Unicyclist Community
Reply
Old 2004-09-27, 02:16 AM   #1
gerblefranklin
Registered User
Alternative Method for Mounting Hs-33 lever
Well, since I'm very near completing a muni frame that can accept brakes, i thought it might be wise to begin thinking about how to mount my hs-33.
There were two major requirements that this mounting had to fufill. Firstly, it had to be easily actuated by 1 finger, even when pulling up hard on the seat. Secondly, the brake lever and other related compnents had to be protected from impact. At CMW this year I saw 3 or four brakes break, including 1 or two levers. Another, less important objective was that I wanted the mountiung to be relatively light. I didn't have a wilder rail adapter or any extra bar ends, and I didn't want to for over the cash for them, so I just started playing around. I noticed that my brake fits well onto my seatpost, so I looked around at that. Finally, I decided that I would mount the brake lever to the seatpost and have it facing back, near the valve for my airseat. I would have a little loop attached to some string attached to the lever that I would use for brake actuation. Here's a picture of the position of the brake laver under my seat.
gerblefranklin is offline   Reply With Quote
Old 2004-09-27, 02:54 AM   #2
gerblefranklin
Registered User
Here's a view of the loop where my finger goes:
Old 2004-09-27, 02:55 AM   #3
mreed87
level negative(-) 4 unicyclist
mreed87's Avatar
Send a message via AIM to mreed87
so you pull on a string from the front? and the brake lever is facing back? waht is the duck tape for
__________________
Mike Reed
mreed87 is offline   Reply With Quote
Old 2004-09-27, 02:55 AM   #4
gerblefranklin
Registered User
and another...
Old 2004-09-27, 02:56 AM   #5
mreed87
mreed87's Avatar
ohhhh thats cool ahahahh does it jsut hang there when your not using the brake?
__________________
Mike Reed
Old 2004-09-27, 02:57 AM   #6
gerblefranklin
Registered User
The duct tape is completely unrelated to the brake. It's for holding the seatcover and padding for seat out together. Yes, the lever faces backwards and you pull the lever with a string attached to a loop.
Old 2004-09-27, 03:01 AM   #7
S_Wallis
S_Wallis's Avatar
Thinking out of the box again, Bevan?
Consider replacing the string and loop with a one piece rod or stiff wire. You could support it off of a guide attached to one of the seat post bolts. Might be easier than supporting the string setup.
Scott
__________________
------------Use my Email, not PMs please--------
S_Wallis is offline   Reply With Quote
Old 2004-09-27, 03:08 AM   #8
gerblefranklin
Registered User
Yeah, I'm thinking outside of the box. or being cheap, whcihever you want. This whole setup cost me $70.00. $70 for the brake, the rest was free.
Actually, the loop is a piece of 1/4" aluminum wire that's about 4 inches long, including the loops at both ends. I used that for the exact reason that you mentioned. I just haven't gotten around to assembling and installing the said mount.
Old 2004-09-27, 03:11 AM   #9
mreed87
mreed87's Avatar
how hard do you have to pull that wire to have the brake work well enough? and does that metal ever get uncomforatble?
__________________
Mike Reed
Old 2004-09-27, 03:21 AM   #10
dubmuni2004
this is quite tasty
dubmuni2004's Avatar
Re: Alternative Method for Mounting Hs-33 lever
that is so innovative. thats an owsome and cheap way to deal with a problem. good for you
__________________
blahblahblahblahblahblahblahblahblahblah
extreme_unicyclist@hotmail.com
AIM: IhaveAsuckySN
dubmuni2004 is offline   Reply With Quote
Old 2004-09-27, 04:27 AM   #11
andrew_carter
Back into muni!
andrew_carter's Avatar
Looks great, a friend of mine mentioned this idea to me a while ago and I've been keen to see how it goes.
Have you considered fixing the string to the end of the lever for more braking power? Or would that mean you'd have to pull the string uncomfortably far? How will the loop for your finger be held in place when you're not braking? Have you test ridden it? Is it easy to find the loop when you need to suddenly brake?
Very interesting, let us know how it turns out. I don't think that setup would suit my braking action. I'm more suited to the more upwards pull of the lever, especially when not sitting down.
Andrew
andrew_carter is offline   Reply With Quote
Old 2004-09-27, 04:42 AM   #12
gerblefranklin
Registered User
Andrew
Again, I don't have a frame to mount the brake in, so I can't really test it yet. I didn't fix the string to the end of the lever for the exact reason that you mentioned. I can't imagine needing very more power than that setup provides. The loop will be loosely be held by a hook hanging from a seat handle bolt.
I think that upward pulling is ideal, but i don't think any of the current setups are engineered correctly, and I think the handle is too far from the base. When I get the chance to fabricate a better rail adaptor, I intend to do a new brake setup that's lighter than a wilder and better. But this should do for now.
Old 2004-09-27, 05:09 AM   #13
andrew_carter
Back into muni!
Sounds great.
Old 2004-09-27, 11:28 AM   #14
zod
Southern Fried mUni
zod's Avatar
Send a message via AIM to zod
that's gotta be the most ghetto thing I have ever seen!!!! rock on....
zod is offline   Reply With Quote
Reply
Tags
alternative, hs33, lever, method, mounting
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.43611 seconds with 10 queries
