Unicyclist Community
Reply
Old 2004-12-23, 07:56 PM   #1
Catboy
Roadkill
Catboy's Avatar
Send a message via ICQ to Catboy Send a message via AIM to Catboy Send a message via MSN to Catboy
Question Rolling Hop Unispin? Unispin Grind?
I've been watching alot of my old skateboarding video's lateley for inspiration, and I immediately noticed that they do an awful lot of flip tricks(kickflip, heelflip, 360flip, shove-it) into their grinds. I've never seen anyone do a unispin into or out of a grind, meaning that the rider would rolling hop, unispin in the air, and land in the grind. OR: grind, and unispin in the air while launching off the grinding surface. I assume one would have to be really good at grinding and unispins... Dan Heaton maybe? I plan on going out and working on getting the rolling unispin, so maybe I can unispin over a gap or off a drop. But I assume that a unispin into a grind would be doable with some practice, and more than doable for some of the active pros out there. 3 things would be needed to Acheive this skill, big rolling hops(or the ability to be able to get some air off of a grind), solid unispins, and being comfortable grinding.
Any comments?
__________________
Rest in pieces.
Catboy is offline   Reply With Quote
Old 2004-12-23, 08:13 PM   #2
dubmuni2004
this is quite tasty
dubmuni2004's Avatar
Knowing Dan Heaton, he probably already has this in mind, or somthing cooler. That would be really cool because grinds are getting old right now, they would be alot more fun to watch if someone did something like you suggested. When you want to grind a rail or something the same height, you notice that your body has to fold in half. So I'm sure it would take lots of practice to incorperate a unispin while your uni is at that angle.
__________________
blahblahblahblahblahblahblahblahblahblah
extreme_unicyclist@hotmail.com
AIM: IhaveAsuckySN
dubmuni2004 is offline   Reply With Quote
Old 2004-12-23, 08:14 PM   #3
caw89
Above your simple levels!
caw89's Avatar
Send a message via AIM to caw89 Send a message via MSN to caw89 Send a message via Yahoo to caw89
Universe 1, Adam Ryznar does it.
__________________
Uniclips Updated Sept
AIM: unicaw89
Quote:
Originally Posted by abbabibble
Cody bent his koxx.
he was working it pretty hard.
caw89 is offline   Reply With Quote
Old 2004-12-23, 08:23 PM   #4
Murde Mental
Unicycling Martyr
Murde Mental's Avatar
I've done a 180 unispin into a grind once...it's not very hard but doing a 180 out after...now THAT I have to work on.
__________________
CREEPMACHINE
Murde Mental is offline   Reply With Quote
Old 2004-12-23, 08:25 PM   #5
James_Potter
Registered User
There's a unispin out of a grind, and a unispin into a crank grab in the first UNiVERsE.
James_Potter is offline   Reply With Quote
Old 2004-12-23, 08:35 PM   #6
dubmuni2004
this is quite tasty
Quote:
goes to show how long it's been since I've seen that movie. But I'm talking about stair rails, thats hard.
__________________
AIM: IhaveAsuckySN
Old 2004-12-23, 08:46 PM   #7
James_Potter
Registered User
Oh yeah, into and out of hand rails would be a bit trickier.
Old 2004-12-23, 10:04 PM   #8
unifreak7
No hops! All flow.
unifreak7's Avatar
Send a message via AIM to unifreak7 Send a message via MSN to unifreak7
yo
No doubt about the hand rails.
Ledges i've done unispins into and out of them, sloped ledges. There not that hard, just a larger aerial off the ledge for the unispin. It's rad. In hazardous (also migth be titled sick trip) next summer will have some of the sickest grind combos anyone has seen. Of course, defect the sooner to come out video, might have some of them. SO i'm alittle worried. lol. Oh well. Next year around this time our movie should be out. So if you're interested in some sick grinds and a lot of other things, this one is a keeper. ha. laters
__________________
Check out my channel - http://www.youtube.com/user/BendableCard
unifreak7 is offline   Reply With Quote
Old 2004-12-23, 11:46 PM   #9
pk
Death Of Inocence
pk's Avatar
this time next year... thats a long wait.
now where did i put my left handed screwdriver
__________________
PK
poiinthepark || Home of the UK poi and fire twirling communities
pk is offline   Reply With Quote
Old 2004-12-23, 11:55 PM   #10
James_Potter
Registered User
Quote:
aren't screwdrivers symmetrical?
