Unicyclist Community
Reply
Old 2005-01-14, 03:43 AM   #1
Krashin'Kenny
Crash Tested
Krashin'Kenny's Avatar
My 4K Custom Frame
No, it didn't cost $4K. I went digging through the scrap pile again and decided to build myself another frame. Here it is :
Krashin' Kenny's Kustom Koker
__________________
If you ain't crashing, you ain't going fast enough!!!!!!!!!!!
Krashin'Kenny is offline   Reply With Quote
Old 2005-01-14, 03:44 AM   #2
Krashin'Kenny
Crash Tested
I filet-brazed the bearing holders for a cleaner look
__________________
Old 2005-01-14, 03:45 AM   #3
Krashin'Kenny
Crash Tested
And the complete unicycle
__________________
Old 2005-01-14, 03:46 AM   #4
Krashin'Kenny
Crash Tested
I almost forgot to show how the crown looks as though it was made specifically for the Coker tire
__________________
Old 2005-01-14, 03:51 AM   #5
UniBrier
Time To Ride
UniBrier's Avatar
Quote:
Kwite Kool Koker Krown
__________________
Steve
Hop Drop & Roll
“If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your
shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer
UniBrier is offline   Reply With Quote
Old 2005-01-14, 03:54 AM   #6
john_childs
Guinness Mojo
john_childs's Avatar
Oh! That does look kustom. Nice.
Are you using a standard width hub or one of the super wide hubs?
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2005-01-14, 12:51 PM   #7
S_Wallis
S_Wallis's Avatar
Very nice Kenny! Quite a tranformation from the way I saw it last weekend. If they ever have a Junkyard Wars episode where they have to build a unicycle, you da man for the job!
Scott
__________________
------------Use my Email, not PMs please--------
S_Wallis is offline   Reply With Quote
Old 2005-01-14, 01:08 PM   #8
Krashin'Kenny
Crash Tested
Thanks guys
John, it has the standard width hub on a stock Coker wheelset
Scott, you can borrow my old frame to convert that 36" UW if you'd like
__________________
Old 2005-01-14, 01:11 PM   #9
S_Wallis
S_Wallis's Avatar
Thanks guys
I may take you up on that as temporary until I have time to build a frame. Thanks. I have about decided the frame/seat thingy is necessary for distance riding.
__________________
Old 2005-01-14, 01:26 PM   #10
goldenchicken
Time bandit
goldenchicken's Avatar
Nice indeed. Seems like a good way to save some money while having a good time in the garage. Did you ovalize the tubes yourself?
goldenchicken is offline   Reply With Quote
Old 2005-01-14, 05:51 PM   #11
johnfoss
North Shore ridin'
johnfoss's Avatar
Cool Color Coker!
Most Cokers are black & white. Nice to see some color on one. Do you get any tire rub? Most frames flex at least a little, and the bigger the wheel gets, the more it can move from side to side. Looks like a great fit in that crown, but I'd be worried about a little rub when you pedal hard.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2005-01-14, 07:56 PM   #12
daino149
On Vacation - till i find a job
daino149's Avatar
Send a message via AIM to daino149
Another very nice frame Kenny. What was the final cost of the parts for the frame? Have you thought about using heavier duty bearing housings like the 2004 KH or other machined housing?
__________________
OPPORTUNITYISNOWHERE
daino149 is offline   Reply With Quote
Old 2005-01-14, 07:58 PM   #13
Krashin'Kenny
Crash Tested
Quote:
Yes I did ovalize the tubes myself using a 10-ton press and a couple of thick steel plates. It is definately the most cost effective way to get a custom frame, I've got about $18 in it
John,
There's a little over 3/8" clearance between the tire and the sides of the crown. I've only ridden it aroud the shop, but took a couple of real sharp turns without it rubbing. If it does ever rub, I can easily remove some of the aluminum from the crown for more clearance.
__________________
Old 2005-01-14, 10:15 PM   #14
goldenchicken
Time bandit
You give me inspiration to make something similar for a 29er. I guess that crown (aluminum is it?) comes from a suspended mtb fork. Are the tubes welded to the crown?
Old 2005-01-14, 11:46 PM   #15
Krashin'Kenny
Crash Tested
The crown is indeed from an old MTB suspension fork and is made of aluminum. If you do decide to make one of these, there are a few things to consider. I've always used crowns that had "1 inch" stanchion tubes on the fork legs. The forks that use larger diameter tubes usually have a wider gap and will be too wide to properly fit the unicycle hub and may cause "knee interference" also.
Another consideration is the diameter of the steerer tube, which will become the seat tube. This frame was made from a fork that had a 1 1/8" steerer tube and I had to insert (braze) a shim to fit the standard unicycle seatpost (22.2 mm). The crown that I used on my MUni, however, had a 1" steerer tube and the seatpost fit inside perfectly.
Feel free to pm me if you need any more info.
__________________
Reply
Tags
custom, frame
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.09944 seconds with 10 queries
