Unicyclist Community
Reply
Old 2007-02-08, 07:30 PM   #31
cathwood
Life's a beach
cathwood's Avatar
Sorry to be a bit dense. but what does being part of the KHU factory team entail?
__________________
Cathy
cathwood is offline   Reply With Quote
Old 2007-02-08, 07:44 PM   #32
danger_uni
Kris Holm
Quote:
Good question. The simplest answer is that KHU provides a bit of support to help these riders do the thing they do best- ride- without having to worry so much about the cost of equipment. In exchange, I hope that they will help grow the sport through inspiring others to ride, and hopefully that will be good for business.
The more complicated answer is- what do companies (not just KHU) look for in a sponsored rider? After 10 years of sponsored riding I could talk for a long time about that but the main things are:
1) Riders who are motivated to ride because they love to ride and are good at it. Riding is the objective, and while sponsorship helps with this, getting sponsored isn't a goal unto itself for these people.
2) Riders who are good with people and who are good communicators through media, demos, or any other way of getting the word out about our sport. Being a good rider is only 50% of pro-riding, maybe less.
3) Riders who actually like KH gear- no fake promotion here.
Cheers,
Kris
danger_uni is offline   Reply With Quote
Old 2007-02-08, 07:48 PM   #33
Danni
Daniel Cormeau
Danni's Avatar
I was wondering when the KH geared hub would come out and how much it would cost.
Still can't believe I'm talking to Kris Holm!
You were the one who got me into this!
Danni is offline   Reply With Quote
Old 2007-02-08, 07:55 PM   #34
danger_uni
Kris Holm
The geared hub R&D is back in action after some delay regarding other products that Schlumpf produces. The other reason for the delay was that the shifter was redesigned and some details had to be worked out with regard to that. We're working on it and hope to have something out for Spring, although considering how long it has taken I won't promise anything. We want to get it right the first time!
No details yet on cost but the complete uni will be probably on the order of about $1600.
Kris
Old 2007-02-08, 07:58 PM   #35
Danni
Daniel Cormeau
Danni's Avatar
Would the hub be compatible with any of your frames? I was going to just buy the hub and put it on my KH24 06. How much would the hub be by itself?
Old 2007-02-08, 08:00 PM   #36
brendan
Unicycling = trials
brendan's Avatar
spring... uhm that would be awesome
$1600...... how much for just the hub or is that question abit too precise to be answered?
ahaha my question was just asked... never mind hey some people are just too quick for me!
brendan is offline   Reply With Quote
Old 2007-02-08, 08:11 PM   #37
danger_uni
Kris Holm
Quote:
I don't have a price yet on just the hub but considering that the rest of the uni is the same as a standard KH uni, you can get an idea from that.
The hub will fit any KH frame sold after Fall last year. However, all of the blue alloy frames sold before that can easily be modified to fit. The only requirement is that the inside (closer to the flange) lip of the bearing housings must be 2mm high or less. The older KH frames had a 4mm lip on the inside, but you can just take a grinder and grind it off. Just the inside lip, not the outside lip. It doesn't have to be exactly precise- just 2mm or less.
The hub does not require a bolt in the fork blade for a lever arm, which is required by the current Shlumpf geared hub.
Kris
Old 2007-02-08, 08:14 PM   #38
Danni
Daniel Cormeau
Danni's Avatar
Would the hub be strong enough for 6+ foot drops for muni? Would it take the abuse that a normal KH hub would take?
Old 2007-02-08, 08:40 PM   #39
danger_uni
Kris Holm
The hub has held up well (no damage at all) on some pretty agressive riding on the Vancouver North Shore, including 5-6 foot drops onto transitions. However, it does contain moving parts and in the long term riding agressively with lots of big drops could make it wear out faster. Also, although it hasn't broken yet I probably wouldn't do big drops to hard flat ground- it does cost a lot after all and hard abuse is what the fixed hub is for. If I was to go for a ride that was really technical and had a lot of big drops, I'd probably take the regular fixed hub. If I did a lot of all-around XC and freeriding and was willing to be a little more careful with rolling out properly on drops, then the geared hub should be good.
Kris
Old 2007-02-08, 09:19 PM   #40
thieum
Tee-Um
thieum's Avatar
1600$, I assume these are Canadian dollars, not US dollars, right ?
thieum is offline   Reply With Quote
Old 2007-02-08, 09:29 PM   #41
DustinSchaap
Eenwiel.nl
DustinSchaap's Avatar
Send a message via MSN to DustinSchaap
Quote:
I'd say it sounds about right in US dollars, the work Florian has on the normal Schlumpf hubs is mostly handwork, I can imagine the development of the new KH/Schlumpf hub has cost quite a lot and I doubt they will be mass-produced. My only worry is that Kris might be using it at FLUCK this year Back to topic! This isn't about the new geared KH but about the team of awesome riders sponsored by KHU, I wonder if Kevin is still sponsored by GB4?
__________________
QU-AX | MUNICYCLE.COM | EENWIEL.NL
Life is a beach, and then you die
DustinSchaap is offline   Reply With Quote
Old 2007-02-08, 11:18 PM   #42
zfreak220
Polska Możność
zfreak220's Avatar
Quote:
maybe we'll start seeing some reeders and stiffener plates for kh seats.
zfreak220 is offline   Reply With Quote
Old 2007-02-09, 12:31 AM   #43
mornish
magic
Send a message via ICQ to mornish Send a message via AIM to mornish Send a message via MSN to mornish Send a message via Skype™ to mornish
Quote:
kh seats have stiffener plates...
mornish is offline   Reply With Quote
Old 2007-02-09, 12:33 AM   #44
zfreak220
Polska Możność
zfreak220's Avatar
stronger ones. i always hear people are snapping them.
Old 2007-02-09, 10:32 AM   #45
wobbling bear
GranPa goes-a-wobblin'
wobbling bear's Avatar
though I am not a talent spotter I wanted to say that I spotted at UNICON
a really talented Muni Girl : a diminutive danish girl (whose name is Gallina I think). Did other persons noticed her?
__________________
One Wheel : bear necessity
wobbling bear is offline   Reply With Quote
Reply
Tags
2007, factory, khu, team
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
new khu products skianduniaddict General Unicycling Discussions 40 2007-02-04 07:49 PM
Retirement from Norco Factory Team danger_uni General Unicycling Discussions 8 2007-01-05 02:00 AM
Announcing the 2006 Kris Holm Factory Team danger_uni General Unicycling Discussions 40 2006-02-08 05:17 PM
New unicycling team: Team Primitive Jester2000 General Unicycling Discussions 4 2005-03-02 10:07 PM
Bedford Factory Team rocks Bradford Festival Darren General Unicycling Discussions 2 2003-08-25 06:08 PM
Copyright © 2001-2005 Gilby
Page generated in 0.12611 seconds with 10 queries
