#1 |
Registered User
project
im doin a school project for math how many wheel revolutions does it take to go a mile does cranks affect how bout wheel size?
#2 |
Registered User
You need to find the outside circumfrence of the tire, because that will differ depending on your tire.
An easy way to find the circumfrence is to measure the height of the tire (while the tire is on the wheel). then the Circumfrence= Height x 3.14. Measure in feet and convert it to a decimal. (ex. 1 ft and 3 in = 1.25 ft) Now there are 5280 feet in a mile. so divide 5280 by the circumfrence and that is the number of rotations it takes to go a mile. Of coarse the answer will be different depending on the wheel and tire you measure. Let us know the results! |
#3 |
Registered User
Crank length wont effect this number, but it may effect how fast you can ride the mile!
#4 |
Registered User
i did it differnet ly but i have a 129 in math and have verified it with 3 differnt sources here r the results
36"-1760 29"-2190 26"-2444 24"-2640 20"-3300 16"-4061 Last edited by skianduniaddict; 2006-06-02 at 04:25 PM. |
#5 | |
Roland Hope School of Unicycling
Quote:
You have used the diameter, not the circumference. A mile is 1,760 yards. A yard is 36 inches. The circumference of a wheel is Pi x the diameter, or 2 x Pi x the radius. So, a 36 inch uni does Pi yards per revolution. Counting Pi as 3.142 1760/Pi = 560 revolutions to the mile To find the circumference of a wheel, take the diameter (20, 24, 26 etc.) and multiply by 3.142. Now you have a circumference in inches. What is a mile in inches? Simply, it is 1760 (yards in a mile) x 36 (inches in a yard) 1760 x 36 = 63,360 That means there are 63,360 inches in a mile. That's why old inch/mile maps were in 1:63360 scale. So, take 63360 inches (a mile) and divide by the circumference in inches. Taking the Coker again: 36 inch diameter x 3.142 = 113.112 inches circumference. 63360 / 113.112 = 560.15 The accuracy of your answer will depend on how many decimal places you take for Pi. From memory, Pi = 3.1415926535 approx.
__________________
"I try to avoid UPDs, not do scientific research on them." Bruce Dawson |
#6 |
Registered User
Mike is correct. Those numbers are off.
He is saying exactly what I said. But I am still not sure that the actual outside diameter of a coker tire is truly 36 in. Can someone verify this? |
#7 |
The outside diameter of a Coker tyre at normal pressure with no load is as near as dammit 36 inches. An allowance could be made for deformation under load, but as a percentage, this would be minimal.
Let's not do the whole project. Leave some challenge for the student.
__________________
#8 |
THE original 12" Trials vid
At this rate we will have done his maths project for him!
I wish i knew about the forums while i was still at school! Rock on! Edd
__________________
www.voodoounicycles.com- The UKs only Extreme Unicycle Display Team I guess it's just a good thing you didn't include the footage of us snorting cocaine from the thighs of prostitutes eh Edd. - Boogie |
#9 |
King of Carnies
There is a thread about this form terrybigwheel, everything is very well explained in there, I suggest checking it out =p
#10 | |
Registered User
Quote:
It could also depend on how you define a mile. If it is a pre-marked distance then you would have to ride your uni in a straight line, which may be easy for some people, but not me! |
#11 |
Registered User
sorry i blew thAT AND I HADED IT IN SO ITS redo time
#12 |
I got infinite skillz
I'm sorry i'm not contributing in any way but this would have been so much easier if you used metric :P
#13 |
Registered User
Considering the orginal question was 'how many rev's to go one MILE', I dont see how using the metric system would help.
#14 |
What's in the box?
Everything would be easier if we used metric.
__________________
Ah, unicyclist.com, we meet again after all these years. |
#15 |
Registered User
i have them i did wheel 63360"/(diameter x 3.14)
36"-560 29"-695 26"-776 24"-840 20"-1008 18"-1121 |
| Tags |
| project |
Similar Threads
| Science Project | JeffArchibald | General Unicycling Discussions | 33 | 2006-02-07 02:18 PM |
| School Project (re-try) | Notch | General Unicycling Discussions | 3 | 2005-02-23 12:27 AM |
| Tinker Project | tron | General Unicycling Discussions | 7 | 2003-07-17 09:49 AM |
| Unicycle Project | falling_star143 | General Unicycling Discussions | 3 | 2001-05-16 10:26 PM |
