Unicyclist Community
Reply
Old 2004-03-13, 03:20 PM   #1
gpickett00
Registered User
gpickett00's Avatar
sixsixone 4x4's
I'm considering buying a 20" summit to replace my current 24" sun which isnt bad for a beginner. But recently whenever I fall off the pedals hit my shins really hard and i want to get 4X4's. Is there a way to avoid hitting my shins a lot?(besides just being more careful) Should I just tough out the wounds until i can get a summit? (this summer) Or should i delay the summit and get 4X4's. Thanks.[IMG]A:\MVC-012F.JPG[/IMG]
gpickett00 is offline   Reply With Quote
Old 2004-03-13, 03:32 PM   #2
muniracer
Hell On Wheel
muniracer's Avatar
Send a message via AIM to muniracer
I think this is the normal progression:
(1) beginner- many small injuries, wear armor
(2) sport- few injuries, dont need armor
(3) expert- some medium injuries, wear armor
(4) pro- possible big injuries, wear armor
edit- these levels above are arbitrary, i just assigned each separate step a title.
So as you learn, you will fall a lot and will make some scars that'll last a long time if you dont wear armor. Then, once you learn how to ride and get smoother, you wont fall much and you still wont be doing that big of stuff so you can get away without wearing armor. But then, as you start doing bigger hops, bigger gaps, more technical freestyle tricks, you will start hitting your shins again. Then as you get really good, since you will be doing very difficult and risky lines or tricks, you risk major injury despite being less likely to fall. you will wear armor just in case.
Get some 4x4s. you can get them for 20 USD as jensonusa.com or something like that, i dont remember. you will probably wear them for a while, put them down for a while, then pick them back up in a year or so, depending on how fast you progress.
__________________
The Hell on Wheel Unicycle Gang owns you!!
http://www.unicyclist.com/gallery/albuq25
muniracer is offline   Reply With Quote
Old 2004-03-13, 03:55 PM   #3
gpickett00
Registered User
gpickett00's Avatar
YES! instead of getting a new uni i am definitely getting new armor. about 45 minutes after i made that post i was practicing hopping from a 6 inch curb and i fell. i also need to wear gloves at this point so i dont get gravel in my hands when i try and save myself. Im accident prone
Old 2004-03-13, 08:09 PM   #4
gpickett00
Registered User
gpickett00's Avatar
that is an interesting progression by the way
Reply
Tags
4x4, sixsixone
Search this Thread:
Advanced Search
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2005 Gilby
Page generated in 0.06728 seconds with 10 queries
