#1 |
Ever hoping for the best!
Wheel removal with Magura HS-33 brakes
I recently got a unicycle with brakes. They are the Magura HS-33 model. One complaint I have about the brakes is that I have to remove one side to take the wheel off.
I was reading the technical manual for the brakes and noticed that they appear to have quick release features for bicycles. Can someone explain for me if this is a possibility on my unicycle? Right now there is a bracket that has two bolts holding the brake to the frame. The brake bosses have two threaded holes that the bracket attaches to. The frame in question is a KH24. Thanks for any advice. -mg
__________________
The sun is the same in a relative way but you're older, shorter of breath, and one day closer to death. michael_j_grant (at) yahoo (dot) com Gallery: http://tinyurl.com/34my5c |
#2 |
www.gb4mfg.com
The QR you described is only for cantilever or V-brake type studs.
I usually just deflate the tire and pinch it to get it through the brake pads. |
#3 |
you - pee - dee
if you had one brake boss on each side like bikes, you could have the quick release. because you have a 2 post set up, you (i'm almost positive) can't have the quick release feature.
I have two quick releases on my bike brake, two flips of switches, and my brakes are completely off. For this reason, any uni i have with a brake will have this setup, not the post mount
__________________
Happy Life Day |
#4 | |
#3649
Quote:
#5 |
Small fish, small pond
George is on the money. Just deflate the tire and you're good to go.
__________________
Weep in the dojo... laugh on the battlefield. -- Dave Stockton |
#6 |
BIG rides: 24"/36" on/off road
I've used both types and even without the quick-release feature, I vastly prefer the two-bolt type. It is so much nicer. Just take one side off (takes 10 seconds) or deflate the tire. Putting it back on takes maybe a minute since you have to adjust and get it just right. The design is so clean and works so well. I've also found that this is something I rarely have to do. Using the Gazz I just don't get flats (well, maybe once a year).
---Nathan |
#7 |
you - pee - dee
hmmm, all valid points...you win (plus it looks a lot cleaner, i suppose)
__________________
Happy Life Day |
#8 |
I didn't even mention the booster issue...
| Tags |
| brakes, hs33, magura, removal, wheel |
