Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
Registered User
The unispin tutorial to end all unispin questions
Title says it. I have come up with a method for learning unispins that is completely foolproof. I will write it on 180's but the same exact tecnique can be used to learn 360's, and 540's I think. Ok, so I'm gonna break down unispins into each of it's tiniest elements which will only take a couple tries to get, and then all you have to do is put them together. O yeah, something I forgot is that you should be very comforable with hopping SIF. Here is an outline of the components of a unispin:
I. UNISPINS a. 180 jump mount 1. jump mount 2. spin uni in air b. no-footer 1. jump off pedals 2. kick feet out c. 180 dismount 1. no-footer 2. spin uni in air 3. land on ground 180 JUMP MOUNT The two necesary abilities to have when doing a 180 jump mount is 1. the jump mount, 2. spin the uni while you are in the air. Jump Mount Basicaly, stand infront of your uni with pedals in hopping position. Just jump on, landing SIF. This is pretty easy, and you should get it quickly. Spin Uni In Air You can start of by just jumping infront of your uni, not landing on the pedals, and spining the uni WHILE YOU ARE IN THE AIR. This is usless if you start spining the uni before you jump off the ground. Make sure you don't do that. Now you can try the 180 jump mount. Jump off the ground, spin the uni AFTER YOU LEAVE THE GROUND, spot the cranks, and land on them. NO- FOOTER Jump off pedals This is basic, but sometimes people find it kind of scary. Something that helps is to push down on the saddle a little bit to kind of boost yourself up into the air. Kick Feet Out Jumping off the pedals is useless unless you can get your feet out of the way of your spining wheel when you do the unispin. Mostly this is mentality. To gain confidence of having your feet high off the pedals you can jump off the pedals, kick you feet out as much as posible, and land on the ground instead of on the cranks. Really this part is all in your head. Now just combine these two skills and you can do a no-footer. 180 DISMOUNT This step really just re-enforces your ability to be in the air and spin your uni, but it is an important step. Dont skip it. No-Footer Just do a no footer. Spin uni in air Sound farmiliar? the step in 180 JUMP MOUNT. Now just combine these steps and you have the 180 dismount. 180 UNISPIN Thats right, you just learned how to do all the steps in a unispin. Now all you have to do is combine it all. Mount the uni, get SIF, hop a bit to get your balance, do a no-footer, spin the uni, and land on the cranks. This trick is really all in your head. Hope I could help, and feel free to post any questions or PM me.
__________________
http://www.youtube.com/watch?v=XUKySpQh2qU Last edited by maximus unius; 2006-12-11 at 01:11 AM. |
#2 |
Maybe that will help some people but like most tutorials people make, it pretty much just states the obvious.
Jump off uni, spin it, land back on... |
#3 |
T.O.M.A.H.A.W.K.
You guys are making this trick a freakin' science!!! This is what you do:
1. Get seat in front 2. Jump off uni > Spin uni with both hands > Don't clip feet on cranks 3. Land on uni and ride off into the sunset Last edited by Tomahawk; 2006-12-11 at 04:01 AM. |
#4 |
Registered User
I get that I'm stating the obvious, but I find it really easy to learn tricks if you break them down into each part. For example, I learned a 180 unispin in about 45 minutes. Thought I might just share with you guys, but apparently that isn't welcome on this site.
__________________
http://www.youtube.com/watch?v=XUKySpQh2qU |
#5 | |
Quote:
#6 |
Registered User
I know that you weren't attacking me in your posts. Just because it's stating the obvious doesn't mean it won't be helpful...
__________________
http://www.youtube.com/watch?v=XUKySpQh2qU Last edited by maximus unius; 2006-12-11 at 10:30 PM. |
#7 |
T.O.M.A.H.A.W.K.
It was a good tut and all, but it made everything way more complicated than it really is. You don't need to learn how to 180 jump mount before trying a unispin, just jump, spin the uni around, then land on the pedals. The problem with all these noobs is that they don't want to put and time and effort into.
#8 |
King of Carnies
I dont get how it makes it complicated by explaining.
He doesnt over explain it and use big words and go way into detail on excact rotation feet positioned angled to the frame, body position over the uni and all other stuff he could of added to confuse people. You did a great job. Took the trick, broke it down into what it is to do one, briefly explained how to do those concepts, then put it back together. Very nice. |
#9 |
2 Wheel Traitor
I think this make it easier... what you people aren't realizing is that, you can already do it, and it's simple for you. For the people who can't Unispin yet, it is much harder than just jumping, spinning the unicycle, and landing back on the pedals.
#10 | |
Quote:
#11 | |
"See what Brown can crash for you!"
Yeah, what Spencer said^^^
I think a lot of the problem with all the people asking for tutorials is that they dont realize how easy stuff can be if you just try. They just gotta go outside and just go for it. I did my first 180 after 25 minutes of hard work. I was really surprised at how easy it was. Before I was one of the people who thought they had to have a tutorial to explain everything, but once I did one I felt a little silly that I asked so many questions about unispins. With that said, Great job on the tutorial Maximus Unius. I think that if people read this, they'd be more likely not to post new threads. I really don't care if they do, but some people do get annoyed by that.
__________________
Leftover parts are proof you made it better! Quote:
#12 | |
Patronus unicycleus
Quote:
__________________
Your life is a storm, thunder is your music and lightning is your electric dancing legs, groove on friends. Groove on.
#13 |
movie nerd
breaking things down into their parts often helps people get their heads around what's being done. and they can work on the part they're having problems with. i did (like most of you) and just practiced for 30-45 mins and landed one. not quite sure how, but i got one. after more practice i started figuring out some technical skills. like hand positions, how to get my legs out of the way to land in more consistantly etc. little stuff like that is what i look for when i read tutorials, not the simple mechanics, which can sometimes be helpful, especially if there's a way to practice them all separately.
i think about juggling tricks where there's a few different throws that you can do all separately, but when strung together look awesome. |
#14 | |
2 Wheel Traitor
Quote:
Nice.
#15 |
70% trials
I think the curve of the earth limits your ability to see for something like fourteen miles right? that's a long way to go on a unicycle every unispin.
| Tags |
| end, questions, tutorial, unispin |
Similar Threads
| 360 Unispin Tutorial | The.Mars.Volta | Just Conversation & Introduce Yourself | 9 | 2010-06-04 01:56 PM |
| Unispin Tutorial | The.Mars.Volta | New Article/Tutorial Request | 17 | 2007-04-26 06:16 PM |
| Unispin Video Tutorial!?!?!? | onewheelinwierdo | Unicycling Articles and Tutorials | 6 | 2007-01-31 05:18 AM |
| Rolling Hop Unispin? Unispin Grind? | Catboy | General Unicycling Discussions | 28 | 2004-12-30 01:03 AM |
