Unicyclist Community
Reply
Old 2005-04-26, 04:51 AM   #1
ColDawG
Registered User
ColDawG's Avatar
Send a message via AIM to ColDawG
FRESH NEW IDEA for suspension unicycles
OK:
here are some problems w/ current suspension systems:
they only eliminate bumps when you are on the seat
the new ones people are coming up with have complicated in-wheel systems that give up wheel strength
My Solution:
I think that the frame should have suspension (telescoping) somewhere between the top of each fork leg and the hub. The pedals shouldn't be mounted directly to the hub. Instead, the pedals should be mounted on a piece that extends from the top of the fork. This way, the pedals/cranks get shock absorption that renders them separate of the wheel.
There would be some sort of drivetrain system going up the pedal/crank mounts, and back down the forks to the hub.
Unfortunately I don't have CAD or n e thing to map it out, i'll do a photoshop-ish drawing and post it on here, but if someone has CAD tools and wants to draw it up, show me if you do it.
PM me or tell me on the forum about what you think!
__________________
UBC rocks!!!
ColDawG is offline   Reply With Quote
Old 2005-04-26, 04:54 AM   #2
ColDawG
Registered User
ColDawG's Avatar
Another idea (stemming off my first):
rather than a complicated bracket that would allow the cranks to be mounted seperately but at the same level/position as the hub, you could just mount the cranks on the fork above the compression part
is there any way to counterweight the cranks so as to make your cranks feel like they're in the middle of the wheel, or would it just take some getting used to and not matter?
__________________
UBC rocks!!!
Old 2005-04-26, 05:06 AM   #3
Evan Byrne
Why am i here? I dont unicycle.
Evan Byrne's Avatar
Send a message via AIM to Evan Byrne Send a message via Yahoo to Evan Byrne
How about not be pussys and just ride unis how they are? Haha, no, sounds cool but i dont know what your talking aobut, try your best to draw it in paint. then post it so we get a better idea
Evan Byrne is offline   Reply With Quote
Old 2005-04-26, 05:22 AM   #4
Denali
Sid Denali Rajan
If that works, the drive train can also be used to gear it...That means you can use a small wheel...Coz if you use a big wheel and the cranks are located above the wheel then it'll be like riding a giraffe(you don't want that for muni).....
Denali is offline   Reply With Quote
Old 2005-04-26, 05:57 AM   #5
weeble
weeble's Avatar
Hub-to-pedal suspension would be a nice design/engineering challenge, but I'm doubtful as to its actual usefulness. Saddle-to-hub suspension should be all that you need. If you're off of the seat, your legs are acting as shock absorbers. If your legs flex enough to land you on the saddle again, then the suspension takes over. Or so I would figure it. I don't think I'd want suspension between the hub and the pedals. My reflex system relies on my legs to tell it what the wheel is doing at all times in order to control it smoothly, and reducing the wheel-feel with a suspension would impair that, I think.
__________________
All brontosauruses are thin at one end, much MUCH
thicker in the middle, and then thin again at the
far end. That is the theory that I have and which
is mine, and what it is too. - Ms. Anne Elk
weeble is offline   Reply With Quote
Old 2005-04-26, 08:06 AM   #6
andrew_carter
Back into muni!
andrew_carter's Avatar
Here's some interesting older discussion on suspension unicycles - http://www.unicyclist.com/forums/sho...ght=suspension .
Andrew
andrew_carter is offline   Reply With Quote
Old 2005-04-26, 09:53 PM   #7
Bob22b
MCL Tearer :d
Bob22b's Avatar
Let's get some uni's with 8" of travel along with a clutch so you can freewheel it then we'll see people riding the drops at the Redbull Challenge. Intense.
Bob22b is offline   Reply With Quote
Old 2005-04-26, 11:46 PM   #8
gerblefranklin
Registered User
Re: FRESH NEW IDEA for suspension unicycles
Quote:
Originally posted by ColDawG
OK:
My Solution:
No, it wouldn't work. It'd be easier to do something in-wheel, and it'd be better to ride. Attaching the pedals and cranks to the frame would just suck.
gerblefranklin is offline   Reply With Quote
Old 2005-04-27, 12:12 AM   #9
Catboy
Roadkill
Catboy's Avatar
Send a message via ICQ to Catboy Send a message via AIM to Catboy Send a message via MSN to Catboy
I still dont see why someone couldnt make a lightweight tweel for unicycles.
__________________
Rest in pieces.
Catboy is offline   Reply With Quote
Old 2005-04-27, 01:41 AM   #10
loosejello
Amanda gives me sunburn
loosejello's Avatar
Send a message via AIM to loosejello Send a message via Yahoo to loosejello
Because tweels AREN'T light, they're full of rubber everywhere. It'd be like thick rubber spokes the whole width of the wheel, with extra rubber for stability.
loosejello is offline   Reply With Quote
Old 2005-04-27, 01:47 AM   #11
Catboy
Roadkill
Catboy's Avatar
A lightweight tweel could be made, since it wouldnt have to stand up to the abuse that cars or motor vehichles apply, the wheel could be much lighter, I think.
__________________
Rest in pieces.
Old 2005-04-27, 02:11 AM   #12
loosejello
loosejello's Avatar
No, you'd still have to have a lot of rubber in there to get the same support as in a regular unicycle wheel. The rubber would still have to be as wide as the wheel to keep the tread part from moving sideways, and you'd still have to have a lot of rubber between the rubber spoke fins, otherwise they'd never hold up to the weight, they'd just buckle straight down.
Old 2005-04-27, 02:28 AM   #13
DK
DK's Avatar
Send a message via AIM to DK
Theres really no need for squish on unis. For trials, you dont want suspension because all it will do is absorb your push to jump (unless we make "platform" shock), but still, for trilas its out of the question. As for muni, I think it would prevent you from keeping in firm mental and physical contact with the trail; you lose your feel.
__________________
poopslush.
Quote:
Originally Posted by tomtrevor
i get to sleep by wacking myself
DK is offline   Reply With Quote
Old 2005-04-27, 02:32 AM   #14
loosejello
loosejello's Avatar
SOMEONE ELSE AGREES WITH ME, FINALLY. DK is exactly right. You could not hop on a suspended unicycle, the suspension would soak everything up. That is their job, to soak up bumps.
Old 2005-04-27, 02:44 AM   #15
DK
DK's Avatar
Quote:
unless someone makes a platform valve like a lot of bike shocks are now- It is rigid under pedaling, but when a bump hits it, an interia valve opens up the suspension. I would still make trials unis un suspended anyways.
__________________
poopslush.
Reply
Tags
fresh, idea, suspension, unicycles
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.15082 seconds with 10 queries
