Unicyclist Community
Reply
Old 2006-12-07, 10:13 PM   #1
Spencer Hochberg
Send a message via AIM to Spencer Hochberg Send a message via MSN to Spencer Hochberg
Koxx hub on nimbus long neck...options?
So I turning my splined koxx 20" wheel into a freestyle uni now and I want a long neck frame. I tried to order a semcycle freestyle frame but they are out of them and don't know exactly when they are getting more in. So I would just get that new 07 nimbus but I might have a problem with the bearings. The koxx bearings are 42mm and the nimbus frame has machined bearing holders for 40mm bearings.
This is what is on the koxx website about their signature frame...
It has machined bearing holders and says it will fit 40 and 42mm bearings so is it possible that the nimbus will take 42mm bearings also?
Evan told me the 22x42mm bearings are shimmed to fit on the koxx axle so it might be possible to get the torker 20x40 bearings and see how that goes but then I would also need to buy an isis crank puller to switch the bearings.
Does anyone have thoughts about how to make this work?
Spencer Hochberg is offline   Reply With Quote
Old 2006-12-07, 10:52 PM   #2
andrew361
Registered User
I can't say anything about the new Nimbus frame, but I was running a Koxx One hub in my older Nimbus X (non long neck) with no problem at all. It actually fit in the Nimbus X frame a lot nicer than my Nimbus II frame.
Andrew
andrew361 is offline   Reply With Quote
Old 2006-12-07, 10:57 PM   #3
Spencer Hochberg
Quote:
Andrew
Yeah, but you use this kind of bearing holder.
So as long as it is close to the bearing size it will work but with the machined holders it fits more exactly. I am not sure how exact it is though...
Old 2006-12-07, 10:59 PM   #4
Borgschulze
2 Wheel Traitor
Borgschulze's Avatar
Send a message via MSN to Borgschulze
Do you know anyone with a CNC mill?
__________________
Gravity is not the issue.
Borgschulze is offline   Reply With Quote
Old 2006-12-07, 11:08 PM   #5
Evan Byrne
Why am i here? I dont unicycle.
Evan Byrne's Avatar
Send a message via AIM to Evan Byrne Send a message via Yahoo to Evan Byrne
Quote:
You dont need a cnc to make bearing holders.
Evan Byrne is offline   Reply With Quote
Old 2006-12-07, 11:10 PM   #6
Borgschulze
2 Wheel Traitor
Quote:
You're right, just get a big bit to cut into it. Manual Mill will work fine.
__________________
Old 2006-12-09, 02:48 AM   #7
Spencer Hochberg
Roger told me that the 42mm bearings will not fit in there but I also have a Udc freestyle wheel in my garage with 40mm bearings so I ordered the frame anyway. I still would much rather use the koxx wheel so I am going to see about getting different bearings for the koxx hub. I just need to know the OD of the axle since the bearings it comes with are shimmed to fit on there. I think I might be able to take the shims off and use smaller bearings, I need to check on that.
Old 2006-12-09, 02:52 AM   #8
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
Why don't you go to your local bearing store and have them take a look at it?
ntappin is offline   Reply With Quote
Old 2006-12-09, 02:54 AM   #9
Spencer Hochberg
Quote:
I dont think I have a bearing store, I could take it to a bike shop maybe...I can't take the cranks off though. I guess if I was going to a bike shop anyway I could have them do it.
Oh and I would just order some bearings online but I don't know the diameter of the axle...
Old 2006-12-09, 03:02 AM   #10
maximus unius
Registered User
maximus unius's Avatar
Why can't you take off the cranks. I though they were regular Koxx cranks?
maximus unius is offline   Reply With Quote
Old 2006-12-09, 03:47 AM   #11
Spencer Hochberg
Quote:
They are so I need a crank puller.
Old 2006-12-09, 04:41 AM   #12
ntappin
ntappin's Avatar
Why don't you try them?
Santa Clarita, Bearing
25520 Avenue Stanford Ste 307
Valencia, CA 91355
(661) 295-0760
Old 2006-12-09, 04:47 AM   #13
Spencer Hochberg
Valencia, CA 91355
(661) 295-0760
haha thanks. It would be better to find the size of the axle then look for the bearings instead of trying a whole bunch of different bearings and seeing if they fit.
Old 2006-12-09, 05:20 AM   #14
ntappin
ntappin's Avatar
Quote:
I was thinking more along the lines of, bring your axle into the shop, have them do all the dirty work .
Old 2006-12-09, 05:24 AM   #15
Spencer Hochberg
Ha, that would work too.
Reply
Tags
hub, koxx, long, neckoptions, nimbus
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wanted: trials cranks and hub Michea Trading Post 0 2006-12-05 05:13 PM
Long neck freestyle or short?? souleater12 General Unicycling Discussions 4 2004-10-30 05:09 PM
Long wait for Nimbus munimanpete General Unicycling Discussions 3 2004-06-30 07:07 AM
for sale.............20 inch Freestyle Sem Long neck For Sale..20" Freestyle General Unicycling Discussions 22 2004-02-09 06:45 PM
Broke my neck last night AccordNSX General Unicycling Discussions 30 2002-07-13 05:27 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11983 seconds with 10 queries
