Unicyclist Community
Reply
Old 2005-03-12, 09:57 AM   #1
ChangingLINKS.com
member
ChangingLINKS.com's Avatar
Send a message via Yahoo to ChangingLINKS.com
Noise from the wheel?
I am getting a noise from the wheel.
It's like a creaking that I can feel and hear.
I can make the noise with the wheel spinning in the air:
It's not the spokes.
I just replaced the bearings with brand new ones.
It's not the bearings.
There is no pressure on the cranks.
I doubt it's the cranks.
The noise happens with or without pedals.
It's not the pedals.
That leaves:
The hub.
The relationship between the bearings and the frame.
Does anyone else have this problem?
Can the hub make noise by spinning and simply supporting the weight of the wheel?
__________________
Wishing you Happiness, Joy and Laughter,
Drew Brown
Changing LINKS
ChangingLINKS.com is offline   Reply With Quote
Old 2005-03-12, 04:36 PM   #2
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
What kind of hub and what brand of cranks do you have?
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2005-03-12, 04:57 PM   #3
unijuggler
lvl 3 goin on 10
unijuggler's Avatar
try tightning the bearing mounts cause i had sort of the same problem and i just tightened them and the problem went away so that could be your only problem
__________________
there were 2 muffins in the oven
muffin 1 says to muffin 2
my god, its hot in here!!
muffin 2 says
holy crap a talking muffin
unijuggler is offline   Reply With Quote
Old 2005-03-12, 05:12 PM   #4
Uniwitold
Registered User
Uniwitold's Avatar
Quote:
The above just has happened to me today.
The solution was as in the quote.
__________________
Veni !Vidi !Mount ! ' Public does not perceive it reacts'. Greg Harper.
Uniwitold is offline   Reply With Quote
Old 2005-03-12, 06:50 PM   #5
musketman
Registered User
musketman's Avatar
are you sure its not ur seat? My seat makes creakin noises all the time and it feels like its comin from the hub/tire area.
musketman is offline   Reply With Quote
Old 2005-03-12, 06:54 PM   #6
musketman
Registered User
musketman's Avatar
o and maybe it is the spokes cuz when you sit donw its putin weight on the spokes maken them bend/move around a little.When you have the uni in hte air there is no weight on the spokes maken them do that.
Old 2005-03-12, 07:42 PM   #7
ChangingLINKS.com
member
Quote:
Profile.
Some noise may be coming from the seat (but I happened to change that yesterday also). At least during today's ride it wasn't so annoying.
__________________
Drew Brown
Changing LINKS
Old 2005-03-12, 08:33 PM   #8
leeman180
The Godfather of the Clan
leeman180's Avatar
Re: Noise from the wheel?
At first when I read this I thought this was a poem .
leeman180 is offline   Reply With Quote
Old 2005-03-12, 10:32 PM   #9
john_childs
Guinness Mojo
john_childs's Avatar
Could the lips of the bearing holders be rubbing on the Profile spacer washers? Maybe one of the washers has a little nub that's sticking out and hitting part of the bearing holder every revolution.
Are you using the big conical shaped saucer spacer from Profile? That spacer can have some clearance problems with some frames and it could be rubbing on the frame. You can get additional small spacer washers from Profile so you don't have to use that big spacer thing.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-03-13, 01:46 AM   #10
gerblefranklin
Registered User
This has happened on 2 of my profile wheels. Both times it went away quickly, but then cam back when I rotated the cranks, possibly because the spacers moved too.
gerblefranklin is offline   Reply With Quote
Old 2005-03-13, 03:56 AM   #11
DK
DK's Avatar
Send a message via AIM to DK
Re: Re: Noise from the wheel?
Quote:
You beat me to it!!!
__________________
poopslush.
Quote:
Originally Posted by tomtrevor
i get to sleep by wacking myself
DK is offline   Reply With Quote
Reply
Tags
noise, wheel
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.07735 seconds with 9 queries
