Unicyclist Community
Reply
Old 2004-08-07, 01:03 AM   #1
miyata
may the schwartz be with you
miyata's Avatar
Torker DX 20' for Trials?
http://www.unicycle.com/shopping/shopexd.asp?id=764
how good do you think this bike would be for trials? it has a 2.125 inch wide tire instead of 2.5 . but everything else looks okay. would it withstand drops of say three feet and crank grabs and other trial manuvers?
miyata is offline   Reply With Quote
Old 2004-08-07, 01:49 AM   #2
munimanpete
the unicycling kiwi
munimanpete's Avatar
Re: Torker DX 20' for Trials?
Quote:
Well firstly its unicycle not a bike...secondly yeah i think it would be fine, especially seeing as its splined, i don't think that the smaller wheel size will make tooo much difference, but it will be a bit harder.
munimanpete is offline   Reply With Quote
Old 2004-08-07, 02:44 AM   #3
Max_Dingemans
Pedal Pedal Crash
Max_Dingemans's Avatar
Send a message via AIM to Max_Dingemans
It'll be okay for awhile, and if you get used to it, could be fine for you forever. But.. I think after awhile the drops will start to get painful, without the cusion of the extra volume. You might also have other traction issues.
I dont know if it would work or not, but plausably you could rebuild the wheel with a dx32 and 2.5 tire in the future, if it turns out not to work in it's current state.
Ps, anyone know how long those cranks are?
__________________
There is nothing worse than a gross exaggeration.
Max_Dingemans is offline   Reply With Quote
Old 2004-08-07, 02:57 AM   #4
TheBadger587
HSG/DH MUni (Represent?)
TheBadger587's Avatar
Send a message via AIM to TheBadger587
i've read in many threads the frame isnt wide enough for a 2.5" tire. otherwise, it's a cheap trials cycle. keep in mind cheap is both good and bad. i think it'll be just fine for hopping/dropping off of picinic tables.
__________________
Gliding, finally.
AIM:TheBadger587
TheBadger587 is offline   Reply With Quote
Old 2004-08-07, 06:19 AM   #5
UniBrier
Time To Ride
UniBrier's Avatar
The DX20 is fine as a heavy duty freestyle or light trials. I've got one as soon as they came out. I'm 180lbs do lots of 2 foot drops and one foot ups with no apparent damage to the uni or cranx yet. Picnic tables shouldn't be a problem.
Max is right that it won't take the place of a true Trials Tire. The landings are not as cushy and there is not as much spring for jumping.
The cranks are 125's (5 inch) vs. the 140's on the KH/Summit wheelset.
It makes a great street machine when you don't need the full trials set up. The shorter cranks make it a bit faster.
A LUNA TRIALS wheel will fit in the frame. I put my Summit/KH wheelset in the DX20 frame and there is plenty of crown and side clearance.
THE PROBLEM IS THE OUTSIDE DIAMETER (OD) OF THE BEARINGS IS DIFFERENT BETWEEN THE TWO WHEELSETS. The KH/Summit Bearings are more than 40mm OD, the DX20 Bearings are under 40mm OD. A standard KH/Summit Wheelset will not seat into the DX20 frame.
Lacing up a 48 spoke dx32 trials rim onto the DX20 hub and a Luna trials tire should work.
I put up a few more pics at the end of my 2004 Torker Gallery. Here is the crown clearance of the Luna in the DX20 frame.
__________________
Steve
Hop Drop & Roll
“If something is too hard to do, then it's not worth doing. You just stick that guitar in the closet next to your
shortwave radio, your karate outfit and your unicycle and we'll go inside and watch TV.” – Homer
UniBrier is offline   Reply With Quote
Reply
Tags
torker, trials
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.09197 seconds with 9 queries
