Unicyclist Community
Reply
Old 2006-12-02, 01:54 PM   #1
Everclear
sexersizer
Everclear's Avatar
Question about rotating cranks
Well today i relised how much the tread on my tire had been warn out so i decided to rotate my cranks. But unfortunatly i didnt have the right equipment so i couldnt. So what i then did was just deflate the tire and and then pull it so i would then use a different section of the tire.
So my question is, is what i did fine? because by rotating the cranks you also move the rim around to i different section....Is it important to keep on altering the position of the rim as well as the tyre??
Thanks for any help
Everclear is offline   Reply With Quote
Old 2006-12-02, 01:57 PM   #2
markf
movie nerd
Send a message via AIM to markf
that should be fine. if your rim is dinged, true it, don't just rotate the cranks. the rim won't really "wear out" in the same type of way as the tire will.
markf is offline   Reply With Quote
Old 2006-12-02, 01:57 PM   #3
ivan
Non-Danish Girl
ivan's Avatar
It's fine. I did the same a few weeks back.
I've never heard of the importance of rotating your rim, so can't help you there, but I'd guess it's a minor issue.
__________________
Did you know that lighter flame smells like burnt nose hair?
Entropy isn't what it used to be.
ivan is offline   Reply With Quote
Old 2006-12-02, 03:01 PM   #4
Mikefule
Roland Hope School of Unicycling
Mikefule's Avatar
It's worth rotating the cranks by 90 degrees, or the tyre, to even out the tyre wear. The tyre scrubs on sharp turns, which are normally at the same part of the pedal stroke, which is why you get uneven wear.
The wheel doesn't get localised stresses and wear in the same way. I suppose it might if you do lots of hopping and dropping because you will usually land witht he cranks horizontal, and probably usually with the same foot forwards. However, for normal riding, I wouldn't worry.
Do get the correct tools to remove your cranks, though. Never try jobs like that witht he wrong tools, because you will cause frustration to yourself and damage to the unicycle. This will cause further annoyance which may make you throw the unicycle at the wall in a fit of temper, causing further damage to the unicycle and possibly to the wall. That will upset you even more, and very probably annoy the owner of the wall. This will lead to a spiral of anger, damage and further anger which will escalate completely out of control.
It is a little known fact that if Adolf Hitler had bought a proper crank removing tool in early 1939, and had not stripped a thread, lost his temper and thrown his unicyle at his Polish neighbour's newly whitewashed wall, World War 2 might have been avoided.
__________________
"I try to avoid UPDs, not do scientific research on them." Bruce Dawson
Mikefule is offline   Reply With Quote
Old 2007-01-01, 02:54 PM   #5
thejdw
elcycinu
thejdw's Avatar
Send a message via MSN to thejdw
LOL page 18
__________________
I didn't spell it wrong, you just read it wrong!
thejdw is offline   Reply With Quote
Reply
Tags
cranks, question, rotating
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Question regarding which cranks to buy Chexjc General Unicycling Discussions 9 2006-10-07 01:18 PM
Profile Hub & Cranks - Warranty Question unicyclistjoe General Unicycling Discussions 12 2005-11-02 11:49 AM
Profile Cranks Question... unibrow General Unicycling Discussions 10 2005-01-15 07:02 AM
a question about cranks and hub uni-2-death General Unicycling Discussions 10 2003-10-06 01:45 AM
Ping--Jason Question about your DM cranks jagur General Unicycling Discussions 5 2003-06-29 02:30 PM
Copyright © 2001-2005 Gilby
Page generated in 0.06895 seconds with 10 queries
