Unicyclist Community
Reply
Old 2006-12-07, 03:53 AM   #16
Spencer Hochberg
Send a message via AIM to Spencer Hochberg Send a message via MSN to Spencer Hochberg
Quote:
Originally Posted by Evan Byrne
At moab im going to go around at night and coat everyones rims in tar, the next day they will have no modulation and lots of noise.
Ha, they will be flying down a hill at 20mph then tap the brake and fly.
Spencer Hochberg is offline   Reply With Quote
Old 2006-12-07, 03:54 AM   #17
Borgschulze
2 Wheel Traitor
Borgschulze's Avatar
Send a message via MSN to Borgschulze
Quote:
Fly into a lawyer and sue Evan probably, now that we know who is going to do it.
It would still be funny to see that, *tap* Aaaaaaaaaah!
__________________
Gravity is not the issue.
Borgschulze is offline   Reply With Quote
Old 2006-12-07, 12:24 PM   #18
joemarshall
dumb blonde
I think munis should come with v brakes.
I'm kind of undecided on this.
V-brakes are okay on 29ers, but with a super fat tyre on a muni, some people find they rub on their legs. It's partly about mount placement, but also leg shape/length makes a big difference. Also, if you hop a lot seat out front, they can get a bit in the way. Having said that, Joe McLeans 26" didn't seem to have any problems with this, I think because of better brake mount placement.
They have a big advantage that it isn't anywhere near so easy to destroy the cable / fittings as a magura hose. It is possible to crash hard on the wiggly bend bit that the cable goes into and break that though. They also have the advantage that cables are lightweight and can be replaced whilst on the trail, without carrying fluid around with you. I've been on several rides with magura riders where they've pulled out the hose and had no brake for the rest of the ride.
In terms of modulation and stuff, v brakes seem very similar when setup well.
If only there was a sensible way to fit a cable disc brake to munis, that'd seem like the obvious nice thing to do.
Joe
joemarshall is offline   Reply With Quote
Old 2006-12-07, 12:42 PM   #19
Borgschulze
2 Wheel Traitor
Quote:
Actual part name is a "Noodle".
__________________
Old 2006-12-07, 02:59 PM   #20
filmo
Registered User
Monty sells an adaptor so you can feet V's in magura fittings, and they are cheap (sorry I can`t find them in their web). They are two screws with the V's mounts.
Also other brands have got adaptors:
http://www.heatsinkbikes.com/?p=veeadapters
and woodward also:
http://www.woodmancomponents.com/cat...at=brk&lang=en
Monty also sells a V' brakes witch are taller than normal V's ( they use them for cheap trials bike) The pads aren´t good but the levers will feet a 3.0 tire.
V's are cheaper and easier to adjust than magura.
filmo is offline   Reply With Quote
Old 2006-12-07, 08:29 PM   #21
Evan Byrne
Why am i here? I dont unicycle.
Evan Byrne's Avatar
Send a message via AIM to Evan Byrne Send a message via Yahoo to Evan Byrne
It werid that maguras are the standard for unicycle brakes. The main addvantage to maggies is thier vice-like grip on a rim for the ultimate trials bike lock. Which is what unicyclers never want, Unicyclers need modulation. Though it would require a special hub, For the best modulation a disc is the way to go. No leg bumping of any kind there.
Evan Byrne is offline   Reply With Quote
Old 2006-12-07, 08:37 PM   #22
Probailer2
Say no to drugs!
Probailer2's Avatar
Maguras on unis are silent though.
Yeah you realy think so?
Search for some MUNI footage from Kris Holm.
His Magura's squick like hell sometimes.
PM
__________________
Sponsored by www.municycle.com
Quote:
Originally Posted by JJuggle
If somebody cloned your mother would you have sex with the clone? I should think not.
Quote:
Originally Posted by Danni
I don't like having penis written all over my uni .
Quote:
Originally Posted by manon1wheel
no offense but deads look plain old gross...
Probailer2 is offline   Reply With Quote
Old 2006-12-07, 08:43 PM   #23
Spencer Hochberg
you would need some kind of guard though or it would get smashed on a muni. Someone mentioned in another thread that when you ride skinnies it is not uncommon to fall to the side where you would land on the disc.
PM
I guess it depends on the setup. My maguras on my kh muni dont make noise.
Old 2006-12-07, 08:47 PM   #24
Evan Byrne
Evan Byrne's Avatar
yeah well a guard would be really really easy to make.
Old 2006-12-07, 11:11 PM   #25
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
Trialsin, has some special brake pads especialy made for V brakes. They are made out of the same stuff they use for their special mag pads, so they would probably be really good, maybe too good though.
ntappin is offline   Reply With Quote
Reply
Tags
990, breaks
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Breaks on a coker??Yes???No?? total uni General Unicycling Discussions 15 2004-12-17 09:31 PM
Breaks are good? Bill Huff General Unicycling Discussions 3 2002-07-20 05:13 PM
Breaks Jeff Lutkus General Unicycling Discussions 0 2001-04-16 06:28 PM
How to fit breaks on a Uni Steinardo General Unicycling Discussions 2 2001-03-20 08:30 AM
no gears, no breaks, no problem Seth Golub General Unicycling Discussions 1 1999-11-11 07:44 PM
Copyright © 2001-2005 Gilby
Page generated in 0.10992 seconds with 10 queries
