Unicyclist Community
Reply
Old 2004-10-05, 04:46 PM   #1
mgrant
Ever hoping for the best!
mgrant's Avatar
Send a message via AIM to mgrant Send a message via MSN to mgrant Send a message via Yahoo to mgrant Send a message via Skype™ to mgrant
I broke my Kinport handle
A couple of weeks ago I was out riding around on my summit 20". It has a Viscount saddle that I've attached a UHMW Kinport handle (well it was a prototype or something that I won at MMF2003).
Anyway, I landed a small rolling hop poorly and came down pretty hard on the saddle. The handle just snapped in two. Has anyone else broken the SH/Kinport handle?
-mg
__________________
The sun is the same in a relative way but you're older, shorter of breath, and one day closer to death.
michael_j_grant (at) yahoo (dot) com
Gallery: http://tinyurl.com/34my5c
mgrant is offline   Reply With Quote
Old 2004-10-05, 05:14 PM   #2
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
Nice. Where on the handle did it snap?
__________________
There is nothing worse than a gross exaggeration.
Max_Dingemans is offline   Reply With Quote
Old 2004-10-05, 05:40 PM   #3
mgrant
mgrant's Avatar
Quote:
It broke behind the back of the handle opening. Two vertical cracks on either side from the top to the bottom. The handle opening is intact.
Tonight I'll take a picture and post it.
I suspect that the production versions are less vulnerable to the type of failure I experienced.
-mg
__________________
Old 2004-10-05, 07:23 PM   #4
zack
Registered User
Send a message via Yahoo to zack
Ya I'v Broken A ton of those Steave Howard Handles, They Always Break in the same spot!
Zack
zack is offline   Reply With Quote
Old 2004-10-05, 09:53 PM   #5
john_childs
Guinness Mojo
john_childs's Avatar
I have had a nut pull through the Kinport handle. I haven't yet managed to break a Kinport handle clean off the saddle.
I now use either large washers under the handle to reinforce it, or the GB4 Handle Reinforcement Plate to reinforce the handle. These two solutions will keep the nuts and bolts from ripping through the handle.
I'm not sure where your handle broke. If it broke around the bolt holes then maybe a GB4 handle plate would have helped keep it in one piece.
__________________
john_childs (att) hotmail (dott) com
Team Never Wash Your Muni
My Gallery :: Unicycling Bookmark List :: World Clock
john_childs is offline   Reply With Quote
Old 2004-10-05, 10:29 PM   #6
showard
I sure would like to see one of those busted handles. If I knew where the handle breaks I might be able to strengthen it in that spot for the next batch.
SH
showard is offline   Reply With Quote
Old 2004-10-05, 10:33 PM   #7
Max_Dingemans
Pedal Pedal Crash
I think I know the spot. If so, that's how I used to break miyata handles.
__________________
Old 2004-10-05, 11:09 PM   #8
mgrant
mgrant's Avatar
Quote:
SH
http://gallery.unicyclist.com/broken_handle/
These pictures show where my handle broke.
I wonder if UHMW plastics can be glued?
-mg
__________________
Old 2004-10-06, 12:17 AM   #9
Dylan Wallinger
Registered User
I've been using a plastic miyata seat base and a kinport handle for ever, and haven't had any problems.
-Dylan
Dylan Wallinger is offline   Reply With Quote
Old 2004-10-06, 11:28 AM   #10
stigma13
What Evil Lurks?
sadly, my kinport has 2 cracks on either side (where there is grooves to fit along the seat base) so when you put force on it, well...lets just say you could probably flex it a full 90 degrees downward. I'm guessing I may have did something when I was attaching it to the seat base...not sure thought. I just bought a new one and there is nothing more relieving then having a solid handle.
Ševon
stigma13 is offline   Reply With Quote
Reply
Tags
broke, handle, kinport
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.07109 seconds with 9 queries
