Unicyclist Community
Reply
Old 2004-06-22, 01:56 PM   #1
nickvb123
got balance?
nickvb123's Avatar
Level 9 skill
http://www.unicycling.org/unicycling/skills/skills.html
Level 9
Ride one footed with the seat out in front for 10 m
Something i would like to know...Is the seat allowed to touch the body while doing this?
I'm guessing it is not because otherwise it is too easy to be level 9 but i would like to have this confirmed by a higher authority.
My interpretation was that for all seat out skills, the seat cannot touch the body. But this is quite hard to do with 1ft seat out front...i suppose thats why its lvl 9???
If you are doing a skill with the seat out and the seat touches your body does this automatically not count?
nickvb123 is offline   Reply With Quote
Old 2004-06-22, 02:27 PM   #2
Robbie
Registered User
Robbie's Avatar
Stop showing off mr i can do level 9 and 10 skills I would guess that it is not allowed to touch the body, otherwise way to easy for level 9. But then again, i'm not a freestyle nerd so i don't know much about that sort of thing
__________________
Quick, get the access codes!
Robbie is offline   Reply With Quote
Old 2004-06-22, 02:45 PM   #3
Borges
Registered User
Wow!
I just logged on to ask a question about riding 1ft seat in front, and here's a thread about it.
Thoughts have been mirrored through the center of the earth and entered the vacant space in my brain.
Anyway. What I wanted to know is:
Is it ok to hold the seatpost against the non-pedalling leg or does that count as holding the seat against the body?
__________________
What happens on the internet stays on the internet.
Borges is offline   Reply With Quote
Old 2004-06-22, 03:01 PM   #4
U-Turn
Small fish, small pond
U-Turn's Avatar
For the skill levels, it is ok to brace the seat or arm/hand against your body. Although some people might think it's bad form, it is perfectly acceptable for level 9. For competition, bracing the seat against your body incurs a lower score than holding it out away from your body.
__________________
Weep in the dojo... laugh on the battlefield.
-- Dave Stockton
U-Turn is offline   Reply With Quote
Old 2004-06-22, 05:37 PM   #5
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
CORRECTION ONE:
It is acceptable in the USA skill levels. The IUF version of the skill levels (same list, different interpretation) sticks to the skills as defined in the Standard Skills List. That means, in seat out skills the seat is not allowed to touch the body. That's why seat in front 1-foot is level 9. It's not the hardest one (for me) in that level, either.
{"I'm not a level 9, but I play on on TV." -- John Foss, who plays level 9 in the IUF Skill Levels video}
CORRECTION TWO:
In Freestyle, yes. In Standard Skill, you would get zero points if you have "seat in front" on your list and then you do "seat in front against body." You have to list the skills you are going to do, or vice-versa, to get the points.
The USA levels were changed to accommodate the problem skills that typically hold riders back in getting to the next level. The seat out skills were determined to be proportionally harder than the other skills with them, unless riders were able to touch the body. But this causes problems with interpreting skill names. For skill levels it's one way, and for Standard Skill it means something else? So I would rather re-organize the skill levels, or more simply *correct* them to add "against body" where necessary to bring them back into line with the official definitions of those skills.
__________________
John Foss
"jfoss" at "unicycling.com"
www.unicycling.com
"Unicycling is a way of looking at the world, making a choice to slow down, finish what you start, doing things not because they're easy, but because they're a challenge." -- Nurse Ben
johnfoss is offline   Reply With Quote
Old 2004-06-22, 07:06 PM   #6
U-Turn
U-Turn's Avatar
Thanks John, although I would prefer the word ELABORATION since that is what you did.
__________________
-- Dave Stockton
Old 2004-06-22, 07:08 PM   #7
johnfoss
North Shore ridin'
johnfoss's Avatar
I guess so. Sorry if it sounded harsh. Or I could combine the two words together?
ELABORECTION.
Uh, maybe not.
__________________
John Foss
www.unicycling.com
Old 2004-06-22, 07:09 PM   #8
U-Turn
U-Turn's Avatar
Ha ha, whew!
__________________
-- Dave Stockton
Old 2004-06-22, 08:10 PM   #9
Borges
Registered User
What about my question?
(Yes, it IS all about me, thanks for asking )
If I had entered "one foot, seat in front (not against body)" on my standard skill score sheet. Would I get points if I held the seatpost against my leg to help steady the uni?
__________________
Old 2004-06-22, 09:37 PM   #10
johnfoss
North Shore ridin'
johnfoss's Avatar
Quote:
The difficulty judges would give you "100." That means to subtract 100% of the value of that skill. Zero points, because you will have done the wrong skill.
Here's the breakdown:
15. a) 1ft seat in front, against body 3.8
b) 1ft seat in front 4.5
c) 1ft seat in front - c 4.7
d) 1ft seat in front - 8 5.0
e) 1ft ext, seat in fr against body 4.0
f) 1ft ext, seat in fr against body - c 4.2
Only 0.7 points different, but you have to do the skills you put on your list.
__________________
John Foss
www.unicycling.com
Old 2004-06-23, 09:46 AM   #11
nickvb123
got balance?
nickvb123's Avatar
I will learn to do it without the seat touching the body. This way i can get more points in standard skill. if i ever compete in it...Anyway this way no ones complaining.
Reply
Tags
level, skill
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.14406 seconds with 9 queries
