Unicyclist Community
Reply
Old 2007-02-12, 02:30 AM   #16
joemarshall
dumb blonde
Quote:
Originally Posted by maximus unius
Can you use other frames with the hub? I would assume not, because of the way it bolts down at the bottom...
Possibly with some modifications.
The bolt thing and fitting you can take out of the original frame, so could drill into a different frame for it. I don't know if you can get them without buying the frame though.
The harder bit, is that the inner side of the bearing holder on that side needs to not have a lip, and most frames have lips on the bearing holders. You might just be able to grind away the inside lip on the bearing holders to fix this.
The new hub should fit on any frame without that lip, or where the lip has been grinded off, and won't need the bolt bit.
Joe
joemarshall is offline   Reply With Quote
Old 2007-02-12, 02:38 AM   #17
Hazmat
Too insane to be considered human.
Hazmat's Avatar
Maybe someday i will have one but not now. The reason being it would cost me $2,243.73 to have one as you can see here.
__________________
I'm 1 weird and unusual Greek Cypriot Australian with a pienormous heart.
Can't wait till this game is finally released.
Hazmat is offline   Reply With Quote
Old 2007-02-12, 02:39 AM   #18
joemarshall
dumb blonde
Quote:
Originally Posted by Hazmat
Maybe someday i will have one but not now. The reason being it would cost me $1,149.76 to have one as you can see here.
the 890 is in £, which are worth more than US $.
So I'm afraid it'd be 2231 Australian Dollars.
Joe
Old 2007-02-12, 02:42 AM   #19
Hazmat
Hazmat's Avatar
Joe
Yeah i just saw which is why i changed it to £ on xe.com. As you can see now. But thanks for the heads up friend.
__________________
Old 2007-02-12, 04:35 AM   #20
GhettoSmurf
Registered User
Send a message via AIM to GhettoSmurf
for changing the seat height on the frame why couldnt you cut the seattube(/seatpost) and shim a smaller seatpost to fit inside of the old one. then you could adjust the height normaly.
GhettoSmurf is offline   Reply With Quote
Old 2007-02-12, 08:10 AM   #21
brendan
Unicycling = trials
brendan's Avatar
lol not without a seatpost clamp, and i'm guessing u cant adapt those very easily
brendan is offline   Reply With Quote
Old 2007-02-12, 08:35 AM   #22
joemarshall
dumb blonde
Quote:
it's only 25.4mm, which means that you'd have to use 1.6mm tubing and fit a 22.2 seatpost inside. Which would be a bit rubbish.
Joe
Old 2007-02-12, 05:06 PM   #23
kington99
Registered User
Send a message via MSN to kington99
Joe
I understand florain doesnt sell the hubs on their own specifically so people cant try and bodge them on to different frames. The force in the torque arm is enormous, the schlumpf frames have a boss welded in to them to deal with this, just drilling a hole thorugh say a nimbus frame and bolting would not be a good idea. I modified a Qu-Ax penny farthing to accept a schlumpf wheel, you can grind down the inside of nimbus style pressed steel bearing housings quite easily. However even a half dozen thick cable ties couldn't hold the torque arm for very long.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2007-02-12, 07:57 PM   #24
joemarshall
dumb blonde
Quote:
It's not a welded boss, at least on the current frames, it's a big old bolt plus some great big washers, the whole boss can just be unscrewed (you do to to change the wheel). I don't know what the part is called, but if they're not custom, you could just buy the bolts yourself and drill the right holes yourself. There's a different sized hole on each side of the frame and you'd have to make sure to get the holes perfectly straight, but there's no welding involved.
Joe
Old 2007-02-12, 08:06 PM   #25
kington99
Registered User
Joe
Ah, we're talking about different schlumpf frames I think. Incidentally I heard rumour at one point that the hole drilled in the web on nimbus 36 frames was for the schlumpf torque arm bolt, but this may well have been speculation rather than fact.
__________________
Dave
Reply
Tags
expensive, schlumpf, udc, uni
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Kris Holm Unicycle Missing on UDC! unilaura General Unicycling Discussions 12 2011-09-17 06:55 PM
UDC Mistake =( adam.mc37 General Unicycling Discussions 18 2007-01-24 06:30 PM
UDC hub and cranks uni4life_13 General Unicycling Discussions 1 2006-12-22 10:35 PM
Coker, Schlumpf 29er, or Schlumpf 36er siafirede General Unicycling Discussions 9 2005-11-11 11:37 PM
Copyright © 2001-2005 Gilby
Page generated in 0.13532 seconds with 11 queries
