Unicyclist Community
Reply
Old 2004-07-21, 10:33 PM   #1
Sofa
you - pee - dee
Sofa's Avatar
Lock nut reusability?
First off, let me give my praise to lock nuts right now, I use them on my seat bolts, (seat post and handles) and on my main bearing caps.
I highly recommend them, no need for loctite, and they simply don't undo until you want them to.
They look like normal nuts with a foggy/white plastic coating inside. They are 1/4" and you can buy a box for dirt cheap.
I have also replaced the stock bearing bolts on my uni's with hardware store ones. These are 1/4" with a herxagon head, 11mm socket type. I believe they are an inch and a half, and the top half inch has no threading.
What I like about these, is that they will bend inside of the main bearing cap, and not snap. I have had bent ones (realistically, they only bend a tiny bit). I have had the stock ones snap before, and that sucks. I have not noticed any unusual wear and tear in the holes by using these bendable bolts, but they are the only things I will use again. (unless a new frame would not allow them)
Anyways, back to the point of my thread: once you undo a lock washer, can it still be used as a secure means of securing the pieces? Or do the threads cutting through them the first time make them a one time use only item?
- I am undoing them or even bothering to look at them after months of use, by the way
__________________
Happy Life Day
Sofa is offline   Reply With Quote
Old 2004-07-21, 10:43 PM   #2
onetrack
Registered User
onetrack's Avatar
Send a message via AIM to onetrack
I agree, locknuts are awesome. They are used alot on skateboards due to their resistance to vibration. from my experience, locknuts loose effect gradualy from stress and threading/unthreading.
I have a semcycle, I put thicker bolts through the bearing housings and instead of locknuts, I put two regular nuts on each bolt and just tighten them against each other (it makes things faster).
mike
onetrack is offline   Reply With Quote
Reply
Tags
lock, nut, reusability
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.05601 seconds with 9 queries
