Unicyclist Community
Reply
Old 2005-01-27, 02:42 AM   #1
TonyMelton
Proud owner of Kris Holms old shoes
TonyMelton's Avatar
Delta brake lever extender slipping on HS-33 Lever
Since upgrading from a Magura HS-11 brake (which has a plastic lever blade) to a Magura HS-33 I've had problems with clamping my Delta brake lever extender in place. On the old plastic lever the grub screw had plenty of material to bite into, but its struggling to hold the extender in place on the new lever for more than a few hours' riding.
When I first noticed this problem the allen pinch bolt was screwed all the way in and still not gripping hard enough. I tried spacing out the pinch slot by threading a washer through the pinch allen bolt. This fix has not been successful.
Anyone got any suggestions as to hold that pesky sucker in place?
TonyMelton is online now   Reply With Quote
Old 2005-01-27, 03:04 AM   #2
jagur
My Uzi is a Tongue
jagur's Avatar
fold up a little square of a beer can and stick it under fixing bolt in the concave part and screw down the bolt on it tight, then tighten the cinch bolt. thats what i did.
__________________
theres enough BS in life, without mobius contributing.
Forget_Your_Life
-------MUNI MILITIA -------
One Wheeled Death Squad
twitter> @shot of jagur
jagur is offline   Reply With Quote
Old 2005-01-27, 05:40 AM   #3
john_childs
Guinness Mojo
john_childs's Avatar
I put a little washer under the set screw that tightens down on the lever. The washer bent a bit as the set screw was tightened. It has held great. No slipping.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-01-27, 08:54 PM   #4
TonyMelton
TonyMelton's Avatar
Thanks for the suggestions Jagur and John. I've gone with the aluminium can method for now - as I had just finished consuming a refreshing carbonated bev when Jagur posted! I'll see how it holds up over the weekend.
Reply
Tags
brake, delta, extender, hs33, lever, slipping
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08792 seconds with 9 queries
