Unicyclist Community
Reply
Old 2006-04-12, 10:31 PM   #1
Sponge
ゴールデン!
Angry Crank coming loose on spindle too fast...
Hi all, I'm using a Profile hub and 145mm crankset, and basically what's wrong is that the left crank seems to slide on and off really easily, literally I can slide it about with my fingers. I never thought it should be this easy, and it seems when I tighten the crankbolt for it, the left crank seems to develop a little bit of play after a while of hopping around.
I put copper grease on both the hub spindle; and, the threads of the crankbolt. Should I put blue loctite on the crankbolt thread or something?
Here's my theory: I think that since the left crank slides on and off soo easily on the hub spindle, it hasn't got anything to hold it still except for the crankbolt, so all the vibration from hopping may have shaken the crankbolt a little looser, making the crank develop a little bit of play/wobblyness. I am pretty sure that a profile crank is meant to be pretty tight fitting onto the spindle 'cos that's meant to help keep it in place isn't it?
Would appreciate any help from you guys
Sponge is offline   Reply With Quote
Old 2006-04-12, 10:34 PM   #2
manon1wheel
dude...
manon1wheel's Avatar
Send a message via AIM to manon1wheel
mine is doing the same thing... accept i have the torker splined cranks and hub.
like when i idle i can feel some play..
sory to thread jack but i felt this was the right thread to put it in.
thanks-Riley
manon1wheel is offline   Reply With Quote
Old 2006-04-13, 03:11 AM   #3
giraffe
trials and street to the death
giraffe's Avatar
Send a message via MSN to giraffe
my profiles slide off by hand..
__________________
Quote:
Originally Posted by evil-nick
Trials biker after seeing me jump off a concrete barrier: "How do you keep from squashing your nuts!?"
Me: "I use those for cushioning!"
giraffe is offline   Reply With Quote
Old 2006-04-13, 04:24 AM   #4
dan de man
Byronic hero
dan de man's Avatar
Send a message via MSN to dan de man
profile?
__________________
[QUOTE/into the blue]Am I the only one who finds it incredibly egotistical when someone sigs themselves?
[QUOTE/dan de man]yes , yes you are
dan de man is offline   Reply With Quote
Old 2006-04-13, 05:00 AM   #5
TheObieOne3226
***** Member
TheObieOne3226's Avatar
Send a message via AIM to TheObieOne3226 Send a message via Yahoo to TheObieOne3226
If you haven't already, buy some anti-sieze from an auto store ($2 for 3 year supply). Take both your cranks off and all the spacers. WD-40 the splines and insides of the cranks and then wipe everything down to bare metal with a clean rag or paper towels. Then liberally coat the axle splines with anti sieze and wipe away excess (but be sure all splines are covered). Slip the spacers and cranks back on. Put anti sieze on the crankbolts and torque them down hard. They should be silent and smooth for a while.
I got this method from John Childs. It works really really well. Everytime your uni starts to squeak, break it all down and redo it. Its fun too.
__________________
SWAT Gallery
SWAT webpage
Arrow Racing
Sixsixone
"Obie is definately a trend setter, I got in to unicycling because of him, and came here because of him" - KJ-52
"try not to annoy the great Obie, for he is better than us." - Murde Mental
Disclaimer: The above message was not intended to offend anyone. If you are offended I can take no responsibility for my actions because I don't feel like it. Also you are reading an internet newsgroup where not everyone will share your same views and beliefs, be able to take criticism and post/read threads at your own risk.
TheObieOne3226 is offline   Reply With Quote
Reply
Tags
coming, crank, fast, loose, spindle
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
loose crank gregs dad General Unicycling Discussions 3 2005-07-19 11:18 PM
Crank Coming Loose Robbie General Unicycling Discussions 6 2004-02-25 08:49 AM
loose crank: why always the right one? fme General Unicycling Discussions 6 2003-04-04 07:17 PM
20 inch cranks always coming loose. Charles General Unicycling Discussions 4 2002-03-27 01:22 PM
Loose crank Scott & Jody Arnold & family General Unicycling Discussions 2 2000-10-21 01:44 PM
Copyright © 2001-2005 Gilby
Page generated in 0.07437 seconds with 10 queries
