#1 |
No tricks, just rides
Pondering on a Schlumpf - questions
There's a distinct possibility of me breaking my new years resolution of buying another unicycle. I bought a 24" muni last year, a 6ft giraffe the year before, and a 20" freestyle in 2003.
I think my next venture will be some kind of 29er for long pavements and roads, and let's be honest... I want to go for broke and get a Schlumf geared uni. First question (possibly stupid): is it possible to idle and ride it backwards? I'm thinking if I need to idle it in case of sudden obstructions ahead, somehow my mind says it may not be possible with geared mechanisms. Second question: as seen in this picture the hub clearly says "please read instructions carefully, especially for off-road and free-riding". What exactly are the issues when it comes to off-road riding? Smooth-ish gravel tracks will be the roughest terrain I plan to ride it on, so I'm more curious that worried. Third question: what size cranks do you recommend? I'm so used to the 150mm cranks on my 24" muni that the 127mm ones on my freestyle feel so twiddly and small for my extra long legs (34"-35" inseam). I was thinking about 140mm but that doesn't seem to be an option on unicycle.uk.com, so it's gonna have to be 127mm or 152mm...
__________________
"Well, not everything is as practical as making your cranks flip around I guess." - Brian MacKenzie "If its wet, it won't hurt as much when we fall off." - Eddbmxdude |
#2 |
Registered User
I'd wait for the splined version coming out later this year.
__________________
"What doesn't kill you strengthens you, what kills you strengthens your mother" |
#3 | |
Quote:
Yes I am aware that Kris Holm Unicycles has joined up with Florian to make a splined geared Muni (I've read the Moab threads) which could be available in 29er size as well. However, this is a long pavement/road machine that I have in mind (nothing extreme) so the current Schlumpf will do just fine for me.
__________________
#4 | |||
Unicyclist.com Webmaster
Quote:
Quote:
Quote:
And no, you don't have to wait for the splined one if you are doing long distance riding or communting.
__________________
Get educated about the legitimacy of government. |
#5 | |||
New York Unicycle Club
Quote:
Quote:
Kidding aside, yes, you can ride it just as a regular uni. Proviso: In high gear, it's really hard to ride backwards or to idle. Since you mention that you're not going to be 'off-roading' a lot, I'd go for the less expensive guni that's available now rather than waiting for the uber-hub coming out this summer. But if you foresee lots of curbs (kerbs, I mean) in your future, or other slight drops, perhaps it'd be best to wait. Quote:
If you have lots of uphills in your future, either get the 127s and plan to downshift a lot, or get the 152s and leave it in high gear when possible.
__________________
Dictator for Life, NYUC Check out my blog (or else): http://newyorkunicycle.blogspot.com/ |
#6 | |
dumb blonde
Quote:
They do sell 140mm cranks for it according to schlumpf.ch, so I'm sure Roger from unicycle.com can get hold of them. I've got one, and I'd say that it really might be worth waiting for the KH one. Not because of the hub, you probably don't need a splined hub for what you're talking about, but for the frame. I think the new hub comes with a cunning torque lever attachment so that you can use a standard and well tested KH frame, rather than having to use the Schlumpf frame. From the brief amount of riding I've been able to do on it, I'm happy with the hub, but the frame was poo. It broke after five hours riding. Snapped through. According to Schlumpf, I think it's because the instructions didn't tell you that you need to torque up the 8 bolts to adjust the seatpost exactly right or something. In the case that you don't, the very thin braces holding the seatpost can snap right through. I'd not trust it for any long ride, unless you ride with a support crew, you really need to be confident that you're not going to be left unable to ride 50 miles away from home, that could be one expensive taxi ride. Even without that, the frame is rubbish for several reasons. Firstly, there are 8 bolts you need to undo to adjust the seatpost. Which all have to be tightened up exactly right or else it'll spontaneously snap after a few hours riding. Secondly it's a very tall frame, I'm normal sized (5ft 10) and I was hitting the frame sometimes on mounts, it's about 4 inches taller than a Nimbus 29" frame. I'm currently still waiting for a replacement frame, which hopefully will be different to avoid these issues, but I've not been able to ride mine for about four months now. From my riding, it's easy to idle in slow mode and okay in fast mode, kind of like idling a coker, except with a little bit of backlash each time you idle, kind of like when the cranks are loose on a normal uni. You can ride it backwards just fine. Cranks wise, I'd suggest start off with something like 150s, if you're not used to riding a big wheel with short cranks already. Joe |
#7 | |||
Quote:
Quote:
Quote:
__________________
#8 | |
Quote:
__________________
#9 |
Wow, Gilby. Thanks. That design is really different, and I can see why someone would be unhappy with it. I also notice that the part that holds the hub (at the bottom of the frame) is different, too.
