#1 |
Now with added jazz croutons!
Onza Vs Kris Holm
Hi de hi one and all......or none.
Decided a new unicycle is in order after hurting mine far too much recently. Don't get me wrong lovely unicycle you and I have had some lovely times together, but I think it's time I moved on. I do still love you, honest. Anyway, back to the matter in hand (she gets very emotional sometimes). What to go for, I've starting saving up some pennies and hopefully in a month or two should have enough for a lovely shiny new unibike. The question is what to go for? I've narrowed it down to either an onza or a Kris Holm trials.....I think. Can give me a bit of guidance as to which is the better uni? I know it's tough to take 2 things and say "Yes this one is definitely superior," but if some people with experience with either and/or both of the unicycles could give me some guidance as to what each one's strong and weak points are, it would be muchly appreciated. I'm planning to be doing mostly trials, and the odd wee bit of Muni. But am saving adventuring into the world of off road in any serious sense until I've saved up again and got myself a half decent Muni. I've not fully decided on what to get yet, so if anyone has any suggestions other than the onza or the kris holm that would be cool n groovy. Cheers ears. Kit P.S. I know this ought really to go in the product review forum but this one seems to get the most readers, so bugger it! It's here now, and here it shall stay. |
#2 |
Registered User
I have neither, but this thread should help.
John edit: just noticed I now appear to be an 'expert unicyclist' Wow, I'm honoured. Didn't think I was that good, but who am I to argue with the forum?
__________________
Never argue with an idiot; they drag you down to their level and then beat you with experience. Last edited by johnhimsworth; 2004-02-13 at 02:51 PM. |
#3 | |
NAUCC 2006 Memphis
Re: Onza Vs Kris Holm
Quote:
I have a guy that works for me that calls it that. Of course he makes up words in the course of conversation all the time. It is so common we actually had a "Word of the Day" board dedicated to his vocabulary blunders. Words uttered by "Mike" Determinism- I think you'll do well, you have a lot of determinism. Unibike- You going to go unibiking? Lincoln Logging- Didn't you ever go Lincoln Logging as a kid? Anybody else know someone like that? I swear I will be able to post a new one that he has muttered by the end of the day. |
#4 |
rotartsinimdA
Get the onza itll hold up for ya for quite a while as you progress into harder and harder trials.
__________________
If you're a psychotic murderer who needs to dispose of body parts across town, dress up as a Godspell unicycle mime. The unicycle case will fit the average-sized kid and people tend to assume the smell is just coming from you. |
#5 | |
Waffle-Tosser, Time-bider and JCTK
Location: the bustling metropolis of Nelspruitia, south africa
Quote:
it's an auto 'upgrade' that kicks in based on the amount of posts u make (that's why jagur can wheelwalk a coker) if u want to change it to something...else, u need to go into the 'user cp' it's in there somewhere |
#7 |
Hell On Wheel
okay. I have the onza. My bro and friends have khs and summits.
(1) The onza is prettier (2) both have kh style seat (3) both have splined hub (4) onza is lighter while kh is stronger (both are light and strong, though) (5) onza has q-factor (cranks bend at angle away from wheel to prevent ankles from hitting nubs. This makes sharp turns harder and you are a little wider. But until you get used to it, the kh will kill your ankles. (6) The kh seems to have a better crank attachment system. i will have a lot of trouble rmoving my left crank if i need to since crank grabs have turned the bolt into an oval and it wont turn (look for my post, "oh nooo"). (7) both are about same cost. (8) you will have to replace pedals for both (9) kh replacement parts *might* be more accessible (i havent needed to replace anything so im not sure) (10) onza has a yuni/nimbusII style crown while kh is flat ( i prefer the onza) (11) kh has been more ridden and has proven to be great! (12) onza is new (i have series II which just came out in november (?)) so is untested so these are facts/opinions on this subject. since i have ridden both and kno people who have both, i consider myself somewhat knowlegable on the subject. i would suggest the onza just because not as many people ride them and it would be good for everyone to know how good they are, which comes from testing. But if you dont want to be the guinea pig of a test, get the kh.
