Unicyclist Community
Reply
Old 2007-06-09, 02:51 AM   #76
onelesscar
I get places on 75% fewer wheels
onelesscar's Avatar
okay...i apologize for my previous post...
just seems like you were making a really big deal out of it earlier, but if you've found a way to work with the situation, that's awesome.
__________________
Catching the coker fever.
onelesscar is offline   Reply With Quote
Old 2007-06-09, 02:57 AM   #77
MuniAddict
Not "2" Tired
MuniAddict's Avatar
Thanks man no worries I just really want a 36-er, and I guess I'm just tired of waiting and not having one. Actually, a friend has been nice enough to let me borrow his extra, but I can keep imposing and not feel guilty about it. I just really want my own, even if it might not work out, at least UDC will take it back. Ive gotta simply face facts; I've got coker fever...and the only prescription, is more cowbell!!! Eh...wait that's not right...haha! http://www.youtube.com/watch?v=UpwfJ9zJ7Qc
__________________
My latest TV segment
UniGeezer.com
My videos
MuniAddict is offline   Reply With Quote
Old 2007-06-09, 03:02 AM   #78
idiorythmic
Oddistic
idiorythmic's Avatar
Quote:
Originally Posted by john_childs
I was very doubtful that a tube with thin sections could herniate and blow off a tire. But I added that possibility anyways. In the ideal world of physics analysis the pressure inside a tire is equal in all places and areas inside the tire and never localized. The pressure at the contact patch is not greater than the pressure anywhere else in the tire.
Quote:
Originally Posted by MuniAddict
How about this scenario. Maybe when/if the tube blows *during* riding, the sudden loss of air pressure, in addition to the wheel rotating with your weight on it, can cause the tire to slip off the rim. Maybe these two events happen so quickly in sequence that it *seems* like the tire is blowing off first. Just a thought.
I thought of a possible scenario: perhaps - if there is a thin spot in a tube - it can fold over upon itself as the tube/tire combination flexes with each contact with the ground. I can imagine as the tire flexes and returns to normal shape with each revolution that a thin spot on a tube could peel or fold or otherwise shift around, causing a tear, sudden pressure loss, and (as Terry describes), wheel rotation and rider momentum can twist the tire off the rim.
idiorythmic is offline   Reply With Quote
Old 2007-06-09, 03:09 AM   #79
idiorythmic
Oddistic
haha, I know the feeling. That's why I had to get one too...(I opted for the steel rim version because I'd rather wait until airfoils and tires are standardized before upgrading.)
Old 2007-09-05, 10:10 PM   #80
saskatchewanian
ERIC P
saskatchewanian's Avatar
Send a message via MSN to saskatchewanian Send a message via Skype™ to saskatchewanian
about 10 min into my first ride the tire unseated itself and jamed on the frame. I promptly got (fell) off the uni and let the air out of the tube before the tube could herniate and blow out. I put the tire back on, was very carefull to seat it evenly when I re-inflated it and have had no problems since.
I ride my 36er almost exclusively on ATV, Snowmobile and hiking trails but have taken it to a skate park where it held up to 2 foot drops better than I did.
I do not believe that I have a faulty tube but had the tire seated improperly when I first got my cycle. The tire/rim fit may be a bit loose but if seated properly it should not be too much of a problem.
I say check to make sure your tire is evenly seated and you sould be fine.
ERIC
__________________
saskatchewanian is offline   Reply With Quote
Old 2007-09-05, 11:14 PM   #81
onelesscar
onelesscar's Avatar
For me a bigger problem than an unevenly seated bead was the tube getting caught under the bead, since the tire fits so tight on the rim. When the tube would get stuck under the bead, it was difficult to
(1) Figure out where it was stuck before it started to bulge
(2) Squish the tire back under the bead to fix it.
Given this, I can believe that it was a tube problem during the "scandalous period" , and from now on, I'm going to talc my tubes before installation to make them slip under the bead more easily.
__________________
Old 2008-01-11, 01:02 PM   #82
MrBoogiejuice
Now with added jazz croutons!
MrBoogiejuice's Avatar
Send a message via Yahoo to MrBoogiejuice
Has anyone suffered any more blow outs since receiving these new, non-faulty tubes?
I ask because last week I had another blow out, this time at about 38 psi and while off the uni having just pumped it up which leads me to doubt the faulty tube theory.
It really seems to me that the obvious answer is that rims are simply slightly too small. Getting the TA tyre on and off this airfoil is really very easy, certainly the easiest tyre to install/remove that I've ever come across.
Also, I'd like to hear from someone independent who has the means to accurately measure an older Coker tyre and a new one. It seems unlikely to me that Coker would suddenly decide to change the size of their tyres when there's been no problems with it.
I've spoken with Roger about this recent blow out and have been offered a replacement tube and TA tyre at half price but I'm not keen on the idea of spending more money if within twelve months I'm going to have to replace them again.
It could be that the tyre bead was damaged after the first blow out I had and allowed the tyre to slip off more easily this time. The bead is now quite noticeably misshapen around where the blow out happened this time.
It's all just rather frustrating having no definitive answers yet so many theories as to what's going on. I just want a unicycle I can inflate to the point I find comfortable to ride with without being afraid of it exploding. It's not much to ask after spending so much on a supposedly superior product is it?
__________________
---unicycle for The Very Hungry Caterpillar---
Make crumbs not War!
You can't polish a turd but you can roll it in glitter.
MrBoogiejuice is offline   Reply With Quote
Old 2008-01-11, 01:18 PM   #83
scotthue
10k & Marathon World Champ
scotthue's Avatar
Send a message via Skype™ to scotthue
take it apart and check for rim tape, also see this http://www.unicyclist.com/forums/showthread.php?t=65133 (the Nimbus 36er SE and Airfoil rims are very similar) I the end I had to file down the burs on the inside of the rim and get rim tape, no problems since then (about 4 mounths)
scotthue is offline   Reply With Quote
Old 2008-01-11, 07:46 PM   #84
MuniAddict
Not "2" Tired
MuniAddict's Avatar
So far so good here. I've used my 36er for long distance as well as 4' drops and other unconventional stuff on a big wheel, and no problems at all; and i routinely run 40 psi!
__________________
UniGeezer.com
My videos
Reply
Tags
excellent, john, talk, udc
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My T7 handle isn't fitting on my coker. habbywall General Unicycling Discussions 9 2007-05-18 11:48 PM
T7 handle is excellent. Brian O. General Unicycling Discussions 19 2007-05-16 01:31 AM
An excellent visit to unicycle.com Phuni General Unicycling Discussions 2 2004-05-25 02:44 AM
Photo Album from John: Some John Foss UNICON photos are now online jfoss@unicycling.com General Unicycling Discussions 9 2002-08-17 12:31 AM
John Drummond on NPR's Talk of the Nation John Hooten General Unicycling Discussions 3 2002-07-23 03:49 AM
Copyright © 2001-2005 Gilby
Page generated in 0.09574 seconds with 10 queries
