Unicyclist Community
Reply
Old 2007-02-19, 12:24 AM   #16
Borgschulze
2 Wheel Traitor
Borgschulze's Avatar
Send a message via MSN to Borgschulze
Quote:
Originally Posted by musketman
I know there's 2 different lengths you can buy this axle, but I dont remember what they were. But Im pretty darn sure it's the same as "our" profile axle length. If it didn't work, Profile has a titanium spindle that would work anyway if you wanted to change it out. Im also pretty sure both of the spindles (Eastern Bikes, and The Profile Ti spindle) have that key slot in them.If you look at the above picture it has to have a slot in it anyway for that bike hub piece to fit on without slipping. The pictures just dont it. Ive read reviews, and they all say the Eastern Bikes 48 spline stuff above all fits with profiles stuff. It should all work.
Or it could be pressed on.
That metal piece around the spindle doesn't really have to turn, if it's pressed on it's fine.
__________________
Gravity is not the issue.
Borgschulze is offline   Reply With Quote
Old 2007-02-19, 03:35 PM   #17
musketman
Registered User
musketman's Avatar
that's true. but I think you are right about the spindle length. Ive looked at other Titanium spindles, and they either come in 5-3/4 or 6" lengths. Our unicycle spindles are like 6-7/8". So I take back what I said. I dont think these Titanium spindles will work in "our" profile hubs, but the cranks should still work.
__________________
Musketman
www.unicycle.com
For Sale: Parachute, only used once, never opened, small stain
kissing isn't what keeps me up to my elbows in placenta all day long...
musketman is offline   Reply With Quote
Old 2007-02-19, 08:40 PM   #18
jagur
My Uzi is a Tongue
jagur's Avatar
Has anybody looked at these?.... DISCUSS...
Yes! back in early 2002
http://www.unicyclist.com/forums/sho...=titanium+axle
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
twitter> @shot of jagur
jagur is offline   Reply With Quote
Old 2007-02-20, 01:38 AM   #19
gerblefranklin
Registered User
Has anybody looked at these? I did some searching for [B]They look pretty sweet aswell
So for all who want to overhaul your Profile hub and cranks, and make your rig much lighter. Giv-it with these! You'll shave off 2.7 lbs! If you have a profile hub and cranks in already.
The final price of this axle and cranks = $440 U.S. Not terribly expensive, but up there. I really want a pair. The bad part is, if you did break them you lost alot of money. But they are Titanium, so they should be pretty strong. And from the few reviews I saw it was nothing but good. They appear to be thick enouph to take abuse without snapping like some other Ti cranks have in the past.
Yeah, because titanium is strong... just on principle? Companies profit like mad off of bikers because none of them know squat about what they're buying. Unicyclists are the same. Here are some hard numbers from the back of my Engineering Mechanics textbook: Ultimate tensile strength of titanium, annealed: 155 ksi. Elastic tensile strength of titanium: 135 ksi. For comparison, here are the same stats for 18-8 cold rolled stainless steel, 190 ksi and 165 ksi, respectively. The modulus of elasticity for titanium is 14000 ksi, while the 18-8 stainless is 28000 ksi. My point is that titanium is NOT strong on principle, and you would be a fool to make the inference that you made.
Titanium, per unit volume of material, is significantly weaker than many steels and other materials. A strong "looking" crank does not make it actually strong (what if it's only 1/64" thick walls?). One problem with titanium is that it is less than 1/2 as rigid as the same volume of steel, so it will flex and fatigue faster than steels.
Whatever though. If you want to blow $500 on some PARTS for your unicycle, by all means do. I can see about 200 things that would bring more enjoyment to my life than that for less money. You need to remember, you are in this sport for ENJOYMENT, not the highest hops or fastest rides. Would 2-lb lighter cranks actually make riding that much more fun for you? I'd rather blow that money on 10 trips to Northstar or 3 trips to Moab.
My point is, if your unicycle works, close the freakin' web-store pages and go out and ride. If not, get it working and then spend your hard-earned cash on something more worthwhile.
gerblefranklin is offline   Reply With Quote
Reply
Tags
axle, cranks, spline, titanium
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WTB used DM Engineering 150mm 8-spline cranks G Lykos General Unicycling Discussions 14 2006-12-24 05:33 AM
WTB: DM Engineering 150mm 8-Spline Cranks GLykos Trading Post 2 2006-12-23 08:27 PM
8-spline cranks on ebay manic_mark General Unicycling Discussions 0 2003-12-27 07:35 PM
Long Cranks and Hub/Axle Failures UniBrier General Unicycling Discussions 0 2003-03-25 03:20 PM
cranks+ suzue= stripped axle? unibrow General Unicycling Discussions 2 2003-02-20 05:35 AM
Copyright © 2001-2005 Gilby
Page generated in 0.06624 seconds with 11 queries