__________________
The Hell on Wheel Unicycle Gang owns you!! http://www.unicyclist.com/gallery/albuq25 |
#8 |
Registered User
This question is kinda a tossup. The Onza and KH look just as good as eachother, but the Kh is stronger. The Onza, by my measurements, is about 2 lbs lighter, but also the quality of their hub/crankset is appearing to be unacceptable. Too many people have reported problems with the hub having playu in it, even after tightening the cranks. This isn't a fatal problem, but trust me, it's really unnerving when trying to to precision moves and you get this loud creak accompanied by about 1mm of movent of your crank. I have the Onza, but I think the KH is a better bet. At a camp I went to, we got a chance to compare the 2 sidebyside, and we observed multiple things. First, despite the measured weight difference, noone could feel it just by holding the 2. Secondly, the KH frame is manufactured with much greater precision. The Kh frame was manufacxtured with very good welds, while the Onza's suck. Also, the Kh frame had even clearance from the tire, while the onza frame was offset abvout 2mm to one side. Thirdly, the KH had the nubs, which the owner didn't complain about, while the onza didn't. Fourth, the KH did look better than the Onza in person, although the Onza hub looked nicer. Fifth and finally, the wheelwalkers in the group noticed it wasa easier to wheelwalk the KH than the Onza, because the Onza frame got in the way. I've especially noticed this since then. aI also have the complaint that the hight profile Onza crown hits the side of your knees much more easily than the KH.
My $0.02 |
#9 |
unity - as 1 stand together
Señor Franklin-
I have some significant slop in my KH hub (trials). I just didnt want people to think that the KH was the definite winner in this area after reading your post. The slop doesnt bother me much though. I dont think i even notice it any more. It's been this way for a while and hasnt gotten any worse so i dont really mind. Despite some small problems(ankle biter cranks and kinda wierd bearing holder shims), my KH is a beast! I'm glad i got it. Just another opinion to add to the mix. -erik
__________________
Neener, neener, neener. -harper Last edited by mango; 2004-02-14 at 01:24 AM. |
#10 |
Hell On Wheel
gerble, a lot of your statements are valid but are opinions and coincidences. My wheel came centered, my welds are fine, and the problems with the crown probably have more to do with which one you are used to. Since my muni has a yuni frame, the onza was as good as I could have wanted. i find the kh to be inferior since i am not used to riding on it. Another thing, i can definitely feel a weight difference between the kh and onza.
dont forget, there are two onzas. uni.com hasnt updated the picture but the new one is much better looking. it DOES have knobs but the q-factor (as explained above) prevents them from being a problem. I can ww fine on the onza. i do want hear which you decide on, when you do.
__________________
#11 |
We own you
I think that if someone owns a KH, they will say that it is better and defend any mentioned problems, and if someone owns an Onza, they will do the same with it. Both have their own pros and cons. There have been many mentioned problems or things people would want different with both the Onza and KH.
john |
#12 | |
Hell On Wheel
Quote:
__________________
#13 |
Registered User
Does anyone have both? I sort of doubt it, but someone may.
#14 |
Newsgroup User
Posts: n/a
On Fri, 13 Feb 2004 08:40:12 -0600, MrBoogiejuice wrote:
>P.S. I know this ought really to go in the product review forum but this >one seems to get the most readers, so bugger it! It's here now, and here >it shall stay. I think your post fits here rather than in Product Reviews. Once you got either the Onze or KH you can write a review, and THAT would feel at home in PR. And about "here it shall stay": as a prediction that's probably true, but if you mean it as a commandment, you should know that a handful of people have been given the ability to move posts from this forum to another. Klaas Bil - Newsgroup Addict -- I have a feeling you might need two points of contact with the ground for such a thing to work? Or at least training wheels on the front and rear. - John Foss commenting on a picture of a one-wheeled vehicle he saw on RSU. |
#15 |
Expert UPD'ist
I started the thread mentioned up above and my final decision ended up being neither. I ended up getting a GB4/Profile/Airseat set up. I have all of the parts that i could possibly dream of and its a gorgeous frame. So if you have the money (itll prolly be about 600 if you get a profile set up) Id get a custom frame from someone willing to do it and work from there just hwo you want it.
__________________
My image was voted out. Last edited by fluffinator007; 2004-02-14 at 07:01 PM. |
| Tags |
| holm, kris, onza |
