Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2007-07-30, 06:11 AM   #1
SqueakyOnion
<3 my Nimbus 29"
SqueakyOnion's Avatar
Send a message via AIM to SqueakyOnion
A few questions...
I'm a pretty new to unicycling. I've only logged a few hours on my uni, which is a Sun 20".
First of all, I adjusted my seatpost to where its comfortable, but it's a little bit (about and inch or so...) beyond the line that says "minimum insertion point"...what will this do to my uni if I keep riding it where I have it set?
Here's a pic...
Also, after about an hour or so of riding, my seat starts to move...it will start to creep farther in, shortening the distance between my bottom and the wheel. Also, the seat begins to twist side to side. Is it normal for this to happen, should I just keep tightening it?
I can't really do anything that would put too much stress on the frame, just riding in straight lines and turning so far.
My inseam is either 32, 33...not really sure which. The pants I buy are usually 34x32, so I assume my inseam is 32?
I'm 5'11" and weigh 160 lbs.
I decided that I love unicycling, and plan to buy a tougher uni in the not-too-distant future (Torker DX, p'aps). When I do, will I have to assemble it myself?
Thanks
__________________
"The pleasure of what we enjoy is lost by wanting more." - Fortune Cookie
"In order to reform the world, we must first reform ourselves."
SqueakyOnion is offline   Reply With Quote
Old 2007-07-30, 06:41 AM   #2
torkerdx
to tire-3ft.
torkerdx's Avatar
Here's a pic...
Thanks
for all you are doing all you need is 2inches in the seat tube(frame)
yeah you ride with a quick release so just tighten the sucker down as much as you can.
with a new uni (unless you go custom(which the DX is not)) you have to put on the pedals, put the frame on the wheel, and the seat post into the seat tube. all you need is a 4 and 5 mm allen, and a 15mm wrench (assuming you get a dx
__________________
Quote:
Originally Posted by gordito8me
it's like running across the highway at rush hour. Dangerous, stupid, but not really that fun.
Quote:
Originally Posted by skianduniaddict
never give 4 teenagers a camera... they go crazy
Quote:
Originally Posted by johnfoss
Yes, being old makes you stupid.
torkerdx is offline   Reply With Quote
Old 2007-07-30, 07:55 AM   #3
BYZA
bloody *****istrators ignoreing me
BYZA's Avatar
Send a message via MSN to BYZA
so is it too uncomfortable to have the post that touch lower?
just tighten it as much as you can
and yes you will have to do some assembly, but unless you start to lace up a wheel, a unicycle is a very simple mechanism, i am sure you would be able to work it out by looking at one that is put togeather.
__________________
improving each day
CRANKFLIP CHAMPION!! 1st place
)---'O, Crankflip
latest vid Roll it, Roll it! http://www.youtube.com/watch?v=GB1nFn_OZx4
Street Dog (my older vid) http://www.youtube.com/watch?v=ijM6vbhc5xs
Byza_dog@hotmail.com thats my msn right there
BYZA is offline   Reply With Quote
Old 2007-07-30, 08:43 AM   #4
sp4rky-m4rky
Registered User
sp4rky-m4rky's Avatar
Send a message via MSN to sp4rky-m4rky
Your 19 and you are concerned about that and dont know how to resolve it? That is worrying, does noone else think the same?
I know we should be nice though so WELOME TO THE FORUMS
__________________
Marcus Collings
*)---', 1mHighJump*
my pure trials vid
my Year in vid
learning 180 or 360 unispins? watch my unispin tutorial
Want to glide? watch my ww tutorial
sp4rky-m4rky is offline   Reply With Quote
Old 2007-07-30, 10:46 AM   #5
kington99
Registered User
Send a message via MSN to kington99
The reason your post moves around is a combination of not having enough post in the frame, and not having the clamp tight enough. If you get the clamp as tight as possible and it still happens then just buy a longer seatpost, they're not expensive, very easy to change and will solve your problem.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Reply
Tags
questions
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
a few questions Ricky W Rec.Sport.Unicycling 3 2006-08-26 02:59 AM
More questions Krashin'Kenny Rec.Sport.Unicycling 7 2003-01-29 08:12 PM
thunder dragon questions (well questions) bagpiperboy Rec.Sport.Unicycling 12 2002-06-21 10:58 PM
Hello/Questions Raymond Flaming Rec.Sport.Unicycling 3 1995-03-16 02:59 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.24600 seconds with 10 queries
