Unicyclist Community
Reply
Old 2006-07-16, 03:10 AM   #1
trials_uni
Trials and Muni Rider!
trials_uni's Avatar
Stripping paint off of Steel(maybe Chromo, Not sure) Frames...
I decided that i want to paint my Uni properly this time and so i need to get the crappy last paint job i did on it off.
The frame is from Bedford if that helps anyone to tell me what its made of.
So what can i use to get the old paint and chrome finish off the frame to prep it for painting? Is there an chemical that will help me strip the paint or am i j in for a couple hours of sanding?
Anyhelp would be great.
Thanks
-Phil
__________________
TRIALS 4 LIFE !
Check Out The Newbie Guide
And the Spline Maintenance Guide!<UPDATED!!!With Video
Quote:
Originally Posted by BillyTheMountain
Hey thanks! The unicycle community needs more people like you, willing to out Bike Suprematists and stand up for the rights of unicyclists!
I'm puttiing you in for an Award at NAUCC!
trials_uni is offline   Reply With Quote
Old 2006-07-16, 03:35 AM   #2
Evan Byrne
Why am i here? I dont unicycle.
Evan Byrne's Avatar
Send a message via AIM to Evan Byrne Send a message via Yahoo to Evan Byrne
Well, theres this stuff called...............*laughs*..........Paint stripper.
That and a wire brush should do the trick.
Evan Byrne is offline   Reply With Quote
Old 2006-07-16, 03:49 AM   #3
pdc
Registered User
pdc's Avatar
Send a message via AIM to pdc
Sand blasting.
A powdercoat shop will usually sand blast and powdercoat a frame for $30 OR $40 usd.
__________________
"What doesn't kill you strengthens you, what kills you strengthens your mother"
pdc is offline   Reply With Quote
Old 2006-07-16, 12:48 PM   #4
trials_uni
trials_uni's Avatar
Thanks Evan but due to that fact that i didn t kno what the frame was made of or what effect paint stripper would have on it i had to ask the stupid question...
-Phil
__________________
TRIALS 4 LIFE !
Old 2006-07-16, 03:04 PM   #5
kington99
Registered User
Send a message via MSN to kington99
Paint stripper is made for stripping paint from metal, therefore it doesnt damage metal surfaces.
A Bedford frame will almost certainly be made from steel, but the cleaning process is no different if it is CrMo. Sand blasting is the best bet by far, but if you dont want to fork out then a brush that mounts in a power drill can be pretty good, ones like this are far more effective than wire brushes and dont throw out sharp wires as they wear. I would expect to be able to strip a uni frame in ten mins with one of these, and they clean the metal underneath and roughen it slightly for good keying with whatever coating you decide to use to replace the paint.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2006-07-18, 09:00 PM   #6
trials_uni
trials_uni's Avatar
Kington your idea worked great for the drill mounted wire brush.
However it did take quite a while because i didnt have a clamp so the frame was all wobbly. The wire brushes, to my suprise, didnt leave any pit marks or gouges in the metal, it was a very clean stripping of the paint. now im in for some sanding to get the paint out of the corners and tou rough up the surface for the primer tonight.
__________________
TRIALS 4 LIFE !
Old 2006-07-18, 09:06 PM   #7
mornish
magic
Send a message via ICQ to mornish Send a message via AIM to mornish Send a message via MSN to mornish Send a message via Skype™ to mornish
I think this is a stupid question, but what exactly is primer?
mornish is offline   Reply With Quote
Old 2006-07-18, 09:37 PM   #8
trials_uni
trials_uni's Avatar
Its a type of paint( i think) that goes on before the color paint. Its usually grey and it just helps the paint to bond to the surface better.
__________________
TRIALS 4 LIFE !
Old 2006-07-18, 09:47 PM   #9
mornish
magic
ok thanks
Reply
Tags
chromo, frames, paint, steelmaybe, stripping
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WICKED PAINT JOBS and anything else to do with paint brockfisher05 General Unicycling Discussions 2 2005-02-05 04:53 PM
Ping DangerUni: Stripping Nuts Memphis Mud General Unicycling Discussions 11 2004-09-24 08:31 PM
miyata nuts stripping Memphis Mud General Unicycling Discussions 2 2002-11-11 09:28 PM
Titanium Muni frames to steel Frames? scottw General Unicycling Discussions 7 2002-05-15 03:58 PM
steel? cjreeder@juno.com General Unicycling Discussions 1 1998-03-15 08:07 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07172 seconds with 10 queries
