Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Unicycling Articles and Tutorials
Prev Previous Post   Next Post Next
Old 2006-08-17, 11:16 PM   #1
trials_uni
Trials and Muni Rider!
trials_uni's Avatar
Arrow Maintaining your Splines!!!
Ive noticed lately that alot of riders(Mostly new riders) are getting new Splined setups and not knowing how to maintain them. Then when they start to creak or break down they come complaining. So ive decided to write a tutorial that outlines how to properly maintain and reassemble a splined crankset and keep it in good working condition.
Im going to cover:
Removing the Cranks and Bearings
Cleaning and Regreasing
Reassembly
How to detect Wiggles and creaks in your uni.
So lets get started.
Removing Cranks and Bearings
Ok we all know that to properly clean and check a hub that the cranks have to come off right? So you have to know how to take them off.
There are 2 kinds of splined cranks. Ones that have pinch bolts, and ones that just slide(Read: Must be pounded) on. Some examples of the pinch bolt ones are: Torker DX, Qu-Ax, and older KH models. Examples of the slide on typer are: Profiles and new KH.
To remove the slide on ones you may need a crank puller to get them off. You can get one at the LBS for about $10 or if you buy Profiles one will likely be provided. Ill go through the steps one by one.
1. Remove the crank bolt by twisting it out of the axel.
2. Thread the crank puller into the crank.BE CAREFUL NOT TO CROSSTHREAD!YOUONLY GET TO STRIP YOUR CRANKS ONCE!!
3. Wind the crank puller around and the crank will slowly come off.
4. Do this to both and you'll be ready for the next step.
Now the Pichbolt designs are characteristically easier to remove but a crank puller still may be needed.
1. Loosen the pinch bolt from the top of the crank. You can take it right out if you like.
2. Remove the crank bolt from the axel.
3. The cranks should now slide off eas it does not use step 2 and 3 from the other crank list
**IMPORTANT** Never use a piece of wood and shove it through your spokes to bash the crank off. it puts a wierd angle on the crank and axel and could cause premature failure.
Now the bearing removal is simple. They should just slide off...But if not then get a beaing puller from an auto parts shop and use it to get the bearings off.
Now your ready for cleaning and regreasing!
You need to keep your splines clean and frshly greased to maintain optimal performance and to help prevent creaks in the setup.
1. Get a rag and clean the gobs of grease off of the splines in the crank and on the axel.
2. Now, using a fresh rag, spray some degreaser on the axel and in the cranks and clean it really well. nuse WD-40. Invest in a decent degreaser, you'll be glad you did. I use Pedros Orange Peelz.
3. Get a hold of some good grease(not auto grease). Id recomend Polylube or Copper Anti Sieze.
4. Apply it to the splines generously, both on the cranks and on the axel.
Now your ready for reassembly!
Reassembly
You cant ride a uni while its in pieces now can you?!
These first steps apply to both slide on and pinch bolt models.
1. Slide your bearings and spacers onto the axel.
2. Slide the cranks onto the axel being careful to keep the left on the left and the right on the right.(this may require a deadblow hammer)
Now it changes. For the slide on models:
1. Put the crank bolt back into the axel(use loctite if you want to)
2. Carefully wind the bolt in. You dont want to strip your axel now do you?
3. Once its in give it a good yank to make sure its good and tight.
And for Pinchbolt models:
1. Put in the crank bolt in just as above being careful not to strip anything.
2. Give it a real good yank to make it tight.
now at this point the crank may still have a bit of a wiggle...Thats what the pinch bolt is for. Wind it into the crank and reef on it real good. That should eliminate the wiggle and fasten your crank completely to the axel.
Now that its back together take it for a real good ride. When you get back make sure that eveything is really good and tight still.
Diagnosing Wiggles and Creaks
Everyone has a problem with wiggles and creaks sometimes. Now you'll know how to diagnose and fix yours!
Wiggles:
A wiggle can happen any time and is often something that should be taken care of right away. So your wondering, "How will i kno if my uni has a wiggle?". the answer is simple. If you kno your uni you will recognize the wiggle as soon as you step on. Some thing just wont feel right.
Some common causes of wiggles are:
1. Crank comming loose.
2. Bearing cap comming loose
3. Axel comming loose from hub.
The first 2 are things that you can take care of easibu tightening the components causeing the problems. The third is something that should be forewarded to your local Uni expert. Dont take it to the LBS, they wont kno what theyre doing anymore than you do.
Creaks:
Creaks are often caused by the crank/axel interface. If your uni is creaking its telling you that its time for an over haul.
So thats all for now. Now you'll have a much better idea of what your doing and will have alot more fun with your splined setup.
If anyone has any comments or additions just add them here.
Hope this helps you guys.
-Phil
__________________
TRIALS 4 LIFE !
Check Out The Newbie Guide
And the Spline Maintenance Guide!<UPDATED!!!With Video
Quote:
Originally Posted by BillyTheMountain
Hey thanks! The unicycle community needs more people like you, willing to out Bike Suprematists and stand up for the rights of unicyclists!
I'm puttiing you in for an Award at NAUCC!
trials_uni is offline   Reply With Quote
Tags
maintaining, splines
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Number of splines? heavy metal unicycling Rec.Sport.Unicycling 4 2005-07-01 05:45 PM
splines happysquidman Rec.Sport.Unicycling 2 2004-10-29 04:48 AM
Antiseize anything other than splines? Sofa Rec.Sport.Unicycling 12 2004-04-06 12:46 PM
Splines vs. square tapers. onewheeldave Rec.Sport.Unicycling 57 2004-02-12 08:00 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.23546 seconds with 10 queries
