Unicyclist Community
Go Back   Unicyclist Community > General Discussion > Rec.Sport.Unicycling
Reply
Old 2005-05-09, 11:13 AM   #1
TonyMelton
Proud owner of Kris Holms old shoes
TonyMelton's Avatar
Question Lacing a 28 hole rim to a 36 hole hub
Is it possible to lace a 28 hole rim to a 36 hole hub? The reason I ask is that I can get hold of an 18" rim and tyre, and would like to try building it up into a unicycle.
Has anyone done this before?
TonyMelton is offline   Reply With Quote
Old 2005-05-09, 11:55 AM   #2
napalm
Because i can.
napalm's Avatar
hey tony- i had the same problem as you, although it was the inverse situation. I had a 28 spoke hub and rim set on my crappy beginner unicycle and when i killed it i cold not get a 36 hole rim laced into it. Hope this saves you time and frustration,
MArk
napalm is offline   Reply With Quote
Old 2005-05-09, 01:42 PM   #3
rob.northcott
Mainly XC Muni
rob.northcott's Avatar
I think it could be done. All holes in the rim would be used, and each side of the hub would have 3_4_3_4_ holes used (where the _ is an unused hole). I can't think quite how the spoke lacing would end up, but I'm sure it could be made to work.
Rob
rob.northcott is offline   Reply With Quote
Reply
Tags
hole, hub, lacing, rim
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2001-2005 Gilby
Page generated in 0.31125 seconds with 9 queries
