces to the sides of the middle supports (in place of the 400mm pieces) so that they rest on the ground and face perpendicular to the 5m rail. Slightly sand or plane away the sides of the 5m rail where the supports sit if necessary. Place the two end supports and three middle supports on the ground in a line and fit the 5m rail in the slots. Give it a test ride. Note: The rail should sit approximately 20mm above the top of each support. This allows an uninterrupted ride along the rail. Applications This practice rail is perfect for improving your rail riding technique. It is low to the ground so that you can build confidence in your skill level and then move on to higher rails if you choose. Once you can ride all the way along, practise riding it slower and slower. This will force you to keep your balance longer and develop your still stands. Hopping Posts These are particularly challenging to use and therefore good to practise on because the landing surface is so small that the rider must concentrate strongly on his or her balance in all directions. If you land wrong on one of these (even if you don?t) it?s very easy for most of us to lose balance. Materials 35x70mm (or similar) planks 60mm long screws Wood glue Building Instructions Cut the planks into the following pieces: - 500mm pieces (3) - 300mm pieces (3) At the midpoint of one of the 500mm pieces, cut out a 35mm wide section that extends only half way across. Repeat for one of the other 500mm pieces. In the final 500mm piece, mark the midpoint and offset that line 35mm in both directions. Offset these new lines another 35mm and cut out similar sections as in step 2 between the outermost lines on each side. Place the two pieces from steps 2 and 3 in the slots you?ve cut so that the two planks are perpendicular to the third one. The slots of the connecting pieces should face each other to create a flush join 70mm high when sittingo n the ground. This is just a test to see if the slots have been appropriately cut. Extend any slots that aren?t cut deep or wide enough. Glue and screw together each of the three 300mm pieces and the 500mm one as shown in the picture. Start by joining two together with one raised 70mm. Then, join this to the piece with the two slots cut out of it. Finally attach the last 300mm piece. Be careful not to place the screws too close to each other. Finally, glue and screw the remaining 500mm pieces onto the third as mentioned. You may also want to screw these two pieces to the middle structure. Allow the glue to dry before using the obstacle. Applications - Gapping onto and off in trials lines. - Holding up narrow balance beams (with extra screws attached) Gapping Bars Gapping bars are generally used in the same way as sandwich boards (gapping between the tops of them) however they can be made to have a much smaller landing surface. The landing surface of these particular gapping bars is 35mm wide and also flat as opposed to v-shaped like the sandwich boards. The v-shape helps to catch the tyre and prevent it from rolling off, however this doesn?t happen in the case of the gapping bars. Gapping bars are great for training for really technical and narrow landings and are a lot of fun. Materials 35x70mm (or similar) planks 60mm long screws Wood glue Building Instructions Cut the planks into the following pieces: - 400mm pieces (2) - 140mm pieces (8) - Approx. 1000mm (1) Using one of the spare cut pieces as a guide, glue and screw two 140mm pieces to the side of the 400mm piece. Place the guide in the centre and secure the two pieces either side of it . When attached, they should snugly hold a 35x70 plank between them. You may need to place some more spare pieces underneath the two shorter ones for support while screwing them in. That way you can push down firmly on them with your foot and they will stay in place. Use two screws for each piece, inserting them on a diagonal. If you put the lower screw too close to the end of the piece it may split. Repeat for the opposite side of the 400mm piece, inserting the screws on the remaining diagonals (so they don?t hit the first set of screws). Again, use spare pieces to line up the angles correctly and support things while working. Throughout steps 2 and 3, keep checking the alignment of each piece. The final product should sit firmly on the ground and snugly hold the 1m bar perpendicular to it. Now that one support is done, repeat for the second. Allow the glue to dry, then place the 1m plank in the 35mm wide grooves and use your gapping bar. Build at least one more to get the most out of them. Applications - Really technical gapping - Long distance gapping to small landing surfaces, 180?s between them. - Holding up narrow balance beams in the groove. Northshore Structures From: http://www.unicyclist.com/forums/sho...328#post204328 Quote:
Quote:
__________________
#23 |
Vendetta Against Freestylers
well, heres what i got, it got a little cold for bare hand and a metal flashlight (-3 degrees F + bare hands = cold joints) but... Everything is covered in abou 1ft of snow at the least.
Every unicyclists dream for supplys ![]() and, my actual setup, its not much, and covered in a bit of snow
__________________
"I'll learn the landing once i do the takeoff" - me Sixsixone - Great gear for all riding!-My Videos Sprite Off Winner 08~ |
#24 |
well, a few of the pallets in the first pic are a little rotten and weak, but there are some more industrial pallets that will not break no matter what lol
__________________
#25 |
oh um also, the pic of those pallets i have, doesnt catch it very well, theres suposed to be like 2 rows of pallets, so its... about 40-60 pallets, in the least
__________________
#26 |
magic
whoah, it is so weird seeing pictures of snow.
#27 |
are you joking? because for me its normal lol.... All i need to do is go look out my window... or at my deck lol... well, yeah i guess, the pic of my set up wasnt too good, i was getting a little cold. Ive got too many pallets on my hands lol... And atleast a foot of snow to walk through to get to them/my trial setup
__________________
#28 |
and im bored
__________________
#29 | |
ONE for the...Off Road
Location: West San Fernando Valley, Southern California
Quote:
The site isn't defunct. It's still there under http://munimanpete.unicyclist.com/ I own the domain name, but there's something going on with it, and I haven't had time to look into it, until only recently. I hope to have it back to where the website comes up under unicycletips.com, within a couple of weeks. cheers.
__________________
Rod Wylie |
#30 | |
Quote:
http://www.unicyclist.com/forums/showthread.php?t=61833 Hear's some simple stuff, thanks to zfreek220 (don't know whose it actually is )
__________________
| Tags |
| courses, trials, unlimited |
Similar Threads
| Obstacle Courses in Chicago? | ackgot | General Unicycling Discussions | 3 | 2007-09-14 11:32 AM |
| trials courses | howdigetsogood | General Unicycling Discussions | 28 | 2007-02-20 12:14 AM |
| Unicycle Unlimited | paco | General Unicycling Discussions | 17 | 2003-11-18 07:42 AM |
| Unlimited 10K | Tim Ferry | General Unicycling Discussions | 0 | 2002-02-26 05:53 PM |
| Unicycling courses /workshops/riders in Surrey, England? | Mick.Whitehead@nmp.nokia.com | General Unicycling Discussions | 3 | 1999-05-22 06:21 AM |