__________________
#10 |
Registered User
Glad to see this conversation, it's answering a few questions for me too. I am considering a Shlumph and have decided to wait for the KH splined version.
Mainly because I do easy trail (canal tow path) riding with a few shallow steps and sometimes end up with loose cranks after a few miles. Splined is just so much a better engineering solution to the problem than squeezing a taper in soft metal. Also I must consider that one day I might be somewhere I want to take it off road or can't resist a few drops and I wouldn't want to be worried about breaking several hundreds of pounds worth of uni, better eliminate that possibility and get the best I can afford first time round. This has proved true with my other unis, I started with low spec stuff and within months ended up making expensive upgrades. I would like to know though, if anyone knows yet, will I be able to buy the hub and have it built into a setup I already own? Andy |
#11 | |
My avatar is a toilet
Quote:
__________________
"...if a bunch of fellow unicyclists can't rally around, commiserate and say 'chin up, lad', then what is this world coming to?" -GILD |
#12 | |
Ridin' my KH
Quote:
I never idle or go backwards on my Coker unless I'm specifically trying to, and I only do that when I have lots of space. When commuting or otherwise Cokering, If something gets in my way I'll either go around, or stop. No problem. I guess that's what I would do on a bike anyway.
__________________
John Foss Email: "jfoss" at "unicycling.com" -- www.unicycling.com ----------------------------------------------- "I ride unicycles against the orders of my doctors. I have six screws and a plate to help hold me together." -- Bungeejoe, 52 |
#13 |
Team UDC Canada!
This answered a lot of questions for me as well. I can't blame you guys for not stress testing your really expensive unis, but if I can't be rolling off/hopping up curbs I think I'll wait for the kh hub and be able to do what I want with it, peace of mind intact.
#14 |
My questions were answered, but dilemmas are increasing about the square-tapered-Schlumpf-now versus splined-KH/Schlumpf-later.
There seem to be mixed opinions about the abuse it can take. Some people here seem to say that simple kerb-dropping can damage it, whereas it seems to be warrantied for drops up to 3 metres and Gilby hops up stairs with his. I do envisage riding down the odd kerb every now and then with whatever I buy. But are they talking about breaking the hub, or just the fact that the square-tapered cranks would need tightening regularly if kerbs did form part of the ride? I did look at David Stone's problem with his loose crank, and it seems the gear-shift buttons being where the crank nuts should be means that the supposedly simple maintenance task of tightening cranks becomes bloody complicated. I've seen pictures of the frame and I do agree its a bit strange, having just two arms holding onto the seatpost instead of it being inside a long tube. Being about 6' 2" with a 35" inseam, the height isn't a problem for me. I started this thread now because if I were to get one now, I'd collect it at the British Unicycle Convention which is in about a months time, as the prospect of putting something very expensive into the hands of people like ParcelForce frightens me. But if I were to wait for the splined one, it doesn't seem to be that long of a wait. Kris Holm sets a target for "July" or "late summer"... for the US I presume. It would take longer than that to reach the UK, it would be about halfway between British Unicycle Conventions. $1600 uni in the hands of people like ParcelForce??? Decisions decisions...
__________________
#15 | |
Quote:
__________________
| Tags |
| pondering, questions, schlumpf |
Similar Threads
| Coker, Schlumpf 29er, or Schlumpf 36er | siafirede | Rec.Sport.Unicycling | 9 | 2005-11-11 11:37 PM |
| Schlumpf vs. Livewire | Brian MacKenzie | Rec.Sport.Unicycling | 10 | 2005-08-25 11:18 PM |
| pondering a move to the PAC-NW | markf | Just Conversation | 9 | 2005-08-06 11:06 AM |
| Uni Newbie still pondering | Jason Neumann | Rec.Sport.Unicycling | 7 | 2002-05-31 08:48 PM |
