Unicyclist Community
Reply
Old 2007-02-24, 07:31 PM   #1
pinefresh
ɹǝsn pǝɹǝʇsıƃǝᴚ
pinefresh's Avatar
Tire removal for wheel build
I have a new hub now and am wondering if you must/should take the tire off to rebuild the wheel. Oh and this is a trials uni by the way, with a dx 32 rim.
pinefresh is offline   Reply With Quote
Old 2007-02-24, 07:34 PM   #2
koebwil
Registered User
koebwil's Avatar
You couldn't do it with the tire on, you need to be able to twist the spokesand install the nipples I think. It really isn't that hard to take off the tire.
__________________
"I used to eat erasers in grade school...." James_Potter
come to my gallery.
I'm on my space now too
koebwil is offline   Reply With Quote
Old 2007-02-24, 07:35 PM   #3
thejdw
elcycinu
thejdw's Avatar
Send a message via MSN to thejdw
(post outdated by new post)
__________________
I didn't spell it wrong, you just read it wrong!
thejdw is offline   Reply With Quote
Old 2007-02-24, 07:38 PM   #4
kington99
Registered User
Send a message via MSN to kington99
No you must remove the tyre, you need to get to the backs of the nipples to install the new spokes. Also it makes it easy to see how the rim is running, and what adjustments need to be made. It only takes a few mins compared to the several hours you're giong to spend building the wheel.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2007-02-24, 10:42 PM   #5
skrobo
jumps stuff
skrobo's Avatar
Send a message via AIM to skrobo
ugh
retarded
of course you do
THINK
come on now, seriously...
ok now that I'm done being a jerk.
technically you DON'T have to if you use the same nipples, but thats dumb too.
pain in the rear
what exactly are you lacing to what?
you will get help with whatever you need if you just ask.
__________________
><> Unicycle For Christ <><
MY VIDEOS
World Record
94cm Highest Hop (rolling)
308cm Longest Hop (10 feet)
210cm Static Flat Gap
skrobo is offline   Reply With Quote
Old 2007-02-25, 04:22 AM   #6
GhettoSmurf
Registered User
Send a message via AIM to GhettoSmurf
ok in all honstey.
if you cannot take off a tire
you are NOWHERE near being able to build a *decent* wheel.
please. just take it to your bike shop. it will be worth it. dont be cheep.
GhettoSmurf is offline   Reply With Quote
Old 2007-02-25, 06:29 AM   #7
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
I'm assuming you are talking about putting a splined hub onto a Norco trials or Bedford light duty. This would mean you have a luna tire and a DX 32 rim which means it will be a big pain in the ass to get that tire off, not to mention get it off without damaging the rim. I would recommend you get some good PLASTIC tire removal tools. Metal ones will without a doubt damage your rim. Make sure they are good tire tools though otherwise I guarantee they will snap, this is probably the hardest tire/rim combo to disassemble/reassemble so you need something of good quality.
To take the tire off you may actualy want three of them. What I do is deflate the tire, put one tire lever under the bead of the tire and lift it over the sidewall of the rim, then I jam it in there so it won't move, then I take another tire lever and I do the same thing about 4-6 inches down from the first one. Now take your third if you have one and stick it about 4-6 inches from the second one and do the same, now you will have a loose one in the middle of the two, take that one out and repeat the process until you have the whole side of the tire off. Now do the same thing for the other side of the tire. It isn't that complicated just takes a bit of elbow grease and time.
If you don't have three tire levers then once you have both of your tire levers in slide them outwards from eachother if you can, if you can't then take a strong plastic pen and stick it inbetween the two tire levers then move it next to one of them so that you can take it out and use it a bit further from the pen. Always keep the pen in the middle though as it will be the weakest part and most likely to either break or come out.
Like the others said though, if you can't/don't know how to get the tire off I would highly recomend having it built by a bike shop. If you shop around you should be able to get ahold of the right shop that will do it for next to nothing. I get my wheels built for 40 bucks including new spokes, which although it sounds alot is really cheap because they are custom cut spokes. Last time they had to cut about 7 sizes of spokes because my rim is bent a tiny bit. This kind of thing cannot be done at home even if you are a really good wheelbuilder.
Wheelbuilding is a skill, something that takes alot of time to learn and perfect, learn other bike maintenance skills first before you build wheels.
I don't want to come off as rude, so hopefully you find this helpful.
ntappin is offline   Reply With Quote
Old 2007-02-25, 06:34 AM   #8
Jerrick
King of Carnies
Jerrick's Avatar
Send a message via MSN to Jerrick
DX32 rim is such a hassle to get a tire off of....
I would recommend doing it though, it will make the whole re-trueing and everything easier and better.
__________________
Just bumming around MR~~~~~~~~~Team Forrest~~~~~~~~~Team Dirty Bird!~~~~~~~~~~~~~~~
Check out my Band.~~~~~~~~~~~~~~~!Quack!~~~~Team Spencer!~~~Member of the MRIS.
Want some advice? Do better.
~Jerrick
Jerrick is offline   Reply With Quote
Old 2007-02-25, 09:09 AM   #9
kington99
Registered User
Quote:
Interesting that seems to be the consensus, I presume you're talking about 19" here? I use to have a 24" DX-32 and getting the tyre off was a piece of cake, I guess you have less room to play with on a 19" rim.
What ntappin said about good quality plastic levers, heed his words, I refitted a wheel TA yesterday wth some brand new (but cheap) plastic levers, snapped one and cut my hand open. Finished the job with my trust 30 year old steel levers, but was lucky not to mark the rim.
__________________
Dave
Old 2007-02-25, 09:14 AM   #10
Jerrick
King of Carnies
Jerrick's Avatar
Quote:
Yeah, I should of mentioned it was for the 19" rims.
__________________
~Jerrick
Reply
Tags
build, removal, tire, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Wheel build specs??? unichomp General Unicycling Discussions 2 2006-07-11 05:21 PM
Wheel Self Build by n00b recycled General Unicycling Discussions 10 2005-07-11 05:59 PM
Wheel removal with Magura HS-33 brakes mgrant General Unicycling Discussions 7 2004-04-09 04:50 AM
How NOT to build a wheel mike.hinson General Unicycling Discussions 5 2004-03-06 11:30 PM
how to build a wheel ? tandys General Unicycling Discussions 2 2001-05-07 10:58 AM
Copyright © 2001-2005 Gilby
Page generated in 0.10706 seconds with 10 queries
