#1 |
Registered User
changing cranks
Are there any special tools needed to change cranks? I'm getting ready to put 127's on my N36.
Thanks, Marty |
#2 |
Unicycling = trials
look here. If its a stock N36 then it shoudlnt have isis cranks and so therefore look under "coterless"
http://www.unicycle.co.uk/FAQ.asp?iC...ParentID=33#97
__________________
I'm a soldja. |
#3 |
Dan Liew (UUU webmaster)
I assume N36 means Nimbus 36, which uses square tapered cranks if I remember rightly. You'll need a square tapered crank puller and a 8mm allen key/14mm socket wrench (depending on what sort of bolt you have on your cranks).
Here's a guide http://www.parktool.com/repair/readhowto.asp?id=103 . Note make sure you put the cranks on the correct side else you will have the pedals on the wrong side (they have different thread directions) which will cause them to undo when you pedal forwards.
__________________
Road, Muni, & Trials-> My first video http://www.youtube.com/watch?v=JeUyz9mfwI8 |
#4 |
Registered User
Thanks. Marty
| Tags |
| changing, cranks |
Similar Threads
| Changing your user name? | terrybigwheel | General Unicycling Discussions | 19 | 2006-08-07 09:46 PM |
| Changing to smaller cranks | innes | General Unicycling Discussions | 15 | 2005-01-24 10:43 PM |
| PW changing troubles | Tim | Requests, Questions, and Bugs on this site | 1 | 2005-01-05 08:22 AM |
| Changing a Tire? | Erin | General Unicycling Discussions | 2 | 2002-08-11 04:13 PM |
| changing the subject | Kris Holm | General Unicycling Discussions | 0 | 1999-04-08 10:10 PM |
