Unicyclist Community
Reply
Old 2004-11-28, 06:14 PM   #1
James_Potter
Registered User
Mountain Bike Race on my Coker, advice please
There's this Mountain Bike Race around my place every year, the Moscow Mountain Madness. It's 12 miles, with the first 10 uphill. I have two unicycles: a coker and a 20 inch trials. [pictures here: http://www.palouseroadrunners.org]
I did it on my trials last year, and the going was very slow. I wouldn't be able to do it on my Coker this way, but if I got a longer crankset, would that make it more possible? And how long of cranks should I get?
Danke
James_Potter is offline   Reply With Quote
Old 2004-11-28, 06:33 PM   #2
Brian MacKenzie
If I hear that tune one more time..
Brian MacKenzie's Avatar
Send a message via MSN to Brian MacKenzie
170mm cranks on a Coker allow for some nice leverage, and you will probably be able to ride in the congestion of many bikers better with a longer crank set.
Most mountain bike cranks are 170-175mm and bike stores will probbaly have a cheapo set lying around to almost give you.
All of the crank lengths I have had on my Coker, I have had the most fun with 175's
Brian MacKenzie is offline   Reply With Quote
Old 2004-11-29, 03:53 AM   #3
jerryg
JerryG
Yes, longer cranks will make it easier, but also slower. I ran in a time trial with mtn-bikers, on my coker with stock crank arms, and only beat one rider. It wasn't as long as the one you're talking about, but the first 1/2 was up hill.
As you should know, the gearing on a mtn-bike will not work to your advantage, unless the hill is so steep that they are in a gear below 1:1. But since most mtn-bike races end back where they started, each up hill has an equal down hill. Use the shortest cranks that will allow you to spin all the way up.
Good Luck,
let us know how you do,
Jer
jerryg is offline   Reply With Quote
Old 2004-11-29, 04:38 AM   #4
Brian MacKenzie
Quote:
On 10 miles of flat road...maybe (people should seriously get away from 'shorter cranks are faster' reasoning)
In the trails? Longer cranks will give you more negotiation power, and in a rooty, bumpy off road course, will probbaly be easier. and therefore faster overall.
What it all boils down to is what crank length you are used to.
But if you get used to 170mm cranks, those would be your best bet (judging on my 2 years of cokering) advantage
Old 2004-11-30, 01:25 PM   #5
GizmoDuck
Uni Hour Record Holder 29.993km
GizmoDuck's Avatar
Location: Wellington, New Zealand/ Middle of NSW, Australia
I agree with Brian- short cranks aren't necessarily faster if you can't spin them as fast. You do need the leverage- so, unless it is flat gravel road- probably 150's or 170's or even 180's. I remember Tony Melton spinning up a hill on 170's (and disappearing out of sight) as I was slowly grinding away on 150's.
Practice running uphills too. If it is too steep to ride on your Coker with the long cranks- it is probably very slow on a bike also. You may find you can run just as fast as them biking!
Good luck,
Ken
GizmoDuck is offline   Reply With Quote
Reply
Tags
advice, bike, coker, mountain, race
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06558 seconds with 9 queries