Old 2004-12-24, 10:33 AM   #11
Klaas Bil
Newsgroup User
Posts: n/a
Re: Rolling Hop Unispin? Unispin Grind?
Mine almost is, it has a switch that is labeled
L - 0 - R
Klaas Bil - Newsgroup Addict
"Deflating pi does not reduce calories, it just concentrates them. - billham"
Old 2004-12-24, 02:42 PM   #12
Worminton
I have stollen Gilby's avatar
(I don't think so! - Gilby)
Send a message via AIM to Worminton
Catboy,
Technicllay uni spins are just about the equivelent of pop shuv its. When you watch your videos what kind of grinds do you see them doing out of the grinds? I assume it would be mostl 50-50's and board slides. It's probably a little harder to do with other grinds like crooked grinds and stuff.
Now to my point.
It's impossible to do a 50-50 or a board slide on a uni. Unless you want to try to grind the straight part connecting from the seat to the wheel to pull off a board slide/smith grind kinda thing. So with the grinds we do using the pedals it would probably be pretty hard to do a uni spin out of a grind because your wheel is so close to the object of grinding that the wheel might hit it.
Keep in mind I've never tried to uni spin out of a grind so this is in theory. If you think you can make it work then go out for it!!!
__________________
Gilby stole my avatar
Worminton is offline   Reply With Quote
Old 2004-12-24, 07:20 PM   #13
Catboy
Roadkill
Catboy's Avatar
Quote:
Originally posted by Worminton
Catboy,
Actually I see them doing the same exact tricks into and out of grinds, and all sorts of grinds on differnt surfaces(pipes, ledges, rails) and still the tricks only vary based on the skill of the boarder. For instance you will people do heelflips into and out of crookeds, nosegrinds, 5-0's and many others. Shuv it's however usually come from out of a grind, but are seen going into the grind when it is on a ledge or whe you can shuv it onto a ledge grind.
I'm not sure if all of this is any bit clear to you but, If I could I would show you what I meant.
__________________
Rest in pieces.
Old 2004-12-24, 07:26 PM   #14
dubmuni2004
this is quite tasty
I watched UNIverse 1 yesterday, and I let it run for a while, and boom! There was extra footage of Adam Rayznar (I think) at the end. He was wearing a cowboy hat. Then after that they just showed someone load a full box of the movies. Did anyone else notice this? When I watched it, I did'nt notice Adam do a unispin into a grind, just a unispin out.
__________________
AIM: IhaveAsuckySN
Old 2004-12-24, 09:02 PM   #15
tugboat
Kevin McMullin
Send a message via AIM to tugboat Send a message via MSN to tugboat
hello. for skateboarding, shuvits usually come out of slides like boardslide, lipslides, noseslides, or tail slides. its very rare that you see someone trick out of a grind with any trick other than a shuvit (not to say that it isnt done, because ive seen hundreds of them done). but shuvits are the most common trick out of a slide in skateboarding. kickflips, heelflips, 3 flips, and any other flip trick is more commonly seen into tricks. thats what ive noticed watching my alomost-pro friends skate, and watching pro videos.
dubmuni: he unispins into a pedal grab, not into a grind.
i hope people start doing crazy stuff into and out of grinds by the time im back so i have some motivation to catch up. someone do a footplant crankflip to grind, video tape it and send it to me, cause that was the next trick i wanted to do until i ruptured my spleen. so someone do it for me haha.
Kevin
__________________
"You won't get hurt if you land it!"
The Kevin McMullin Facebook Page
Bedford Unicycles
Unicycle.tv
tugboat is offline   Reply With Quote
Reply
Tags
grind, hop, rolling, unispin
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.08782 seconds with 9 queries
