#1 |
the unicycling penguin
Funny noise
There is a funny sound when my cranks reach a certain loction. Not quite a click, more of a low vibration that is very annoying and felt only on the right pedal. Is this pedal too tight/loose on the cranks or something?
__________________
,¸¸,ø¤º°`°º¤ø,¸¸, °º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º° °`°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸, ø¤º°`°`° °º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º° ,¸¸,ø¤º°`°º¤ø,¸¸, |
#2 |
addicted.
I don't know what it is but you're not alone. My 20" does that. I think it's when the right foot is around the 4 o'clock position.
I think "donk" is the most phonetically suitable description for the sound. It feels like it's in the pedal but I'm not totally convinced. I put it down to having a crappy noname uni that got worn out by a couple of months of heavy learning use. |
#3 |
King of Carnies
It could be loose spokes, loose cranks, or loose pedals.
Tension/true up your spokes, tighten your cranks or just give it a bit of torque, and check your pedals, that should get rid of the sound, usually. If its more of a grinding gritty sound, your bearing probably are dirty and have stuff grinding in/on them, or they are dry and need some lube on/in them. |
#4 |
Nh... it's definately a doink sound, felt through my feet rather than ear (if that makes any sort of sense. My unicycle is new.
__________________
#5 |
Totally Doable
My guess would be either a loose crank or loose pedal bearings. Can you move the pedal back and forth on the axle? Can you wiggle the crank by hand?
| Tags |
| funny, noise |
Similar Threads
| Maguras and Airfoil noise? | iridemymuni | General Unicycling Discussions | 32 | 2007-03-20 07:58 AM |
| Noise when I pedal | monkeyman | General Unicycling Discussions | 3 | 2006-03-13 04:33 AM |
| Noise from the wheel? | ChangingLINKS.com | General Unicycling Discussions | 10 | 2005-03-13 03:56 AM |
| weird noise | mfrobert | General Unicycling Discussions | 1 | 2005-01-02 04:48 PM |
| A quite strange clicking noise.. | lleberg | General Unicycling Discussions | 9 | 2004-11-23 06:13 AM |
