Unicyclist Community
Go Back   Unicyclist Community > Unicycling Discussion > Unicycling Articles and Tutorials
Reply
Old 2006-12-18, 02:51 AM   #1
unirox13
Unicycling Ninja!
Send a message via AIM to unirox13
back pedal woes!!
ok im having trouble doing pedal grabs and going to rubber, i can do crank grabs to rubber most of the time but they're still kinda sloppy. so here's my question, my jumping position is right foot back left foot forward with my left hand on the handle and i jump to the right so i use mny back foot for everything. in most of the videos i watch whenever someone does a pedal grab they use they're front foot, does that make any difference at all???
__________________
The World is on fire, are you the smoke, or the flames?
unirox13 is offline   Reply With Quote
Old 2006-12-18, 04:20 AM   #2
bcwheelriderguyhehehehehe
Unicycle for donuts(hehe, yay!)
bcwheelriderguyhehehehehe's Avatar
You ride weird But really I don't think it make much of a difference. Like when ever I crankflip to a crank/pedal grab I land with my right(back) foot. And I don't find going to rubber very hard. It might just be that you are still getting used to pedal grabbing. Cause if you can crank grab alright the pedal grab will just come later I suppose.
__________________
Quote:
Originally Posted by Borgschulze
I like to get to know you on a more personal level of which cannot be described without 70's porn music and flashing lights.
Quote:
Originally Posted by iridemymuni
hey evan i've got the same blue nipples as you !!!!!
Quote:
Originally Posted by tobbogonist
this may be off topic, but my trouser snake is called:
Conan: The Barbarian
bcwheelriderguyhehehehehe is offline   Reply With Quote
Old 2006-12-18, 04:54 AM   #3
timbob1907
crankflips!!!?!!!
timbob1907's Avatar
Send a message via AIM to timbob1907
Learn how to use the other hand. I used to be backpedal and could not even try to do a pedal grab. i learned how to use the other hand so i could jump the other way and now i can pedalgrab. It takes a bit of work but now i can ride with either hand and crankgrab to either side.
__________________
Quote:
Originally Posted by forrestunifreak
I'm addicted to placebo's. I should stop taking them, but it wouldn't matter anyway.
Quote:
Originally Posted by fluxusmaximus
It looks like some deranged mad-man going berserk with a heavy metal object.
(\_/)
O 0
(><)This is bunny. Copy bunny into your signature, help him on his way to world domination.
CarbonFibreSeat!
timbob1907 is offline   Reply With Quote
Old 2006-12-24, 06:03 PM   #4
skrobo
jumps stuff
skrobo's Avatar
Send a message via AIM to skrobo
hmm
it may be better to learn to jump to the other side w/ the other hand or turn your cranks 180*
a friend of mine is having the same problem, he is just learning pedal grabs. it is much more akward to go backwards for a pedal grab than forward (it goes forward or backwards because of the swinging motion... if you let it)
you can definitely do it. and it is probably not worth changing your style over either because of the way you ride.
__________________
><> Unicycle For Christ <><
MY VIDEOS
World Record
94cm Highest Hop (rolling)
308cm Longest Hop (10 feet)
210cm Static Flat Gap
skrobo is offline   Reply With Quote
Old 2006-12-24, 06:13 PM   #5
superuni
superuni's Avatar
Send a message via MSN to superuni
Quote:
Originally Posted by unirox13
ok im having trouble doing pedal grabs and going to rubber, i can do crank grabs to rubber most of the time but they're still kinda sloppy. so here's my question, my jumping position is right foot back left foot forward with my left hand on the handle and i jump to the right so i use my back foot for everything. in most of the videos i watch whenever someone does a pedal grab they use they're front foot, does that make any difference at all???
i ride the exact same way...it just takes a little bit of practice.. i can do crank and pedal grabs and grind with my back pedal..my peadal grabs are a little bit sloppy tho
__________________
Thizz
superuni is offline   Reply With Quote
Old 2006-12-24, 10:48 PM   #6
unirox13
Unicycling Ninja!
thanks yall i've been working on it a lot and i can get it every now and then so i guess that means im getting better. one other thing, would seat height also be a factor in doing SIF hops and crank and pedal grabs?
__________________
Old 2006-12-24, 11:17 PM   #7
Jerrick
King of Carnies
Jerrick's Avatar
Send a message via MSN to Jerrick
Many people who do SIF will have their seat higher. Its a lot more comfortable on your back cause your not hunched over, and it makes it easier to tuck.
__________________
Just bumming around MR~~~~~~~~~Team Forrest~~~~~~~~~Team Dirty Bird!~~~~~~~~~~~~~~~
Check out my Band.~~~~~~~~~~~~~~~!Quack!~~~~Team Spencer!~~~Member of the MRIS.
Want some advice? Do better.
~Jerrick
Jerrick is offline   Reply With Quote
Old 2006-12-25, 12:00 AM   #8
unirox13
Unicycling Ninja!
will i still be able to do like rolling hops, seat in jumps, and street stuff with the seat higher, or would it be better to just find like a comfortable medium where i could do pretty much everything with it?
__________________
Old 2006-12-25, 10:52 AM   #9
Jerrick
King of Carnies
Jerrick's Avatar
Yes, its all possable still.
A happy medium would be good to find, but then just take it about an inch higher than that. =p
__________________
~Jerrick
Old 2006-12-28, 10:47 PM   #10
unirox13
Unicycling Ninja!
i did yall, i finally landed the pedal grab to rubber...i kinda took ya'll advice as far as seat height and stuff but basically it was just practice and repatitiuon(sp?)
thanks again for the help
Max
__________________
Reply
Tags
back, pedal, woes
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Grinding on the forward pedal woes Sponge Unicycling Articles and Tutorials 8 2006-10-24 07:22 PM
Pedal grab with front foot or back foot? skate4flip General Unicycling Discussions 25 2006-04-10 02:29 AM
UW woes mazem General Unicycling Discussions 8 2004-07-14 05:31 AM
fell on my back on a pedal Mark Newbold General Unicycling Discussions 4 2003-03-31 03:55 AM
Coker Woes Brian Berlin General Unicycling Discussions 13 2000-07-15 10:51 PM
Copyright © 2001-2005 Gilby
Page generated in 0.10595 seconds with 10 queries
