Unicyclist Community
View Poll Results: Do you often land on your bearing housings?
Often 12 42.86%
Seldom 7 25.00%
Almost Never 9 32.14%
Voters: 28. You may not vote on this poll
Reply
Old 2005-09-07, 05:41 PM   #1
UNIquelyCanadian
Static Long Jump ~ 2.0 Meters
UNIquelyCanadian's Avatar
Do some people use their bearing housings as platforms to land on like pedals and cranks? In general are bearing housings very strong, to prevent the bearings from being crushed?
I have only landed on my bearing housings a couple of times in all my practice of learning crank grabs and pedal grabs, should I not worry about damaging the aluminum ones on my KH20 05?
__________________
~Cameron
New Photos: www.camerondonaldson.com
“When someone tells you there is no such thing as truth, they are asking you not to believe them. So don’t.”
- Dr. Roger Scruton
UNIquelyCanadian is offline   Reply With Quote
Old 2005-09-07, 05:56 PM   #2
harper
768 - It's in your DNA
harper's Avatar
I voted often, although it is unintentional. My imprecision doing crank grabs is hard on my bearing housings
__________________
-Greg Harper
Destroying the climate by shutting down nuclear power plants, one by one, since 1979.
JC is the only main man. There can be no other.
"A fool on a unicycle is redundant" - J.D. Miller
harper is offline   Reply With Quote
Old 2005-09-07, 07:48 PM   #3
Butty
bout level 5/6 )-0
Butty's Avatar
Send a message via MSN to Butty
is your side hop --> from a rolling or just from a stil stand
__________________
yer you're right, but only when i say you are )-o
Butty_74@hotmail.com add me!!
My Web Page
Butty is offline   Reply With Quote
Old 2005-09-07, 07:57 PM   #4
caw89
Above your simple levels!
caw89's Avatar
Send a message via AIM to caw89 Send a message via MSN to caw89 Send a message via Yahoo to caw89
I think I ofund why my bearings are screwed up
__________________
Uniclips Updated Sept
AIM: unicaw89
Quote:
Originally Posted by abbabibble
Cody bent his koxx.
he was working it pretty hard.
caw89 is offline   Reply With Quote
Old 2005-09-07, 08:02 PM   #5
Sigurd
Aspiring street/trials unicyclist.
Send a message via AIM to Sigurd Send a message via Yahoo to Sigurd
All the time, every time. Still in good shape (Summit).
Sigurd is offline   Reply With Quote
Old 2005-09-07, 08:04 PM   #6
cegli
Slowly Getting Better
cegli's Avatar
I accidentally land on them all the time, and they've been fine so far. I ride a Onza 24" with the '05 KH/Onza hub which is the same I believe.
__________________
I like to unicycle.
cegli is offline   Reply With Quote
Old 2005-09-07, 08:05 PM   #7
bugman
NAUCC 2006 Memphis
bugman's Avatar
I hit my bearing housing occasionally while mounting. Though it hurts like hell, I can see no permanent damage occurring.
bugman is offline   Reply With Quote
Old 2005-09-07, 08:07 PM   #8
fexnix
I got infinite skillz
fexnix's Avatar
Send a message via MSN to fexnix
I think They should make steel bearingshousings for the KH
that would not be a very big amount of weight and it would make them very bombproof.
__________________
My 29er page
My fresh album
fexnix is offline   Reply With Quote
Old 2005-09-07, 08:26 PM   #9
UNIquelyCanadian
Butty: my sidehop (longjump) is from a static standstill, seat in. I've been trying to learn rolling long jump but as yet I don't jump any further then static.
bugman: You need to read threads more carefully to determine the subject matter.
__________________
~Cameron
- Dr. Roger Scruton
Old 2005-09-07, 08:29 PM   #10
skicker
Registered User
bearing housings?
is that a euphemism for something?
skicker is offline   Reply With Quote
Old 2005-09-07, 10:16 PM   #11
skate4flip
Street Freestyle
skate4flip's Avatar
Send a message via AIM to skate4flip Send a message via MSN to skate4flip
When i used to do crank grabs i sometimes got on my bearing holders, but now i learned pedal grabs and i never land on them because the pedal is farther from the bearing house then the crank is. I land on my bearing holders when i grind sometimes though.
__________________
Reply 23K, 25K, post 29K, reply 37K, post 41K, post 47K, and reply 61K in most replys!!!
My Gallery UPDATED 06/19/07
skate4flip is offline   Reply With Quote
Old 2005-09-09, 01:43 PM   #12
MrBoogiejuice
Now with added jazz croutons!
MrBoogiejuice's Avatar
Send a message via Yahoo to MrBoogiejuice
I totally agree. My KH 05 frame is a bit knackered due to the bearings wearing down the inside of the bearinghousings. Now the frame has some give around the bearing and squeaks which is pretty frickin annoying. When I next have some spare pennies I'm going t get a rowing frame rather than a KH 05 one. Don't think I could be convinced to get another alu frame in a hurry.
__________________
---unicycle for The Very Hungry Caterpillar---
Make crumbs not War!
You can't polish a turd but you can roll it in glitter.
MrBoogiejuice is offline   Reply With Quote
Old 2005-09-10, 01:30 AM   #13
gerblefranklin
Registered User
I used to hit mine when doing long pedalgaps to my crank. Now I hit the pedal instead, so no more issues. I'd be more worried abut destorying my pedal than I would be about destroying my bearing housings. If you are hitting your housings, also look out for damage to spokes/flanges.
You can always make your own steel bearing housings. It's not that hard, just might take you a couple days (3-5 hours per, assuming a manual mill).
gerblefranklin is offline   Reply With Quote
Old 2005-09-10, 02:52 AM   #14
m_extreme_uni
Registered User
m_extreme_uni's Avatar
I think that when you are doing pedal grabs, if you rotate the cranks in the air (so that they're vertical) you end up hitting your crank, and then falling onto your pedal (if it's not very accurate) so then, you not only maximize your vertical pedal grab, but you minimize contact with the bearing housing.
As far as the KH frame goes, i know Kris made an extra thick bottom main cap, so that this didn't happen, and on my frame, so far it's been perfect. I've done thousands of pedal grabs, and big gaps to pedal grabs, and the housings are great. But that's just me.
-Ryan
__________________
"Yeah, Gravity is bad" Leo Kottke
m_extreme_uni is offline   Reply With Quote
Old 2005-09-10, 12:05 PM   #15
DarkTom
Get up on your roof!
DarkTom's Avatar
I have an 05 onza trials and I land on the bearing housings all the time. They're a bit bashed and scratched but this hasn't hampered their performance any.
I have however bent the black disc thing that goes between the crank and bearing and covers the side of the bearings (flange?) so that it rubs into the frame and was wearing into the metal of the frame. If I span the wheel (not on the ground) it would stop when the bent bit got to the frame and rubbed into it.
A hacksaw soon fixed this tho. (I cut the bottom half of the disc off)
T.
__________________
"DarkTom of Glasgow, one of the few uni riders here that you really musn't mess with" - GkMac
"mondeos can fly" - Pebbles
24" uni for sale
koxx/onza trials uni for sale
DarkTom is offline   Reply With Quote
Reply
Tags
bearing, housings, land
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.11515 seconds with 10 queries
