Unicyclist Community
Reply
Old 2004-10-27, 02:05 AM   #1
happysquidman
Unicyclist and Dude
kh seat problems
my kris holm seat wiggles back and forth. i tried tightening the bolts under the seat, but the keep on coming loose. it looks like they've slid out of the place that they're supposed to be in. how should i fix this?
__________________
Dude....
happysquidman is offline   Reply With Quote
Old 2004-10-27, 02:07 AM   #2
Goatman!
^-#-^ Sean Webster
Goatman!'s Avatar
Send a message via AIM to Goatman!
you can use locktite. but all i use is lock washers. they seem to help me
__________________
I Was Born A Poor Black Child.
click my sig for a good time.
NIPPLES
Goatman! is offline   Reply With Quote
Old 2004-10-27, 02:09 AM   #3
andrew_carter
Back into muni!
andrew_carter's Avatar
Using those nuts with the ring of nylon over the thread (Ny-Lock?) solved the problem for me.
andrew_carter is offline   Reply With Quote
Old 2004-10-27, 02:10 AM   #4
andrew_carter
Back into muni!
This is the best image I could find - http://www.aeroparts.com.au/ms21104d...k_alum_nut.jpg
http://www.moruyabicycles.com.au/media/nylock_nut.jpg
Reply
Tags
problems, seat
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.07092 seconds with 9 queries
