Unicyclist Community
Reply
Old 2005-06-18, 05:42 PM   #1
skate4flip
Street Freestyle
skate4flip's Avatar
Send a message via AIM to skate4flip Send a message via MSN to skate4flip
Tight Turning help
Hi, i just started posting here and i have a problem with doing tight turns 180 and 360 degrees for levels 3 and 4. I searched the forum a little bit and did not find anything that helped. The first thing i noticed when i was practicing 180 degree turns was that i always ended up standing up on the pedals to twist my body. Is that normal to do? I dont have a low seat so I dont think it is because of that. I practice in the street, is it easier on different surfaces? My last problem is that sometimes my pedal hits the ground when i turn which throws me off the unicycle.
If anyone has a tips for me or you learned to turn in a tighter circle, please post them. Thanks.
skate4flip is offline   Reply With Quote
Old 2005-06-18, 05:58 PM   #2
john_childs
Guinness Mojo
john_childs's Avatar
Re: Tight Turning help
Quote:
What size wheel and what length cranks?
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-06-18, 09:20 PM   #3
skate4flip
Street Freestyle
skate4flip's Avatar
It is a 20" wheel and 150mm cranks (pretty sure its 150).
Old 2005-06-18, 11:08 PM   #4
johnfoss
North Shore ridin'
johnfoss's Avatar
Practice riding in small circles. Learn to do it with continuous pedaling, not with a stop-start motion. This may be a little tough with your long cranks, but with practice you'll learn how much you can lean without touching your pedals to the ground.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2005-06-18, 11:14 PM   #5
podzol
"Not I," said the duck.
podzol's Avatar
Skate 4 flip,
I'm working on the very same thing and have been practicing the advice John Foss gave me in the figure 8 thread.
It works. I actually made myself dizzy today! That was unnerving, but it made me feel that I was on the right track!
I get my 20" on Tuesday, so that will make it a bit easier. Now on a 24"
Blake
podzol is offline   Reply With Quote
Old 2005-06-19, 12:27 AM   #6
flyer
Team UDC Canada!
flyer's Avatar
Yup, I learned pretty quick to turn in a smooth circle once I had to pass level 4 and turn in a small (1m) circle 360 degrees.
The best part is that I accidentally hit a spin one day while doing this, and have been doing it since. Pirouettes are great, and the tire tracks I leave on pavement surely must confuse the heck out of people who come upon them later.
flyer is offline   Reply With Quote
Old 2005-06-19, 03:36 AM   #7
skate4flip
Street Freestyle
skate4flip's Avatar
Hey thanks for the posts everyone. I tried searching the forum for the figure 8 thread and didnt see it. Could you send me a link Podzol? Thanks.
Old 2005-06-19, 03:48 AM   #8
podzol
podzol's Avatar
Hi Skate,
You can find the thread if you search for " 8's ".
However, this is the sage advice of John Foss:
Practice spins; riding in small circles. At first, you will notice your tire makes an inconsistent scuffing noise, as your circle has "corners" on it. The more you can smooth out your riding, the more constant the tire noise will be.
Practice riding into and out of sharp turns (not necessarily fast). You only need to be leaning when you're making the turn. Try to keep your body more or less in line with the frame, from side to side, rather than tilting toward the inside. Instead, turn your upper body in the direction you want to go. In other words, if you're circling to the right, put your left shoulder forward so your upper body faces into the circle.
Repeat until you get dizzy.
Funny thing is I actually did get dizzy!
Blake
__________________
John Foss, the Uni-Cyclone
"jfoss" at "unicycling.com" -- www.unicycling.com
"Read the rules!" -- IUF Rulebook -- USA Rulebook
Old 2005-06-19, 05:28 AM   #9
skate4flip
Street Freestyle
skate4flip's Avatar
Thanks for the thread. Where do you practice your riding? (I practice in the street). The advice from the thread helped quite a bit but i still can not get my turn in a 1 meter circle. Will it come after practicing more? How long did it take you to learn it?
Old 2005-06-19, 05:49 AM   #10
podzol
podzol's Avatar
I can't do it smoothly in a meter circle at all, but I can do it. Mine is still a choppy series of reaction turns.
Today the times the turning technique right, it felt completely different. I felt like the unicycle was layed out pretty flat. Do you snow board? It really had the smooth digging-in feeling that a hard carve has. A dynamic equilibrium situation. It was completely different than the spastic twisting I usually end up doing!
I rode for sevral years as a kid. I was the only unicyclist I had ever met, so I didn't learn many tricks. I took a 20 odd year break and have been just getting into it the past couple months. Now I'm wrapping up level 3 and well on my way to level 4, just the pesky turns.
I actually learned my level 4 mount today, too. I did the jump mount. For level 3 I did the side mount. (unofficial levels).
Blake
Old 2005-06-19, 05:57 AM   #11
skate4flip
Street Freestyle
skate4flip's Avatar
I have only snowboarded a few times but i going this winter. I skateboard alot more, so i pretty much know what you mean. Now that i have better techinuque, I think the only thing to do is practice and practice. Good luck with your turning.
Old 2005-06-19, 11:13 PM   #12
Klaas Bil
Newsgroup User
Posts: n/a
That combination is indeed prone to pedal strikes. Try retrofitting
shorter cranks, e.g. 125 mm, or 140 mm max.
Klaas Bil - Newsgroup Addict
"As with all great social movements, the origins of mountain unicycling are unclear. - Hannah Nordhaus (Los Angeles Times)"
Reply
Tags
tight, turning
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.22885 seconds with 9 queries
