#1 |
Registered User
solid tires
does anybody else think a solid rubber trials tire would make it alot more hardcore and durable? for jumps off of higher objects...or is that just dependent on the rim??
?? i also know it would be a big pain to get it off and on the rim i dont even know if it would work right it would probobly be the biggest pain just making it and fixing the flaws and crap im just not sure...
__________________
Andrew |
#2 |
Registered User
and it would make it alot heavier
__________________
Andrew |
#3 |
Going places on wheel.
Heavy, no compression, so much more force would be going into you rim...
Would not work.
__________________
#4 | ||||
to tire-3ft.
Quote:
but we could also make a brick tire and the brick tire might work better too
__________________
Quote:
Quote:
Quote:
#5 |
That would hurt so bad. I have done small drops with a 110 psi tire and it hurts when you land. A solid tire would be worse.
#6 | |
2 Wheel Traitor
Quote:
#7 | |
Quote:
#8 | |
2 Wheel Traitor
Quote:
Must have been like riding on a brick. Did it pop? I bet if it did it was super loud. |
#9 |
Nah, it didn't pop.
#10 |
movie nerd
i know plenty of bmxers who run over 100 psi. they get pinch flats otherwise. and a solid tire would be especially hard to mount, even if its riding properties would be good, which they wouldn't be.
#11 |
Team Spencer Photographer
When I used to ride BMX I always had my tires at 110psi, I loved it, there was such little rolling resistance and I never smashed my room or pinch flatted.
Back to the subject though, I've seen solid rubber tires at walmart for 20" wheels. The labeling said it felt equivalent to riding on a 35psi tire. The option is out there but I think it would be pretty terrible for any sort of trials. I don't see there being much bounce. EDIT: I just searched for a bit and what I had seen was actually a solid tube http://www.walmart.com/catalog/produ...uct_id=3636434 Last edited by Brian O.; 2006-12-09 at 06:56 AM. |
| Tags |
| solid, tires |
Similar Threads
| Does a spoked rim deform then pop back? Or is it like a solid disk? | DonO | General Unicycling Discussions | 10 | 2005-11-16 11:48 PM |
| solid seat post ? | maxisback | General Unicycling Discussions | 2 | 2005-10-11 11:37 PM |
| Simple, solid, and smooth | Ben Plotkin-Swing | General Unicycling Discussions | 10 | 2005-08-19 06:28 PM |
| 24" slick tires: 3 Skinny tires for a smooth ride | don.tai | General Unicycling Discussions | 5 | 2002-04-01 08:52 PM |
