#1 |
ゴールデン!
Grinding on the forward pedal woes
Hi, I've recently been doing something a little different to my normal 'rock hopping'. So I decided to play with grinds more on marble ledges in China. however, I only do grinds on small ledges, and I'm finding it hard to slide on my pedal which is the forward left pedal. I think it's easier to 'camp' on the back pedal for grinding because its like an anchor and most of your weight is sort of centreed back a bit.
But, I know other riders like Mike Clark, Shaun J, Zack B, all grind on their forward pedal, it's just that I'm wondering is it possible to get a forward pedal grind good without the wheel lowering down and rubbing against the floor, if you get me? The main problem I get with pedal grinding is that my wheel swings down a tiny bit and ends up rubbing the floor which in turn stops the grind. Any tips anyone? I don't want to crankgrind anymore. |
#2 | |||
Say no to drugs!
If you grind on the pedal only and you tire hits the ground, then you have to grind on the crank to.
And with a pedalgrind it doesn't mather what position your grindfeet is. You just have to learn it. PM
__________________
Sponsored by www.municycle.com Quote:
Quote:
Quote:
#3 |
ゴールデン!
grinding on the back pedal's easier, seeing as the back pedal works better as an 'anchor'. and its more awkward to swing up/hold up the uni holding the handle when your grinding on the front pedal.
#4 |
blank
Check out www.unicycletips.com . They have some great advice about grinding, I'm not much help as I am crap at grinding.
Mike
__________________
Add me at: mike41ishere <att> hotmail <dott> com 'i like things big' - Amanda 'Crankflips are like woman, hard to understand' Peter/Probailer2 |
#5 | ||||
Say no to drugs!
Quote:
I tried grinding on the back pedal and I can do it on a slented ledge but on a flat box I can't slide far (maybe 10 cm). And I sometime fly over the uni because I lean to mutch over the crank and the it rotates and projects me away from the uni. PM
__________________
Quote:
Quote:
#6 |
grimreeper
sif grind
the other day i learnt to grind
i tryed 2 different techniques on a flat grind i do it right foot in front and it works pretty well on a slope without jumping on to it i did sif and it worked well u can control the uni wether its on the pedal or pedqal and crank and its very easy to land
__________________
death can't be prevented Last edited by grim_reeper01; 2006-10-06 at 10:02 PM. |
#7 | |
Get up on your roof!
Quote:
T.
__________________
"DarkTom of Glasgow, one of the few uni riders here that you really musn't mess with" - GkMac "mondeos can fly" - Pebbles 24" uni for sale koxx/onza trials uni for sale |
#8 |
ゴールデン!
woahh this was ages ago
Between the time of my first post further up, and now, I've been properly grinding on my pedal. I just don't find the crankarm to be as good at sliding, and it can screw up when the crank and bearing clamp wedges the grindbox/rail. Pedal seems to screw up less in a way, feels nicer, and slides faster. |
#9 | ||||
Say no to drugs!
Quote:
![]() So I'm trying pedalgrinds now PM
__________________
Quote:
Quote:
| Tags |
| forward, grinding, pedal, woes |
Similar Threads
| Pedal Grinding a Unicycle | madmattunipro | General Unicycling Discussions | 30 | 2006-07-24 03:33 AM |
| iPod woes | Erin | Just Conversation & Introduce Yourself | 17 | 2005-05-25 09:15 AM |
| UW woes | mazem | General Unicycling Discussions | 8 | 2004-07-14 05:31 AM |
| Maintenance woes | Mikefule | General Unicycling Discussions | 3 | 2003-08-11 04:07 PM |
| Uni saddle woes... | Dave/Cheryl Chandler | General Unicycling Discussions | 11 | 2002-01-28 05:56 PM |
