Unicyclist Community
Reply
Old 2006-04-13, 04:26 PM   #1
koebwil
Registered User
koebwil's Avatar
CF Base Drilling?
I just got a CF base from UDC. I need to drill the holes. What is the best way to drill them?
__________________
"I used to eat erasers in grade school...." James_Potter
come to my gallery.
I'm on my space now too
koebwil is offline   Reply With Quote
Old 2006-04-13, 05:21 PM   #2
underdog
Most of the level 3 stuff now
underdog's Avatar
With a drill?
__________________
'I tell you, we are here on Earth to fart around, and don't let anybody tell you different' - Kurt Vonnegut
underdog is offline   Reply With Quote
Old 2006-04-13, 05:28 PM   #3
maflitto
Registered User
are there premarked holes on the carbon fiber base for drilling? I plan on getting one soon since my seat flexs way to much
maflitto is offline   Reply With Quote
Old 2006-04-13, 05:56 PM   #4
entropy
Dropped
entropy's Avatar
Link to john_childs' instructions on how to drill out a carbon fiber (cf) base.
john_childs wrote a very good post about this, but it took me a while to find it originally:
http://www.unicyclist.com/forums/sho...13&postcount=3
That's what I used to figure out how to best drill my CF base, and it came out quite well.
entropy is offline   Reply With Quote
Old 2006-04-13, 06:30 PM   #5
unijesse
Registered User
unijesse's Avatar
also, scroll all the way down the page.
__________________
They put on panda suits and then pretend they're milking a cow. It's art. You wouldn't get it.
><> Unicycle For Christ <><
unijesse is offline   Reply With Quote
Old 2006-04-13, 06:55 PM   #6
koebwil
Registered User
koebwil's Avatar
Is there a way to put the nuts on the inside and have the bolts go from the bottom up into the seat?
__________________
come to my gallery.
Old 2006-04-13, 07:31 PM   #7
maestro8
is what it is
maestro8's Avatar
Quote:
Yeah. Scott Wallis has some flanged, threaded inserts (i.e. nuts without the hexagonal shape) that he epoxies into the seat base... kinda sorta like the one you see in the lower right of this image:
If you find one of these you just need to drill a hole large enough for the threaded collar to go through, then epoxy the flange to the top of the seat base (where the seat foam will sit). You'll need to ensure your epoxy job is spot-on (the surfaces mate perfectly with each other, are prepped and cleaned, the epoxy does not have bubbles, etc.) otherwise you could torque them right off when tightening the screws. The larger the flange you can find, the better off you'll be.
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2006-04-13, 07:38 PM   #8
entropy
Dropped
entropy's Avatar
Not with carriage bolts.
You could loosely follow these directions from George Barnes, and just install all the nuts & bolts upside-down:
http://www.gb4mfg.com/gb4/air_seat.pdf
Keep in mind that if it isn't securely fastened and something comes loose, you may have to remove the bumper, handle, seatcover and pad in order to re-tighten the base bolts / nuts.
Old 2006-04-13, 07:39 PM   #9
koebwil
Registered User
koebwil's Avatar
I will definately look for those. Thanks.
__________________
come to my gallery.
Old 2006-04-13, 07:45 PM   #10
koebwil
Registered User
koebwil's Avatar
I like the idea of a rubber bumper between the post and the base.
__________________
come to my gallery.
Old 2006-04-13, 08:39 PM   #11
kington99
Registered User
Send a message via MSN to kington99
You can get rivnuts which are threaded tubes which are deformed to hold themselves in place with a rivnut gun, ive used them exstensively on fibreglass and they're pretty good, tricky to get hold of tho.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2006-04-13, 10:34 PM   #12
john_childs
Guinness Mojo
john_childs's Avatar
Max Dingemans (from the TCUC) uses the T-nuts in the carbon fiber base. The T-nuts are designed to be pounded into wood (it's the one in the above picture on the black square). For use on the CF base you cut off three of the prongs. Drill a round hole for the threaded part and cut a slot for the remaining prong. That remaining prong will keep it from spinning. Then file down the excess that is sticking up on the other side of the CF base.
The T-nut thing might be good if you're using a foam seat. I don't think it would be good for an air seat because the nut and bolt will stick up into the inside of the seat and that would be bad for the tube.
I haven't tried the T-nut option. The advantage is that it would be lighter than the carriage bolt option (carriage bolts are heavy).
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2006-04-14, 04:11 AM   #13
mango
unity - as 1 stand together
mango's Avatar
Send a message via AIM to mango
Alot of good stuff being said...
Heres one more thing to keep in mind: the little dots/indentations that are on the cf base when you get it that are kind of the suggested places to drill the holes can be wrong. Just ignore those are measure where to drill the holes. Take your time. Thats it.
__________________
Neener, neener, neener. -harper
mango is offline   Reply With Quote
Reply
Tags
base, drilling
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ode to Scott - my sweet new CF base Jester2000 General Unicycling Discussions 9 2006-02-22 12:23 AM
[Wanted] CF seat base daino149 Trading Post 4 2005-09-28 01:31 PM
Spinning bolts on CF seat base Checkernuts General Unicycling Discussions 10 2003-09-14 11:09 PM
Need Help Drilling out CF seat base Checkernuts General Unicycling Discussions 2 2003-09-02 09:22 PM
CF BASE, I need help now. The Munieer General Unicycling Discussions 2 2003-01-07 08:49 PM
Copyright © 2001-2005 Gilby
Page generated in 0.11462 seconds with 10 queries
