#1 |
Registered User
Learning to one foot
Today I finally got my rim fixed. My crank is still bent from doing muni and stair jumping in virginia. I feel like Im not one of you guys because my unicycle sucks so bad. Oh well. I should have a summit in a month. Oh yeah one foot.
Today I decided to try one foot riding a little bit. Do you need to be on a hill? When I saw frank do it he was on a hill. When Im riding normal, should I start by putting less and less pressure on my right foot until I decide to take it off? I read a hoseclamp thread. Im definitely doing that tomorrow. Thats such a good idea! Thanks for the help. |
#2 |
The Russian Bear!!!
George, one footing down a hill is a great way to study the cloud formations. At least it was for me. --chirokid--
__________________
"Other than that, the best maintenance is to keep riding it as this helps to keep the eccentric nut on the saddle in optimal condition." quote by Mikefule |
#3 |
Guerilla Unicyclist
I found it easier to learn going *slightly* downhill, just so I could get used to the feel of it without throwing mself of balance with my pedaling. I found that I needed to lean back more than felt safe at first, as I'd lean forward as I pushed down on the pedal and the uni'd kick out behind me. It's a lot to do with subtle weight shifting I found. Try it from one foot idling.
__________________
OWS "...I explain briefly to him that such conduct leaves him vulnerable to accusations of being an idiot. We part as enemies" - Mikefule |
#4 | |
Waffle-Tosser, Time-bider and JCTK
Location: the bustling metropolis of Nelspruitia, south africa
Quote:
with the emphasis on try riding across the hall and lifting one foot, trying to find the fork without shoving my foot on the tyre and faceplanting and one foot idling, trying to get enough oomph into that one foot to actually get it over the top i just can't seem to get it to complete the circle how do u get from one foot idling into the stroke for one foot riding? |
#5 |
Guerilla Unicyclist
I go for one firm but controlled push when my pedalling foot is forward. Lean back as you push down tho, or just hit the deck! Also putting a *bit* of pressure on the frame to help with momentum is useful in idling.
I think the biggest thing is the deft weight shifts, it felt weird leaning back at first then it just becomes second nature. Practice practice practice!
__________________
#6 |
Registered User
when i learned to ride one foot i didnt think of putting my foot on the frame and just extended it back.I still cant put it on the frame very well,but i can go a half mile or so with it extended.
#7 |
I am the Walrus!
Going down a very slight slope helps a lot. But make sure it's not too steep, then it's even harder. And you'll get too used to the momentum of ust moving downwards, rather than just using your own power to pedal.
__________________
Something is either worth dying for or it's not worth doing...Abbie Hoffman mDOTeDOTatkinsonATgmailDOTcom President of the MRIS ☮ Unicycle For Peace ☮
#8 | |
Registered User
today i rode about 20 pedal strokes a few times. about 8 full pedal strokes average. my learning method worked really well! i was really happy with my results after one day. This method:
Quote:
#9 | |
Unicycle teacher
Quote:
#10 |
Registered User
I decided today that i was going to learn to ride one footed. So i went riding and i slowly released pressure from my right foot until it was completely off of the pedal. first i did 1 rotation. then 2. then 3. then 6. then 6. then 13. then my best was 20. i think its the best way to learn to ride one footed. i cant even idle, or one foot idle. or ride backwards. did i skip a step?
#11 |
Registered User
Today i also did the thign with tape and the hose clamp. although i dont even use the crown yet. my foot just sways in the air while i ride
#12 |
Unicycling Addict
uphill or downhill?
Am I the only person who found that one-footing uphill was easier? That way you could sort of lean forward and give big pushes. I found going downhill challenging at first cause you had to be controlled in slowing down the uni...
I actually stilll think it is easier to one-foot uphill and only just mastered one-foot from one-foot idle, after being able to do figure 8's both directions.... ?? Zia
__________________
Why would you need two feet, if you only have one wheel? Last edited by zia; 2004-04-03 at 04:28 AM. |
#13 |
Registered User
i dont have ANY hills where i live so i just do my technique. anyway, it rules yours
| Tags |
| foot, learning |
