Unicyclist Community
Reply
Old 2005-04-27, 12:25 AM   #16
Catboy
Roadkill
Catboy's Avatar
Send a message via ICQ to Catboy Send a message via AIM to Catboy Send a message via MSN to Catboy
Quote:
Originally posted by andrew_carter
After looking at it a second time I've noticed that the frame may not freely rotate from the foot plates. Even so, I'm guessing that any significant braking force will transfer into the frame and (if they're connected) the plates and make the whole thing roll under your feet.
My thoughts exactly. It looks like it could throw your forwards while braking.
__________________
Rest in pieces.
Catboy is offline   Reply With Quote
Old 2005-04-27, 12:27 AM   #17
john_childs
Guinness Mojo
john_childs's Avatar
You could use a front BMX fork mounted the same way. A BMX fork would already have the brake posts for mounting the brake.
If you can find an aluminum BMX fork you would weld it to the aluminum BC plates. If you've got steel BC plates you could use a steel BMX fork. But the way you've got the thing mounted avoids the need to weld to the BC plates. Either way would work.
Cool stuff.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-04-27, 12:28 AM   #18
cyberpunk
Unicycle for Secularism
cyberpunk's Avatar
Send a message via AIM to cyberpunk Send a message via Yahoo to cyberpunk
I can finnaly BC down that crazy hill without going into the river at the bottom.
Thank you Evan.
(truth be told I don't even own a BC, too broke)
cyberpunk is offline   Reply With Quote
Old 2005-04-27, 12:29 AM   #19
TheObieOne3226
***** Member
TheObieOne3226's Avatar
Send a message via AIM to TheObieOne3226 Send a message via Yahoo to TheObieOne3226
I'm gonna have a little faith and say it will work. Think about it...you don't want to lock the wheel from a full speed ride...you're not trying to BC skid. You apply a little bit of pressure and your weight keeps the frame upright.
__________________
SWAT Gallery
SWAT webpage
Arrow Racing
Sixsixone
"Obie is definately a trend setter, I got in to unicycling because of him, and came here because of him" - KJ-52
"try not to annoy the great Obie, for he is better than us." - Murde Mental
Disclaimer: The above message was not intended to offend anyone. If you are offended I can take no responsibility for my actions because I don't feel like it. Also you are reading an internet newsgroup where not everyone will share your same views and beliefs, be able to take criticism and post/read threads at your own risk.
TheObieOne3226 is offline   Reply With Quote
Old 2005-04-27, 12:35 AM   #20
Evan Byrne
Why am i here? I dont unicycle.
Evan Byrne's Avatar
Send a message via AIM to Evan Byrne Send a message via Yahoo to Evan Byrne
exactly, you would only apply a little braking at a time, just lean back when you apply it.
Evan Byrne is offline   Reply With Quote
Old 2005-04-27, 12:46 AM   #21
jiheison
Registered User
Question
What brake/brake mount are you using?
jiheison is offline   Reply With Quote
Old 2005-04-27, 12:48 AM   #22
TylerHeartless
jud jud FRANK!
TylerHeartless's Avatar
Send a message via AIM to TylerHeartless
Thumbs up
Looks sweet good work.
TylerHeartless is offline   Reply With Quote
Old 2005-04-27, 12:51 AM   #23
Evan Byrne
Evan Byrne's Avatar
The brake mount is called "Big cheese"
Old 2005-04-27, 12:51 AM   #24
TheObieOne3226
***** Member
Big cheeeeeeese...
Big beaten...
__________________
SWAT Gallery
SWAT webpage
Arrow Racing
Sixsixone
Old 2005-04-27, 12:52 AM   #25
UniTyler
Registered User
[threadjack]
Evan, what uni is that in your avatar?
[/threadjack]
UniTyler is offline   Reply With Quote
Old 2005-04-27, 12:52 AM   #26
KcTheAcy
Ohh Baby
KcTheAcy's Avatar
Nice job, I had thought of making one, but didn’t have the stuff, My idea was to have a comfy pad that goes behind your legs to support the break similar to the pads that you rest you arms on on aero bars. That would any problems of the platforms turning under your feet. Either that or those full sized Bedford platforms would give added control when breaking.
KcTheAcy is offline   Reply With Quote
Old 2005-04-27, 12:54 AM   #27
Evan Byrne
Evan Byrne's Avatar
Tyler
Old 2005-04-27, 12:58 AM   #28
jiheison
Registered User
Thumbs up
Quote:
Many thanks!
Old 2005-04-27, 01:07 AM   #29
maestro8
is what it is
maestro8's Avatar
What about slotting your frame (to allow vertical adjustment) and attaching the brake mount with proper bolts? Those pipe clamps aren't meant to do much more than clamp pipes.
It looks like the clamp "tail" hangs out from the frame. I've never ridden a BC before but it looks like that could make a nasty slice in your leg.
__________________
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." - Bertrand Russell
maestro8 is offline   Reply With Quote
Old 2005-04-27, 01:10 AM   #30
James_Potter
Registered User
that's a very good idea. but one thing I don't like is that it requires hands.... there must be a way to mount the handle on the 'frame' you added, so you can press it with your leg.
also, the frame is longer than the platforms. this would make it harder to balance, I think, since the frame might make the platforms want to flip over. I'm pretty sure it would make a rolling jump mount impossible, at the very least....
James_Potter is offline   Reply With Quote
Reply
Tags
brake, project, system, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.09458 seconds with 10 queries
