#1 |
Registered User
Wanted: Magura brake part
I broke my magura hs33
the part that attaches to the seat post cracked, so if anyone has a spare part around the attachment area, let me no!! haha, i will have to go on a brakeless ride now!
#3 |
i will defenestrate you
did you buy from your lbs
__________________
www.unicyclepa.com we suck but its all good team YAMS member in your sig or title and say |
#4 |
Registered User
Or try eBay I got a new brake lever on ebay for $25 and $5 shipping. If you aren't in too big of a hurry you can probably get one for less
#5 |
Why am i here? I dont unicycle.
Unless you do that very very carfully, your going to bleed your brakes.
Check magurausa.com for info on how to bleed it. |
#6 | |
Registered User
Quote:
Yes you will definitly need to bleed your brake. It's not that difficult but you will need a bleed kit and fluid. I got the 5wt. Finish Line Shock oil on Amazon and I made my own bleed kit with a marinade injecting syringe and a bit of plastic tubing and a barbed magura fitting. I don't think the Magura kit is very expensive but I put this together for about $3.50 but I already had the magura fitting from replacing my plastic brake lines. |
#7 |
Registered User
Repairing Magura
I also did this and was able to uses a hose clamp to attach the break to the post. I don't have the break anymore to look at, but I believe there is a screw on the inside. I drilled a whole in the hose clamp and put the screw through it to attach it. The clamp held the brake securely.
#8 |
Registered User
I found that the cheapest was £30 for the part that i want, turns out i have to get the whole master cylinder. I'm not going to get it because i didnt use the brake that often when it was on but when i get better and start to need it, i will think about buyin the part. So if anyone if interested, i am open to offers for the brake. Obviously the clamp is broken but i will be willing to sell the whole thing. You can pm me or reply to this thread with offers. Or email me on tommygrhcp@gmail.com.
| Tags |
| brake, magura, part, wanted |
Similar Threads
| [Wanted] Magura Brake System | UniBrier | Trading Post | 3 | 2005-12-20 12:06 AM |
| Missing Part: Magura Brake Shim | Evan Byrne | General Unicycling Discussions | 5 | 2005-09-02 09:34 PM |
| [WANTED] Magura HS Brake | ColDawG | Trading Post | 5 | 2005-06-02 09:01 PM |
| magura/KH brake mod | cline | General Unicycling Discussions | 3 | 2004-09-30 04:30 AM |
| Magura brake help,please | forget_your_life | General Unicycling Discussions | 11 | 2004-04-08 05:48 AM |
