#16 |
1st crankflip in Brazil
im thinking about buying a kh isis cranks and hub
you guys know if it fit in the nimbus frame ?
__________________
From HELL SP mono CLUBE! ###unicycle for JAH RASTAFARI### One wheel in brazil |
#17 | |
King of Carnies
Quote:
I am not sure about the regular, rounded Nimbus frame, but if I remember right, you ordered the Nimbus Hoppley, and that comes with the Nimbus II frame, so I hope your using that one. lol Anyways, because the Nimbus II frames bearing holders arent machined and perfect like on a kH frame, they will hold the 42mm bearings from KH. =p |
#18 | |
Registered User
Quote:
If you search the forum you will find two answers: "Yes you can with no problems, I have done it for years." and "No, it will cause your bearings to fail." I have not run a 42mm bearing in a 40mm bearing housing frame for more than a few hours. So I can say yes it will fit but I am not sure about the long term durability of the bearings. If you do order a KH ISIS hub and cranks and plan to put them in a nimbus frame, I would order a spare set of bearings because the KH ISIS bearings (made by Qu-ax) are 42mm x 24mm and are not a standard bearing size. |
#19 |
dammt
__________________
#20 | |
Robs World
Quote:
#21 |
elcycinu
Help pleaese!
I've done the same anybody know how I can fix it?
__________________
I didn't spell it wrong, you just read it wrong! Last edited by thejdw; 2007-03-12 at 05:48 PM. |
#22 | |
Robs World
Quote:
#23 | |
elcycinu
Quote:
__________________
I didn't spell it wrong, you just read it wrong! |
#24 | |
Registered User
Quote:
Hell even if they do fail after two years, new bearings are about £6 or something, lot cheaper than getting a 42mm frame.
__________________
Dave - what a thoroughly post-modern subversion of the cycling genre - Last edited by kington99; 2007-03-12 at 10:21 PM. |
#25 |
Polska Możność
i remember reading a tip somewher that said you put a penny or something in before the crank extractor. can anyone confirm this?
#26 | |
Totally Doable
Quote:
ISIS is a standard. If the cranks you manufacture are the only ones that fit properly on your hub, you're not following the standard. "Slight variation" is not acceptable. |
#27 |
Registered User
Koxx-One is not offering two hubs, one using M12 bolts and one using M15. ISIS cranks require ISIS crank arm remover. Square taper crank remover has much smaller area to push on spindle....hence it getting stuck inside ISIS spindle threads.... no fun as a couple of you have found out. Any bike shop should have ISIS crank arm removal tool.
Per K1 cranks on other spindles. Last week I tried the standard K1 crank that comes on Devil 19s etc...) on 4 other brands of ISIS spindles. They fit well. Next week or so I will be getting in the LIGHT and STREET cranks in and I will try them on other ISIS spindles. Let me know if anyone is interested in my findings. Per crank installation. I have found the best way to get good seating of cranks to spindle is with a rubber mallet. Lay the UNI/bike on its side so that the downside is touching ground/wood (place towel in between so as not to scratch up your cranks/spindle), place crank on upside......... hit forcefully 3 or 4 wacks with rubber mallet. This seats the crank onto the spindle well and greatly reduces odds of them loosening up quickly. Though you should always check crank bolt tightness numerous times after installing cranks (particularly new ones). Last edited by tim williamson; 2007-03-13 at 02:16 PM. |
#28 |
Hi Tim
Everyone knows koxx cranks apear to fit on other spindles because they are too big. I would be interested if you find any other ISIS cranks that we can fit onto the Koxx hub Thanks jim |
#29 |
Threadjack surfer
we european use 2 coins of one eurocent to prevent the crank extractor from damaging the isis axle...
get prepare to waste 2 eurocents because the coins are completely destroyed but if you compare this with an isis hub price... the choice is quickly done
__________________
GILD: "You get to play every game in the world, in the finest game setting known to man, your imagination." One of these days I'm gonna change my evil ways. Till then I'll just keep riding on |
#30 |
Registered User
Remove cranks easily with the proper tools!
The right tools for the KH 2007 crank removal operation
http://www.parktool.com/products/det...6&item=CCP%2D4 with http://www.parktool.com/products/det...26&item=HR%2D8 or this coupled with the appropriate wrench http://www.parktool.com/products/det...6&item=CWP%2D6 The CCP-4 is really simple to use. Remove the 8mm Allen bolt. Make sure the threads on the crank are as clean as possible before screwing the crank removal tool into the crank. It's a good idea to check the crank removal tool threads, too. If the tool was dropped or hit by something it is very easy for the fine steel threads to get damaged. If you can't screw the tool in with your fingers you are probably stripping the aluminum threads on the crank - this is bad! Once the crank pulling tool is firmly screwed into the crank - turn the handle and your crank will slowly be pulled free. It really is simple, if you make sure the threads on the crank and the tool are clean! |
| Tags |
| crank, isis, removal, warning |
Similar Threads
| Koxx "ISIS" cranks removal... How is it done...? | Sponge | General Unicycling Discussions | 32 | 2006-10-30 01:32 AM |
| Crank arm removal | koebwil | General Unicycling Discussions | 13 | 2006-01-08 06:02 AM |
| Crank removal help?? | burjzyntski | General Unicycling Discussions | 8 | 2005-07-07 07:33 PM |
| crank removal | cathwood | General Unicycling Discussions | 2 | 2005-05-10 07:15 PM |
| Crank Arm Removal | ITEMNO530 | General Unicycling Discussions | 2 | 2003-06-30 03:18 PM |
