Unicyclist Community
Reply
Old 2006-03-18, 09:12 AM   #1
silverfridge
MUnicyclist:-King of the Mountain
silverfridge's Avatar
Damn, i have broken a seat post bolt in the seat, but it is not a removablecover help
yeah, i overtightened one bolt and snapped up inside seat, but the cover isn't removable. what can i do, can i leave it?
__________________
To be or not to be?
You misunderstood, I want a 2B pencil
silverfridge is offline   Reply With Quote
Old 2006-03-18, 09:43 AM   #2
kington99
Registered User
Send a message via MSN to kington99
You can remove the cover by pulling all the staples out aslong as you have some way of restapling it back afterwards. You could always buy a fusion seat cover to replace the stapled one that you have removed, they're a tight fit btu they wil go over the standard seat foam. If you ride hard on only 3 bolts you will eventually destroy the seat much quicker than if there were four, and the seat will flex more aswell. Basically if you don't want to risk home surgery on your seat just ride it until it breaks and then get a new one, not muhc else you can do.
__________________
Dave
- what a thoroughly post-modern subversion of the cycling genre -
kington99 is offline   Reply With Quote
Old 2006-03-18, 03:38 PM   #3
flyer
Team UDC Canada!
flyer's Avatar
I have one of those staple guns, the silver kind you squeeze to put a staple out. I replaced the cover on my KH seat recently because my seat cover broke. Took five minutes to staple it back on (using new staples). I wouldn't do it more than once or twice because you'd weaken the plastic where you have to staple it back in, but it will work for a one-time repair. Just make sure you get it right
flyer is offline   Reply With Quote
Old 2006-03-19, 02:20 AM   #4
ntappin
Ask me about the Ottawa unicyclists
ntappin's Avatar
Send a message via MSN to ntappin
If you want you could take off the cover, then make a new cover. If you use the search function there are quite a few cover threads. That is probably the easiest and the fastest way of doing it. It is definatly the cheapest.
ntappin is offline   Reply With Quote
Old 2006-03-19, 05:29 AM   #5
muzzle
UNI branded
muzzle's Avatar
assuming that its a KH style seat (and i'm not only referring to the fusion), the cover IS removable (as other people in this thread have pointed out)... pull out the staples and put new ones in when your done, i have done this and its very quick.
the new bolt was cheap as hell from the local hardware and stronger than the original. while your at it you can make other seat mods
of course, there is some saddles which the cover is clearly NOT removable... but then its not worth keeping anyways
muzzle is offline   Reply With Quote
Old 2006-03-19, 08:47 AM   #6
max_pfeifer
balls of steel
max_pfeifer's Avatar
One of my saddle bolts snapped off a few months ago and apart from a bit more flex it is fine.
__________________
Nobody cares about threats over the internet.
Don't try to act hardcore with the keyboard.
Fighting online is like racing in the special olympics;
even if you win, you're still retarded.
max_pfeifer is offline   Reply With Quote
Reply
Tags
bolt, broken, damn, post, removablecover, seat
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Anyone broken the KH Rail Seat Post yet? pete66 General Unicycling Discussions 21 2006-04-13 10:20 AM
Broken seat post. Question about new one Rockey General Unicycling Discussions 1 2003-03-16 09:00 PM
Broken Seat Post Mojoe General Unicycling Discussions 12 2003-03-13 06:28 AM
broken seat post Seth Golub General Unicycling Discussions 2 2000-08-30 04:14 PM
Broken Seat Post removethis.reed8990@uidaho.edu General Unicycling Discussions 2 2000-08-30 03:14 PM
Copyright © 2001-2005 Gilby
Page generated in 0.06643 seconds with 10 queries
