#1 |
Hell On Wheel
aw nuts!
i was riding and looked down and...gasp! here is the crank with the missing piece. its not the side i crank grab with so i dont know how i lost it. i think its just a dust cap but if not...darn.
__________________
The Hell on Wheel Unicycle Gang owns you!! http://www.unicyclist.com/gallery/albuq25 |
#2 |
Hell On Wheel
sorry the pics are so big but here is the side with the piece.
__________________
#3 |
Average wheels: 1.5
That's more than a dust cap, it's the self extractor for the crank. With that thing in, unscrewing the bolt in the centre will pull the crank off. Without it it'll just remove the bolt but leave the crank there.
I think they're threaded the same on both sides, so you should be okay; just don't lose the other one... I haven't worked out a really satisfactory way of tightening the things. I use the end of a screwdriver (or key, if I'm in the middle of nowhere) to push them tight. Presumably you can get a special gadget to tighten them properly... Phil
__________________
"Cattle Prods solve most of life's little problems." |
#4 |
Average wheels: 1.5
Incidentally, IrfanView is a very nice little program that will shrink pictures down so you don't end up with almost 2MBs of pictures in a thread...
![]() Phil
__________________
#5 | |
Unicyclist since Nov 2000
Quote:
__________________
"I have to overcome a 'stress hill' when tightening the nuts, but once installed they sit in a 'stress valley'. " --Klaas Bil |
#6 |
level 5 unicyclist
the link doesn't work
Ferko
__________________
Eenwieler, Einrad, Unicycle, Monocycle. It is just the same! |
#7 |
Hell On Wheel
if i have a crank extracter tool then i should still be good right? just unscrew bolt, then use crank extractor as i normally would with a square tapered crank...
__________________
#8 |
you - pee - dee
I can't really tell. Can you post a larger photo?
__________________
Happy Life Day |
#9 | |
Hell On Wheel
Quote:
__________________
#10 | |
Registered User
Quote:
A note for all you onza owners: I have the old Onza, and when I took apart the cranksert, I found the bolts were tightening on the splines. I put a washer in there to rectify the problem. I reccomend you do too. It only makes the bolt stick out an extra 1/8". Also, the hub works like the profiles. Don't fully tighten the right crank, alternate. 1/2 turn right, 1/2 turn left... That way the axle stays centered in the hub. If you do one side completely first, you can pull the axle out of the hub (I'm not saying this from observation, but sadly, experience). |
#11 | |
Guinness Mojo
Quote:
Threaded bolts can create a lot of force with just a little bit of twisting and can easily pull the axle through the hub.
__________________
john_childs (att) hotmail (dott) com Team Never Wash Your Muni My Gallery :: Unicycling Bookmark List :: World Clock |
#12 | |
Hell On Wheel
Quote:
__________________
#13 | |
Guinness Mojo
Quote:
__________________
#14 | |
Average wheels: 1.5
Quote:
Phil
__________________
#15 | |
Guinness Mojo
Quote:
Park Tool makes one. Park Pin Spanner SPA-2 Picture of it in use
__________________
| Tags |
| nuts |
